Thread started 09 Jan 2016 (Saturday) 21:13
Need to take some clothing product photography, but don't know where to start.
Wondertwins
Jan 09, 2016 21:13 |  #1
Hey guys, I was recently assigned to take flat product shots of shirts and jackets, and need help in terms of lighting. We'll be shooting at my buddy's living room and we have a large white oaktag paper that we bought for the background. I know there are some workarounds such as buying lighting from hardware store, but I'd like to know how I can replicate the shot below, with lighting rental equipment or DIY methods.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/01/2/LQ_769038.jpg
Image hosted by forum (769038) © Wondertwins [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/01/2/LQ_769039.jpg
Image hosted by forum (769039) © Wondertwins [SHARE LINK]
(Canon 7D Gripped) (Canon 35mm f/1.4 L) (Canon 135 f/2L) (Canon 430 EXII)Flickr (external link)
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Jan 09, 2016 21:21 |  #2
Don't mess with diy. You have a 430ex. All you need is a set of triggers a softbox or umbrella and a stand. Since its flat a single speedlite in a 42 inch umbrella and a set yn603 triggers will put you in business for under $100.
Wilt
Post edited over 7 years ago by Wilt. (2 edits in all)
Jan 09, 2016 22:32 |  #3
You sure you want to replicate the lighting of those shots?! It uses a rather specular (smallish) single source as evidenced by the shadows cast. A rather small softbox (or medium size one, too far away).
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Post edited over 7 years ago by PhotosGuy. (3 edits in all)
Jan 09, 2016 23:20 |  #4
Background
Shirt
paper towel
strobe
Camera
And borrow a steam iron from somebody.
Wondertwins
Jan 09, 2016 23:35 as a reply to  @ Wilt's post |  #5
Thanks. How would I set up the camera so that it is perfectly on top of the product?
Wondertwins
Jan 09, 2016 23:37 as a reply to  @ gonzogolf's post |  #6
Thanks. I actually don't have the 430EX anymore... How would I set up the camera so that it is perfectly on top of the product?
PhotosGuy
Joined Feb 2004
Jan 09, 2016 23:43 |  #7
Wondertwins wrote in post #17851936 (external link)
So use the one on your camera.
Ladder?
gonzogolf
Gallery: 561 photos
Jan 09, 2016 23:45 |  #8
Then amend my advice to include a YN flash. You are attempting to do pro work. Make a little effort.
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Jan 09, 2016 23:57 |  #9
Some tripods have an additional screw attachment on the bottom of the centre column which allows you to attach your camera and position it pointing down. However that will generally only work for small items as the camera will be quite close to the floor.
The traditional way of shooting from above, for larger items, would be to use a boom that attaches to the tripod (with a counter weight on to balance the weight of the camera). The problem with that is that focusing/altering settings can be difficult. At a minimum you would need a step ladder to get high enough to look at/adjust the camera. Better yet some for of remote controller (like Cameranger).
Dan Marchant
nathancarter
Gallery: 32 photos
Post edited over 7 years ago by nathancarter.
Jan 11, 2016 07:53 |  #10
Wilt wrote in post #17851850 (external link)
But if that's what the paying client wants, that's what the paying client gets.
A lot of catalog photos are like that - or worse, they have similar shadows 'shopped in.
Also, a small/hard light source will show texture and depth better than a big soft flat light.
gjl711
Jan 11, 2016 08:11 |  #11
Wondertwins wrote in post #17851933 (external link)
Don't bother, It makes it harder to shoot. Set up a table (or a sheet of plywood) at an angle, maybe 30~45 degrees. Then shoot comfortable standing up. Way easier.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Wilt
Jan 11, 2016 08:44 |  #12
nathancarter wrote in post #17853587 (external link)
I don't disagree...I was merely asking the OP, to verify that style was desired by the client (and not out of lack of his own knowledge or the client's). As photographers we can suggest things to clients as consultants, telling them why do it any different (and let them consciously choose what style)
As for texture, the example photos only show wrinkles! :rolleyes:
PhotosGuy
Joined Feb 2004
Jan 11, 2016 08:54 |  #13
gjl711 wrote in post #17853598 (external link)
I was thinking that, but when the OP said that he "was recently assigned", it sounded like a class project & I figured that he was expected to add some of his own creativity to the mix.
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Post edited over 7 years ago by Left Handed Brisket.
Jan 11, 2016 09:28 |  #14
i use a c-stand, grip arm and baby pin with a threaded hole in the end. Then a 1/4-20 rod to the camera. Works great, but I also use gaffers tape around the strap to both get it out of the way and have a failsafe should the 1/4-20 rod break or i do something stupid. Shoot tethered if you can.
the trick with this type photo (assuming just one light source) is going to be getting the light far enough away so fall off across the product is not too great. You can see in your examples that the right side is somewhat darker than the left, you're going to want to minimize that effect via Inverse Square Law.
OhLook
Gallery: 105 photos
Joined Dec 2012
Jan 11, 2016 11:16 |  #15
With those angles, you may have to pin the garment to cardboard to keep it from sliding off. Several pins through (e.g.) the back of a shirt where they won't show when it's buttoned.
PRONOUN ADVISORY: OhLook is a she. | A FEW CORRECT SPELLINGS: lens, aperture, amateur, hobbyist, per se, raccoon, whoa | Comments welcome
2,523 views & 1 like for this thread, 9 members have posted to it and it is followed by 4 members.
1092 guests, 183 members online
