FORUMS General Gear Talk Tripods, Monopods & Other Camera Support
Thread started 05 Jan 2016 (Tuesday) 08:09
Macro Tripod (tabletop style) for heavy stuff
Poindexter
Gallery: 26 photos
Jan 05, 2016 08:09 |  #1
I'm in the market for something a bit smaller than my trusty old Gitzo 3530 legs. I'd like to spec it for what I think is the heaviest setup I'd use on it:
  • 1D body
  • Canon 180mm macro
  • some sort of head (start with a Markins Q3)
  • Novoflex Castel Q focus rail
  • Flash attached with Wimberly Macro brackets
  • And to get crazy technical on weight, there are plates and cards and all that other crap one forgets adds weight
It isn't super critical to nail this for weight purposes, so we can just say all this is probably around 10lbs-ish.
The Feisol TT-15 was my first choice at $59 until I saw a review that says it doesn't get perfectly flat. But for $59 I might have to get it anyway. (Digital Picture review (external link))
The Novoflex options look interesting, but I'm not finding much on how easy they are to use. (B&H Link (external link)). However, this starts to creep in price where "for just a little more"....
The RRS option might make the most sense of all and it packs up super small. The Really Right Stuff TP-243 (external link) is nearly $400 though.
And then there is the Berlebach wooden option (external link) from across the pond that I really like around $200 before shipping, etc.
flickr (external link) | SmugMug (external link) | Gear (external link)
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Jan 05, 2016 08:23 |  #2
Heya,
Check out the Sirui T-025X (external link).
Very best,
Poindexter
Gallery: 26 photos
Post edited over 7 years ago by Poindexter.
Jan 05, 2016 08:31 as a reply to  @ MalVeauX's post |  #3
Thanks MalVeauX. I'd jump all over those if I didn't already have some Gitzo travel legs that are quite similar. I'm looking for something even smaller!
johnf3f
Jan 05, 2016 14:53 |  #4
Certainly not light but have you considered the Gitzo 3320BS? Basically it is a short (2 section) legged version of a 3 series Systematic - very, very stiff and stable.
Life is for living, cameras are to capture it (one day I will learn how!).
Poindexter
Gallery: 26 photos
Jan 05, 2016 15:11 |  #5
johnf3f wrote in post #17845773 (external link)
Researching your suggestion landed me on an old thread you were involved in: https://photography-on-the.net/forum/showthre​ad.php?t=952675
It looks sweet! How much was it if you don't mind me asking?
johnf3f
Jan 05, 2016 15:23 as a reply to  @ Poindexter's post |  #6
I bought mine a few years ago and it was priced at £230 (UK) in those days, but my local camera shop was very cheap for Gitzos so I only paid £189.
I am not certain if Gitzo still make it so you may have to look around on the used market. It is extremely strong, forget the weight ratings, it holds over 100 kilos quite happily - I have used it to support me when getting things of high shelves/changing light bulbs etc.
Poindexter
Gallery: 26 photos
Jan 05, 2016 15:30 as a reply to  @ johnf3f's post |  #7
In the little bit of research I've done, since you brought it to my attention, it seems this is the best option. And that pricing is absolutely in line with my favorite options thus far....except the Really Right Stuff option.
I can't find anything on the used market. Not even a sniff of a 3320BS legs. With that said, I will keep my eyes open and pick them up later. Not to sound like a snobby rich jerk, but $200 isn't a bank breaker in this hobby!
In the meantime I'm pulling the trigger on the Berlebach mini legs (external link). They go low and pricing seems quite reasonable. I also think they look cool!
IMAGE: http://www.photomacrography.net/forum/userpix/1062_Berlebach1_1.jpg
johnf3f
Jan 05, 2016 15:46 as a reply to  @ Poindexter's post |  #8
Note that was pounds Sterling not Dollars!
I did a little looking around after my post and it appears that Gitzo have discontinued it. I have not used Berlebach tripods but I have heard good things about them and that Mini looks cool!
Poindexter
Gallery: 26 photos
Jan 05, 2016 16:11 as a reply to  @ johnf3f's post |  #9
Thanks and yeah I saw it wasn't the stinky currency of those dreaded colonists ;) ...figured those Gitzo legs are probably worth around $200 in used condition.
Archibald
You must be quackers!
Gallery: 789 photos
Jan 05, 2016 16:54 |  #10
OK, so you really want a small tripod, probably for outdoor use on varying types of surfaces. The Berlebach looks like a good solution.
Outdoors I hand-hold, but indoors I use a home-made camera stand that is heavy and rigid, characteristics needed for 1x and higher macro work. There is also the Kirk Low Pod for this purpose. These stands are probably better if you are working on a flat surface.
johnf3f
Jan 05, 2016 19:43 |  #11
Poindexter wrote in post #17845865 (external link)
OOH! Ouch! Ouch! Ouch!
Being a descendant of good Irish stock (pure for 300 + years) I wonder how long ago your ancestors "Colonised" your neck of the woods? True there was some sort of Norman invasion in the 11th century (father's side) - but we don't like to talk about that!
Just funning you! I hope you can eventually find a 3320BS they are a great tripod:-)
kaitlyn2004
Jan 05, 2016 21:11 |  #12
Poindexter wrote in post #17845177 (external link)
I'm waiting for the TT-15 to get back in stock at B+H, but I also saw that review but it seems to contradict feisol's note:
- Minimum height of 4.5 inches (11.00 cm) at lowest preset leg angle; it can go flat to the ground
Now it doesn't have an SET ANGLE that makes it possible to "lock against the ground", but given it can reverse fold it should certainly be able to be splayed out and easily balance
My Landscape Photography Videos (external link)
My Instagram (external link)
Poindexter
Gallery: 26 photos
Jan 06, 2016 06:51 |  #13
johnf3f wrote in post #17846156 (external link)
Just funning you!
I was too. I have an English grandmother and we always joke about how she is now a colonist.
kaitlyn2004 wrote in post #17846258 (external link)
I'm waiting for the TT-15 to get back in stock at B+H, but I also saw that review but it seems to contradict feisol's note: Now it doesn't have an SET ANGLE that makes it possible to "lock against the ground", but given it can reverse fold it should certainly be able to be splayed out and easily balance
Good point. That review I linked to wasn't the one where the reviewer was saying it didn't go flat. I cannot find that review anywhere, so I guess we're going to have to test it out ourselves when B&H gets one back in ;)
My concern about "not going flat" is that the legs aren't locked in when flat. Flat and unlocked means the whole thing will easily tip over with weight on top because an unlocked leg isn't doing anything.
I don't think the Berlebach I bought sits right on the ground locked either. It looks like it sits up about 2 cm.
7,137 views & 1 like for this thread, 5 members have posted to it and it is followed by 2 members.
1411 guests, 136 members online
