MA128 wrote in post #17834259
I'm a beginner using Lightroom 5 and don't understand why the JPG generated by Lightroom is noisier and less vivid than the JPG created by the camera. Both images have been edited in LR for tone, vibrance, sharpness, etc. in an attempt to make the DNG the equal of the JPEG. Thanks in advance.
JPEG from Camera
JPEG generated by LR5 from DNG file
Heya,
The JPEG engine in your camera is different from the JPEG engine of Lightroom 5 for starters, so they will not render the same output.
However, the issue looks to me like you're comparing your profile & image settings in your camera determine that JPEG output to a RAW file that doesn't use that, so naturally, one will be less sharp, less saturated, etc, because the JPG-only settings in-camera are not applied to that RAW file, only the JPG. Take a look at them. These settings do not apply to RAW files, just JPG output. To get the same JPG output from the RAW file, you need to apply similar settings in Lightroom to the RAW file, which will require more sharpening and vibrance/saturation, etc, tweak till you like the look. Then SAVE that profile so you can do RAW -> JPG from Lightroom and get the look you want and maintain the flexibility of shooting in RAW.
Very best,
