Thread started 05 Jan 2016 (Tuesday) 04:54
macro flash
Sophia ­ Scott
Joined Oct 2015
Jan 05, 2016 04:54 |  #1
Hello, I want to deal with macro photography. I have a EOS REBEL T2i and would like a help on how to start looking for a macro ring flash. I thought to http://www.macroringfl​ash.com/meike-fc100/ (external link) but I'm not sure if it's the right decision. Thoughts?
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Jan 05, 2016 06:56 |  #2
Sophia Scott wrote in post #17845094 (external link)
Heya,
Depends on what you want to do. That LED ring light isn't bright enough for still shot macro with a stopped down aperture for depth of field (think F8, F11 which is typical of macro). That light is basically a focus aid, or ok for fill light if your have a wide aperture and do not stop down (F2.8, F4, etc). It's just not that bright.
I would just use a normal speedlight with a diffuser.
If you want to use a ring light, I would still use a diffuser (a DIY setup). Yongnuo makes a nice ring light for a good price.
But really, a $40~50 manual speedlite flash and a DIY diffuser is the cheaper, better solution for light.
But it mostly depends of course on what you're actually wanting to do macro of.
Very best,
Atsumi
Jan 08, 2016 09:33 |  #3
I second a normal speedlite with a diffuser. A bracket to get it too the side of the camera and closer to the lens would be beneficial as well.
-Tiffany
Canon 5D Mark II / Rebel XT / 18-55mm / 24-105mm f4 L IS/ 50mm f1.8 / 70-200mm f4 L / 85mm f/1.2 L II /100mm f2.8 macro / 430EX II
[[Flickr (external link)]] [[Twitter (external link)]]
davholla
Gallery: 465 photos
Joined Nov 2014
Jan 13, 2016 06:12 |  #4
Atsumi wrote in post #17849768 (external link)
That can be a good idea, although I found it too difficult to setup.
This is quite good although you need to cover the light with some thing (e.g. toilet paper) to avoid getting reflections
Atsumi
Jan 13, 2016 14:37 |  #5
davholla wrote in post #17856366 (external link)
I made a box lined with aluminum foil with a paper towel diffuser, then stuck a white card on the other side of the lens to redirect some light.
-Tiffany
orionmystery
Post edited over 7 years ago by orionmystery. (2 edits in all)
Jan 14, 2016 08:44 |  #6
Agree. All you need is a speedlite and a DIY diffuser.
I use either a Canon 270EX (external link)
or a Nissin i40 (external link)
I like these two because they are light weight.
IMAGE: https://c1.staticflickr.com/9/8483/8284000386_6bc1f13223.jpg
As for DIY Diffusers, check out this link for ideas: http://orionmystery.bl​ogspot.my/2010/12/more​-macro-rigs.html (external link)
Kurt
Malaysia & Borneo herping/macro tours:
http://www.orionherpad​venture.com (external link)
3,364 views & 0 likes for this thread, 5 members have posted to it.
macro flash
2232 guests, 131 members online
