Thread started 26 Dec 2015 (Saturday) 13:33
70D with OCF using 270ex and OCF using YN560 ii - ok to do or making my life more complicated?
kezug
Dec 26, 2015 13:33 |  #1
Just as the title says, I am using my 70D (in Manual mode) with a 270ex on camera and a placed OCF using my YN560 ii.
I am shooting around 400 or 800 ISO at about 200-250 shutter and aperture at 5.6 - 8.0 for portrait style shots of family events, but nothing in studio or for any type of work...its once in awhile shoots.
I am bouncing both flashes to create the affect I want.
However, am I just making things difficult? I find myself having to adjust the manual YN 560 at various power or moving it to achieve the affect. I usually either try to add drama or to add more light that the bounce OCF is incapable of achieving or to fill in shadows.
I typically use the YN560 off camera rather than on camera as I seem to NOT get good results as the light power no matter what setting seems to produce a cool or flat image. I get a nice yellow (softer light) using the 270ex.
Ugh...so, I like the fun in having 2 flashes, but am I creating issues by having mixed types of flashes?
Should I invest in different flashes or replace one that I have?
Is there any suggested material to read for this type of setup?
Camera's: 70D, G12 | Len's: 18-135mm IS STM, 55-250mm IS STM, 50mm f/1.8 II | Photos:flickr (external link)
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Post edited over 7 years ago by MalVeauX. (2 edits in all)
Dec 26, 2015 14:01 |  #2
Heya,
Some lights do have different output temperatures which can cause odd issues with white balance. They also have different power outputs so you have to use each one to their advantage, or at least know their limitations.
You're not necessarily making things difficult, but that depends on how you're using everything (since it's not completely clear how you've set your lights). Some example images would help here to show what you think is not good.
Have you tried each flash individually to see if there's an issue with a certain flash?
White balance can be changed in post, so no matter how cool an image appears, you can warm it up. Shoot in RAW.
Are you trying to use TTL bounce with the 270ex and then using manual on the 560II and wondering why you're getting weird results? That can definitely be an issue that you're the root cause of, if that's case. The 70D has bounce exposure TTL issues for sure (well documented underexposure when using TTL bounce specifically, it's weird). While trying to do TTL bounce and then manually add the 560II is going to give weird exposure anyways if you're not being very careful with placement and power output of your manual 560II flash. If you're doing this, I would suggest you use two ETTL flashes and use FEC to use one as key and one as fill. Or, just use both in manual mode and manually set one as key and one as fill, or both as fill.
Placement matters. The closer your light to subject, the higher it's output. This changes your power levels immediately if you move relative to the subject(s).
When bouncing, the surface will give your light a color. Bouncing two different surfaces will give you blends. Keep this in mind.
Personally I would have no problem using the two lights together you're using, but I'd use them both manual and I'd use one as key (on camera bouncing) and one as room fill at a low setting--paying careful attention to not create weird shadows with my key bounce; Example: I'd first set the 560II off camera some where in the room and point it at the ceiling and do an exposure of the room without the 270EX involved, to get a gentle fill exposure value dialed in. I would leave that one constant. Then, add the 270EX as a key (you could use ETTL on this one if you wanted to make up for your moving around and the distance from flash to bounce surface to subject angles change drastically quickly and that's where TTL really is a time saver). If not much is changing you can use it manually to get the ideal exposure values.
If I were in your shoes and were replacing both lights, I'd replace them with two off-camera ETTL/HSS capable lights, like Yongnuo 685's with a 622-TX controller on the camera.
Very best,
kezug
Dec 26, 2015 14:49 |  #3
Thank you for taking the time to post and with suggestions as well. I am aware of the 70D bounced exposure issue so I am using FEL but that is not the difficulties. I just sometimes have a hard time getting more of a fill effect when using my setup as the scene seems to stay lit well, but when I dial down the power of the YN560II, it seems to then just darken the exposure instead of fill.
I think I will have to be more scientific in my tests and start learning/experiencing the affects of shutter vs ISO vs Aperture when using "flash"!
MalVeauX
Joined Feb 2013
Dec 26, 2015 14:51 |  #4
kezug wrote in post #17833113 (external link)
Heya,
As a note, when I setup a room for bounce, I don't change power on my flashes after I set it. I just use ISO to control the output. ISO up if subjects are distant to flash source. ISO down if they're closer.
Very best,
1,093 views & 0 likes for this thread, 2 members have posted to it.
1050 guests, 107 members online
