Thread started 06 Jan 2016 (Wednesday) 18:17
Close to buying, but would like some input: AD360II or CL-600 (before the CL-600X releases)
ninobrn99
Jan 06, 2016 18:17 |  #1
I'm really having a tough time biting the bullet on my purchase!! I don't know if I should go with the CL-600 or the AD360II to get me by until I can find the AD600 or Cheetah stand releases the CL-600X at the end of March.
Cheetah Stand:
1x CL-600 kit = $578.88
1x RS-90 = $179.95
Amazon:
1x X1C XMT/RCV kit = $85.99
Total: $844.86
OR
Amazon:
AD360II/X1C combo = $545
Y-cable = $11.78
S-mount = 19.80
Battery Clip = $9.89
Bulb protector = $6.29
Cheetah Stand
1x RS-90 = $179.95
Total: $772.71
Obviously, the 360 is going to be cheaper, but do you all think 2x 600's might be overkill and a 600/360 combo might be a good mix for portability and selection for general on-location shooting? I realize that it's only $72 and I might as well spend it, but it's more about versatility for me. I'm leaning to having one of each, but would like some input from you all.
Nino
5D MK3 | iPhone 6s Plus
YouTube Channel (external link)
Ulysses01
Joined Jul 2013
Jan 09, 2016 02:43 |  #2
I'd hold off on the CL-600 altogether while waiting to see what the Cheetah 600X is actually going to be. It'll likely be here in only a couple months. In the meantime, pick up one or two CL-360 units. Can't go wrong with them. Lots of flexibility and power in a small package. You can expand later once the options become clearer.
ninobrn99 wrote in post #17847523 (external link)
Cheetah Stand:
1x RS-90 = $179.95
Amazon:
Total: $844.86
OR
Amazon:
Y-cable = $11.78
S-mount = 19.80
Cheetah Stand
1x RS-90 = $179.95
Total: $772.71
Nino
agv8or
Gallery: 10 photos
Post edited over 7 years ago by agv8or. (2 edits in all)
Jan 09, 2016 03:32 |  #3
Nino
Depends on what you're trying to kill? The AD600 does 1/256 power which is the equivalent of 1/128 power of the AD360II. Definitely the AD600 will be more versatile and with a self contained battery will be less cumbersome than the AD360II albeit a little bit larger. The AD600 also has the modifier mount built into the flash rather than needing a separate Pro S bracket to hold both the modifier and the AD360II. The TTL AD600 is 1 stop more flash output than the AD360II as well but it is also $250 more expensive. With two AD600's, you can utilize the 2-into-1 1200ws single remote flash head when it becomes available, just in case you want to kill something really big.;-)a
Rand
Gear
xseven
Joined Apr 2013
Feb 27, 2016 14:19 |  #4
And ... including the bracket ... half the weight of AD600 ... in case you want to hand hold it on a pole ... or the wind is blowing ...
1,888 views & 0 likes for this thread, 4 members have posted to it and it is followed by 2 members.
504 guests, 128 members online
