I have heard that most new camera batteries only get up to their full potential after a few cycles of use and recharge. I just got 2 new batteries in preperation for a spring vacation and I won't have time to take enough pictures to truly drain the battery the normal way.
Is there any problem you can think of by just leaving the camera on over night and let it drain the battery that way? If I do that a couple of times, the battery should be able to hold its maximum charge.
A couple issues I've already thought of:
1) Should I remove the CF card, any potential damage there?
2) Would it cause any damage to the camera's or lens's electronics?
3) Could image on the LCD be "burned-in" if I just left if there for many hours?
4) Is there really any significant difference between the charge of a brand-new battery and a broken-in one?
These questions and anything else you can think of would be helpful.
