It's not a Fisheye, it's rectilinear. What that means is that it is corrected so that straight lines will appear straight. With a fisheye, any straight line that does not run through the center of the frame will appear curved.
All that said, on a FF (35mm format) camera the wide end of the 17mm lens will indeed be ultra wide. In my mind this range (UWA) is basically anything wider than 24mm. People think of this as 'ultra wide' mainly because it's the kind of focal length that really shows such a wide field of view that you can really see it in the pictures. But other than that (ultra wide), yes, it is just like any other rectilinear lens and is not a fisheye.
