Thread started 09 Jan 2016 (Saturday) 08:58
RS-80 shutter release or equivalent brand, & 7D Mark ii
Quack ­ Me ­ Up
Joined Nov 2011
Jan 09, 2016 08:58 |  #1
First off, I assume these two are compatible from what I found online. I was wondering if when using the release does it override my current setup using back button focus? I guess I'd still like to be able to use BBF and just use the release to trip the shutter but not sure if this is possible.
Thanks for any help.
Jon
Joined Jun 2004
Jan 09, 2016 15:51 |  #2
If you're set to BBF, the remote release won't cause the camera to focus when you go to trip the shutter - you'll have to BBF then hit the remote, which sort of renders using a remote pointless since you use it to avoid directly touching the camera.
Jon
Cocker Spaniels
Quack ­ Me ­ Up
Joined Nov 2011
Jan 09, 2016 17:46 |  #3
I am looking at using the remote while doing some lens calibration along with my body. I know I could probably just use a shutter delay of 2 or 10 seconds but I thought I might use the remote for that purpose.
TerminalCity
Gallery: 16 photos
Joined Apr 2013
Post edited over 7 years ago by TerminalCity.
Jan 19, 2016 22:54 as a reply to  @ Quack Me Up's post |  #4
Just return AF to the shutter button for your testing purposes using a remote release, that way you don't need to touch the camera for the focus operation. If you want the AFMA value written to the EXIF then you need AF to be active when the shutter is released. BBF gets you nothing if you're doing AFMA on a tripod and it only takes 5 seconds to change the setting.
That's the way I used to do things using DotTune or eyeball test before I bought FoCal.
3,678 views & 0 likes for this thread, 3 members have posted to it and it is followed by 2 members.
1507 guests, 129 members online
