silvermesa1 wrote in post #17858960
Anyone know of a reasonably priced double speedlight bracket that works well with the Elinchrom Deep Octa? I have two older Vivatar 285 speedlights that I have had for quite some time and also purchased the deep octa recently.
P.S. My original thought on purchasing the deep octa was to pair it up with a studio strobe but have not purchased that yet. I would like enable the use of it temporarily with a double speedlight bracket. I assume one speedlight might not fill it up sufficiently.
Heya,
Well, a single speedlite actually will handle it fine, up to the 48" size or so and below, just fine. It's more, how close it needs to be to subject that will determine how fine it is or not.
By adding a 2nd speedlite, you get 1 more stop of light, and a little more spread, but not much more spread. This is assuming you're zoomed back at 24mm or 35mm. Two speedlites are ideal if you need to get +1 stop of light but not at full 1/1 power, so that you can shoot at lower power, get more light, and have a faster recycle time, and to get a little more spread for a larger modifier (but really for 48" and below, you really don't need more speedlites for spread, one at 24mm is fine).
That said, I use two speedlites in a key modifier often (48" and 60" reflective umbrellas with covers, "brolly boxes"). I shoot them at lower power (1/4) for the recycle times and number of shots and for the spread at 24mm. I use a basic $25 bracket that allows two speedlites to gang up with an umbrella shaft. I use Yongnuo 560 III's so I don't need transmitters for each light, so ganging up lights for me is not a problem nor a chore, it just adds light.
For the Elinchrom, you need a speed ring that will support more lights, it was made mostly for a single light. The above linked add-on for an s-bracket will hold more speedlites internally in the octa for you.
Very best,
