Thread started 16 Jan 2016 (Saturday) 19:56
Macro Extension tube with AF : how to use best ?
CanonYouCan
Post edited over 5 years ago by CanonYouCan. (2 edits in all)
Jan 16, 2016 19:56 |  #1
I just bought this Macro Extension tube with AF : http://www.benl.ebay.b​e …geName=STRK%3AM​EBIDX%3AIT (external link)
With which of my lenses below would it work best ?
I just tried with my 24-70 and 17-40 but had to put my lens almost against the subject.
Would I start with all the rings so that the lens will be most far away from my camera ?
Sony A7 III | Metabones V | Canon 16-35 F4 L | Sigma 85 1.4 Art | 70-200 2.8L II
Lighting : Godox AD600B TTL + Godox V860II-S + X1T-S
Modifiers: 60cm Collapsible Silver Beautydish + grid | Godox 120cm Octagon softbox + grid + Speedlite Flash bender
Tripod: Vanguard Alta 253CT carbon
Jon
Joined Jun 2004
Jan 17, 2016 11:34 |  #2
First off, using it with a zoom lens is a recipe for insanity - the focus point will change as you zoom to adjust the framing.
Second, the longer the extension tube length you're using the closer you'll need to get to the subject to achieve focus (and the greater the magnification will be).
Start with the shortest (13 mm) tube on your 135 mm lens and see how much closer you'll get. Remember, by adding any tube to any lens you'll lose infinity focus. Then move to progressively more extension and see the differences. Just using the two longer tubes stacked with your 50 mm lens will get you to about life-size, and a 100 mm (or less) working distance, depending on the internal optics of the lens.
Jon
Cocker Spaniels
Bassat
"I am still in my underwear."
Joined Oct 2015
Jan 17, 2016 11:48 |  #3
I get 1:1 with 25mm ET and 18-55 STM at ~35mm, on a 70D. ETs work better (more magnification) on shorter lenses. If you can't get focus at all (think 16mm on 16-35 w/31mm ET) your focus point may actually be inside the lens.
CanonYouCan
Jan 17, 2016 18:24 |  #4
In past I had a Sigma 150 2.8 Macro but sold it, as I realised and read I need a 5:1 magnification for the pics you sometimes see of gigantic insects.
This is probably not possible with this extension tube and one of my lenses ? :)
I'm not going to buy a macro again as it was just for testing...
Jon
Joined Jun 2004
Jan 17, 2016 19:41 |  #5
No, probably not. You can get better than 1:1 with the 50 and all three tubes, but unless you've stunned or killed the insect, you'll have a hard time getting close without scaring it off.
Jon
Cocker Spaniels
3,342 views & 0 likes for this thread
Latest registered member is rush1981
632 guests, 350 members online
