Thread started 10 Jan 2016 (Sunday) 13:10
Canon MP-E question
davholla
Gallery: 465 photos
Joined Nov 2014
Jan 10, 2016 13:10 |  #1
Today because I couldn't go outside I decide to experiment with some settings at 5x magnification.
Here is one at f/7(all other settings were changed as necessary to get approximately the correct exposure)
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/01/2/LQ_769150.jpg
Image hosted by forum (769150) © davholla [SHARE LINK]
davholla
Gallery: 465 photos
Joined Nov 2014
Jan 10, 2016 13:18 |  #2
Here is one at f/16(all other settings were changed as necessary to get approximately the correct exposure). I think
a) I should have used a tripod to make the testing more comparable
b) That the difference is small
c) f/7 is slightly sharpter
i) Has anyone else done similar testing?
ii) If so what conclusions did you reach?
iii) For 5x magnification what do you use and how did you choose it?
This was all done on the Canon 7D MKII
BTW I did also do some testing on the 550D and Canon EF-S with f from 16-32 and I couldn't see much difference (this was at a much higher level of magnification half life size.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/01/2/LQ_769154.jpg
Image hosted by forum (769154) © davholla [SHARE LINK]
Archibald
You must be quackers!
Gallery: 789 photos
Post edited over 7 years ago by Archibald.
Jan 10, 2016 13:33 |  #3
At 5x, the effective aperture is much smaller than the nominal aperture. The very tiny aperture causes major diffraction softening.
Check the lens manual for the effective apertures. Sorry, I'm on my mobile now and can't look myself.
But to get sharp results at 5x, going by memory, you should be at around f/4.
Of course DOF is very thin at f/4, so you need to do focus stacking to get the DOF you need.
Shooting at 5x is technically difficult. :-)
I'm Ed. Migrating to Focus on Photography (https://focusonphotogr​aphy.community.forum/ (external link)) where I'm Archibald.
Archibald
Gallery: 789 photos
Jan 10, 2016 15:35 |  #4
Effective aperture for the 65mm lens, from the manual and some numbers calculated by me follow.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/01/2/LQ_769183.jpg
Image hosted by forum (769183) © Archibald [SHARE LINK]
The numbers in bold give a rough compromise aperture to stay below for good sharpness.
Good info on effective aperture of this lens is here.
http://pikespeakphoto.​com/tests/canonlens_mp​-e.html (external link)
davholla
Gallery: 465 photos
Joined Nov 2014
Jan 10, 2016 15:41 |  #5
Archibald wrote in post #17852838 (external link)
Hosted photo: posted by Archibald in
./showthread.php?p=178​52838&i=i108790156
forum: Macro
That is interesting so I should have tried f 3.6 at 5x? I will have to try that (sadly the little monster -my son - is being an insomniac so I can't now).
racketman
Gallery: 20 photos
Post edited over 7 years ago by racketman. (2 edits in all)
Jan 10, 2016 16:59 as a reply to  @ davholla's post |  #6
Obviously you will get next to no depth of field when using wide apertures for best resolution so you have to take multiple images at different focal planes and then combine them in stacking software to get the depth of field.
Toby
sorpa
Gallery: 28 photos
Jan 10, 2016 18:30 |  #7
Did you use some sort of focusing technique? Apart from having the lens mounted on tripod. Let alone some other solid surfaces. Because f/16 at 5x is freakingly dark. You see chit. The effective aperture formula is: effective f = (M+1)*f# where M is magnification and f# is the one actually used. That goes around f/96. Pitch dark.
LordV
Jan 11, 2016 00:56 |  #8
Many people have done comparisons - see below for one I did ages ago.
What you consider a good aperture to use is just a balance between DOF and diffraction softening and is a matter of personal choice.
I prefer fairly sharp shots so as commented above tend to try and keep the effective aperture between F22 and F32 over the magnification range of the MPE-65 when using a crop camera ie f11 at 1:1 going down to F5.6 at 5:1. You can shut down the aperture about 1 stop on these settings with a FF camera and get the same DOF/diffraction softness balance.
Brian V.
1623
x
2418
TOO LARGE!
EMBED PREVENTED, IMAGE TOO LARGE:
https://farm1.staticfl​ickr.com/76/229014482_​8a6d88ace0_o.jpg
Click here to see our image rules.
MPE-65 5:1 diffraction softening test (external link) by Brian Valentine (external link), on Flickr
Macro Hints and tips
davholla
Gallery: 465 photos
Joined Nov 2014
Jan 11, 2016 02:28 |  #9
lui-même wrote in post #17853095 (external link)
On my PC it is not that dark. I did these handheld, I have tried using a tripod (and for these could have). However many people don't use tripod successfully so I decided to try without.
(Also my camera once came off a tripod, hit my son who started shouting and broke the flash)
davholla
Gallery: 465 photos
Joined Nov 2014
Jan 11, 2016 02:30 |  #10
racketman wrote in post #17852940 (external link)
Definetly something I need to learn how to do, do you do it handheld or with a tripod/gorillapod?
Dalantech
Gallery: 525 photos
Best ofs: 5
Jan 11, 2016 03:56 |  #11
You can shoot hand held with a flash, but getting the flash close to the subject will help with specular highlights (better diffusion) and will keep the duration of the flash to a minimum (easier to freeze motion and get sharper images). Here's a shot at almost 5x and F16:
IMAGE: https://farm6.staticflickr.com/5708/20063022473_ece55df9ac_c.jpg
IMAGE LINK: https://flic.kr/p/wyUe​Az  (external link) Wool Carder Bee Portrait II (external link) by John Kimbler (external link), on Flickr
My Gallery (external link)
My Blog (external link)
Macro Tutorials (external link)
Snowyman
Gallery: 682 photos
Joined Oct 2011
Post edited over 7 years ago by Snowyman. (5 edits in all)
Jan 11, 2016 04:01 |  #12
It is most definitely a question of taste, desired result and compromise. Working in a studio with a tripod, lighting and an inert subject, a wide aperture and stacking is a no brainer.
As regards 5x mag and not being able to see your subject, the solution is a light or strategically mounted torch.
I prefer to hunt outdoors, hand held and if I paid too much attention to the numbers I'd have nothing to show for my effort! F/14, very nearly 4X magnification, effective aperture F/67:
IMAGE: http://pre01.deviantart.net/551f/th/pre/i/2015/231/c/8/img_1476_1_by_snomanda-d96apfl.jpg
Snowy's Gear
Deviant Art (external link)
500px (external link)
Dalantech
Gallery: 525 photos
Best ofs: 5
Jan 11, 2016 04:07 |  #13
Snowyman wrote in post #17853481 (external link)
I prefer to hunt outdoors, hand held and if I paid to much attention to the numbers I'd have nothing to show for my effort!
You and I have similar shooting styles, and like you if I pixel peeped I'd have a lot fewer images in my gallery ;)
Snowyman
Gallery: 682 photos
Joined Oct 2011
Post edited over 7 years ago by Snowyman. (2 edits in all)
Jan 11, 2016 04:09 |  #14
I wasn't quick enough composing my reply. :rolleyes:
Snowy's Gear
davholla
Gallery: 465 photos
Joined Nov 2014
Jan 11, 2016 04:19 as a reply to  @ Dalantech's post |  #15
Good photo, what is it holding onto a plant stem? When spring and summer return I will have to try getting up early to get insects.
I don't have any problems now with seeing the subject I have a little torch attached to the flash.
Thanks all for the replies.
I will try this
"Early morning shot while the critter was still trying to get it's metabolism going. I was holding on to the flower petal with my left index finger and thumb, and resting the lens on that same hand to keep everything steady."
next time I have a go.
A lot of my best photos have been when I have had the thing on my hand as it gives a better perspective (of course for somethings not possible).
3,282 views & 6 likes for this thread, 7 members have posted to it and it is followed by 3 members.
Canon MP-E question
2232 guests, 131 members online
