saea501 wrote in post #17835952
It won't give you any better reach, it will however decrease your field of view. And this is
not to restart this age old argument once again. I'm simply stating my own experience when I put my newly purchased 70-200 f2.8 on my 600D. The field of view was just not acceptable to me which is why I got the 6D. You have to decide this for yourself.
TonyKInTexas wrote in post #17841084
OP, as hinted at by saea501, a cropped sensor does not really give you better reach. It uses less of the glass in front of the sensor so a so-so lens may appear to perform better. It also reduces the amount of DOF seen.
I also agree with Vertigo1 about the 5D3 and am toying myself with getting a 5D3 to replace my original 7D.
An APS-C sized sensor with approximately the same number of pixels, will resolve far more small detail at the sensor than one based on 35mm film. In a focal length limited situation this higher resolution will result in more pixels on any specific subject. If the pixel counts are exactly identical then the smaller APS-C sensor will record 2.56× as many pixels on any specific target. As long as the lens resolution is sufficient to match the sensor resolution, and most current quality lenses have sufficient resolution to outresolve current sensors (if that wasn't the case the camera manufacturers would not need to use AA filters on sensors) then the higher resolution of the sensor will always be an advantage.
With a 600mm lens I find that maybe 50% of my images actually need to be cropped to use only a 15×10mm area of sensor in order for the subject to fill the frame. I don't actually care how big the sensor is in this situation, as long as it will put the maximum number of pixels possible on the subject. If I were using an old 20D (my backup body) I could upgrade to any of the approx 22 MP FF bodies and I would get pretty much the same number of pixels on target. So in that situation no the "crop" format offers no advantage. On the other hand I could look at the 7DII or any of the other 18-20 MP crop cameras and they offer upwards of twice as many pixels on target compared to the 22MP FF bodies.
Admittedly there is a FF option that will match the crop bodies, the 5DS cameras have approximately the same linear resolution as the 18 to 20 MP crop bodies, so you can match the crop bodies for resolution, they do have very good AF systems too. The main issue for a lot of people with those bodies is frame rate and buffer depth. Being almost twice the price of a 7DII is also a big drawback for some.
Given the cameras that the OP is starting with, any of the 18 MP plus crop bodies are going to offer a significant 2× or better increase in total number of pixels on the subject, with the same lenses. That is a significant gain in resolution. To match that gain over the 300mm he has, using a Canon lens on the 6D would require the use of the 500mm f/4 L, or similarly expensive lenses with converters.
So if you are FL limited, and also want an excellent AF system, virtually identical to that in Canon's top of the range 1Dx, combined with high frame rate and good buffer depth, the 7DII would seem to be the best choice available from Canon, and maybe from any manufacturer. As seems to be clear from a careful examination of the facts, there is no general AF problem with the camera. It's just a system that takes some learning to understand and master. If you don't make the effort to do that it will disappoint. I'm sure that if Canon sold the 1Dx at around £1000 that there would be an awful lot of complaints about the AF, and other systems from inexperienced buyers who expect a camera costing that much money to just do it all for them. If I were in a situation that I could afford a new 7DII I would go out and buy one tomorrow without hesitation, knowing that the chances of it being faulty in any way would be very low.
Alan
