I use a scanning electron microscope at work. I frequently take overlapping photos that I merge into a larger photo using CS4. At low magnification the electron beam is not completely uniform over the entire photo. This means that one side of the photo is slightly brighter than the other side. In a single photo this is barely noticeable unless you look carefully. I sometimes have to merge 6-12 photos into a linear array. But what happens is that the slight brightness gradient in each single photo is magnified during the merge so that the array ends up being very overexposed on one side and very underexposed on the opposite side. If I try and correct the resulting array with a gradient it ends up blotchy and variable. So I've been taking each individual photo, opening it in ACR, applying a slight gradient and then merging the resulting photos. This takes a lot of time but it is the best solution I've been able to find.
If I unclick the blend option in the photomerge window I just get a very mosaicy looking array that looks like a patchwork quilt instead of a single photo. Is there a way to correct this in the photomerge process? Another way that I can save some time?
