I have been tossing around the idea of a Macro lens. I have been looking at the Sigma 105mm macro and the Canon 100 USM (non L) Has anyone had any use the Sigma? Is not having IS a big issue in Macro. Thanks Cole
Dec 27, 2015 14:12 | #1 I have been tossing around the idea of a Macro lens. I have been looking at the Sigma 105mm macro and the Canon 100 USM (non L) Has anyone had any use the Sigma? Is not having IS a big issue in Macro. Thanks Cole Be Better today than Yesterday, strive to Be better Tomorrow than today
Dec 27, 2015 18:36 | #2 Save yourself some money. Get a Vivitar (Pheonix) 100mm 3.5 Macro
MalVeauX "Looks rough and well used" More info Post edited over 7 years ago by MalVeauX. | Dec 27, 2015 18:45 | #3 cole4570 wrote in post #17834196 I have been tossing around the idea of a Macro lens. I have been looking at the Sigma 105mm macro and the Canon 100 USM (non L) Has anyone had any use the Sigma? Is not having IS a big issue in Macro. Thanks Cole Heya,
Beekeeper Goldmember More info | Dec 27, 2015 21:55 | #4 I've got the 100L IS and love it, but it's the only macro lens I've got. I've also used it for close up birds, and portraits. I do hand hold shots with it too, so the IS does help there. Zach--C&C is welcome on my photos
Dec 30, 2015 16:44 | #5 I also own the Canon 100mm L IS the new one. Is a wonderful lens, allow you take pictures as slow as 1/40s hand taken and looks sharp, with 2.8 aperture is very clear in low light situation and also for portraits photography is wonderful. Do i forget mention is sharp like a razor blade ?
MatthewK Cream of the Crop More info | Dec 30, 2015 17:31 | #7 Oh man, this is one of the few times in photography where I say "just do it". The macro world is almost limitless in it's interesting things to shoot; when I get really bored with photography, I take the macro lens out for a shoot in order to reinvigorate my interest and creativity.
Trad59 Member 40 posts Likes: 7 Joined Apr 2014 Location: Australia More info Post edited over 7 years ago by Trad59. | Jan 01, 2016 22:56 | #8 Echo others comments on 100L. Beautiful lens for macro, still life / mid tele. As a once Canon 6D, now Sony A7ii shooter, I've kept this lens for good reason. Being able to focus from infinity to macro with finesse and a high degree of acuity makes this a very versatile tool in the bag.
Archibald You must be quackers! More info | Jan 01, 2016 23:19 | #9 I bought the non-L, took some shots, realized I needed IS, and returned it the next day for the L. I'm glad I did. The reasons are mostly as stated by others - IS is very useful, especially when you are not in macro range - but even at macro distances IS helps. Canon R5 and R7, assorted Canon lenses, Sony RX100, Pentax Spotmatic F
Dalantech Cream of the Crop 5,379 posts Gallery: 525 photos Best ofs: 5 Likes: 3548 Joined Jul 2006 Location: Mt. Vernon, Mo. (living in Italy) More info Post edited over 7 years ago by Dalantech. | Jan 02, 2016 16:41 | #10 If the primary light source is natural light then get a long focal length lens. If the primary light source is going to be a flash then get a short focal length lens. You'll have to get the flash / diffuser close to the subject to get good light, so a short focal length lens will work best. Honestly I cannot recommend lenses in the 100mm range because they seem to be a jack of all trades but a master of none. Too short for natural light, and too long for a flash unless you get the flash out past the lens. If anyone tells you that a short focal length lens isn't a "bug lens"... Tech Specs: Canon 70D (F11, 1/125, ISO 200) + a Canon EF-S 60mm macro lens with 25mm of extension (1.7x) + a diffused MT-24EX (flash head "A" set as the key and "B" as the fill, both on the Canon flash mount). This is a single, uncropped, frame taken hand held. I am the "finger model". My Gallery
Jan 03, 2016 13:28 | #11 I"m also thinking of a macro lens, mostly I'd be using it for flowers, I think they would be good for that. So I've been poking around a little bit looking at a few options - At Amazon you can pick up a new Tokina 100mm f2.8 macro for $338, looks like a bit of a sale, anyone have experience with that thing? It does say first available in 2001, so 14 years old, not sure if lens design has changed that much since then. The L lens you guys talk about sounds great, but I'm not up for spending that much on a macro lens.
Archibald You must be quackers! More info | Jan 03, 2016 13:48 | #12 patrick j wrote in post #17842842 I"m also thinking of a macro lens, mostly I'd be using it for flowers, I think they would be good for that. So I've been poking around a little bit looking at a few options - At Amazon you can pick up a new Tokina 100mm f2.8 macro for $338, looks like a bit of a sale, anyone have experience with that thing? It does say first available in 2001, so 14 years old, not sure if lens design has changed that much since then. The L lens you guys talk about sounds great, but I'm not up for spending that much on a macro lens. The Tokina has quite a good review at photozone.de. Also keep in mind that one usually stops down to f/11 or thereabouts for macro work, where diffraction softening kicks in, tending to equalize the sharpness of all lenses. Canon R5 and R7, assorted Canon lenses, Sony RX100, Pentax Spotmatic F
Alveric Goldmember More info Post edited over 7 years ago by Alveric. (2 edits in all) | Jan 03, 2016 13:54 | #13 Permanent banThe Tokina sux: I had one and it had focus shift, and at normal/long distances to boot. Ended up replacing it with a Canon EF 100mm f/2.8 L IS. Also, the Tokina has a barrel that extends/retracts with focusing: these barrels are a no-no if you're thinking of using a ring flash, as the weight of the flash might wreck the lens. 'The success of the second-rate is deplorable in itself; but it is more deplorable in that it very often obscures the genuine masterpiece. If the crowd runs after the false, it must neglect the true.' —Arthur Machen
Jan 03, 2016 15:07 | #14 Opinions vary I guess. A used Canon 100 can be picked up on Ebay for about the same as a new Tokina, maybe that's the way to go.
JohnKoerner Senior Member 734 posts Likes: 68 Joined Jun 2011 Location: San Dimas, CA More info | Jan 07, 2016 12:07 | #15 Permanent bancole4570 wrote in post #17834196 I have been tossing around the idea of a Macro lens. I have been looking at the Sigma 105mm macro and the Canon 100 USM (non L) Has anyone had any use the Sigma? Is not having IS a big issue in Macro. Thanks Cole I agree on the idea of Sigma; I disagree on the 105mm.
| Latest registered member is semonsters 1257 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
