So I got tired of endless paperwork at work this week and started to design a slider, don't really need one but have wanted to try designing one for a while now. I had two concepts I wanted to design and this is the first.
The tubes are Carbon Fiber and can be made to any length, this design is using 4' lengths. The ends would stay the same no matter the length of the tubes. You would just have to change the length of the drive belt along with the tubes. The drive belt is not shown in these images, neither is a good amount of the nuts and bolts. The motor will have a controller (faster/slower forward/backwards) and built in battery that can be hand held or set down off to the side as to not disturber the slider.
The one downside to this design is I can not mount it on my tripod, so I would always have to find a place to set it.
Upside, should be very light, can run up inclines (not down) and could have a second plate put on the bottom and run it upside down.
If you see any improvements please do let me know. The ends and plate will be made out of black delrin (or something close to it), its easy to machine on the CNC.
All told this design would run about $400 At that price it might be better to get one that has a built in start stop timer for doing low light time lapse, as this will be a continuous, a very slow continuous but non the less could result is images that are not tack sharp as light gets lower.
