i have the eos m with latest firmware , using the 24-105 on it , got hold of a helios 44-2 lens so bought the adapter so it would fit the eos m , but all i get is update firmware failed , uodate lens firmware . any ideas much appreciated
Jan 04, 2016 08:14 | #1 i have the eos m with latest firmware , using the 24-105 on it , got hold of a helios 44-2 lens so bought the adapter so it would fit the eos m , but all i get is update firmware failed , uodate lens firmware . any ideas much appreciated Dave (mrmacca)
Qlayer2 OOOHHH! Pretty Moth! More info | Jan 04, 2016 08:15 | #2 Custom function menu: C.Fn-7 Release shutter without lens must be set.
Jan 04, 2016 08:20 | #3 thanks for the reply...unfortunately it still does the same Dave (mrmacca)
Qlayer2 OOOHHH! Pretty Moth! More info | Jan 04, 2016 08:24 | #4 Do you have a chip on the adapter? If so, pull it off (it's probably just glued on there). Some of the chipped adapters have invalid or old code that don't work with many camera bodies.
this is the adapter Image hosted by forum (767979) © mrmacca [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Dave (mrmacca)
Qlayer2 OOOHHH! Pretty Moth! More info | Is that an M42-Canon EF adapter?
sorted m8 , put a bit of tape over the contacts on the adapter , now its just getting used to it , cheers for the advice m8 Dave (mrmacca)
| Latest registered member is zachary24 879 guests, 130 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
