Thread started 24 Jan 2016 (Sunday) 16:13
Head shot with 16-35 lens?
trailguy
Jan 24, 2016 16:13 |  #1
With a D750 I have only the 16 - 35 (f4) lens at this point. Very good lens, but obviously not the best lens for portraits.
I will shoot about 20 individual head-shoulder shots of employees in an office. I'm thinking to be about 10 ft. away, with a dome on the SB-700 flash angled up 45 degrees. Lens F4, shutter 125.
BUT I'd appreciate any advice here.
The camera does great and gives some ability to fix things in LR, but I want a good setup.
Perfectionism is the highest form of self-abuse
"Best wide-angle lens? Two steps backward"
Ernst Hass 1952
LV ­ Moose
Moose gets blamed for everything.
Gallery: 223 photos
Jan 24, 2016 16:26 |  #2
35 is pretty wide on a FF for a head-shot. No chance of borrowing/renting something longer?
Moose
Gear... Flickr (external link)...Flickr 2 (external link)...
Macro (external link)...Hummingbirds (external link)
Aircraft (external link)
mike_d
Jan 24, 2016 16:31 |  #3
Set to 35mm, stand back, keep them in center of frame, crop.
neacail
Gallery: 43 photos
Joined Dec 2013
Jan 24, 2016 16:33 |  #4
I don't want to come across as being harsh, but here goes anyway . . . 35mm is terribly unflattering for portraits.
Have a look at the image at this link:
http://www.lesjones.co​m …stepheneastwood​-tile1.jpg (external link)
Personally, I like to use 100mm or longer. But for people who have nice facial structure (and smallish noses) 50mm works okay. There is no way I would even consider using 35mm for serious headshots.
I think you really need a longer lens. I would strongly advise against doing this with the your 16-35. It probably isn't worth the embarrassment that will most likely ensue.
Shelley
Image Editing Okay
neacail
Gallery: 43 photos
Joined Dec 2013
Jan 24, 2016 16:34 |  #5
mike_d wrote in post #17871186 (external link)
How far would one have to stand back to make this work? I'm genuinely interested . . . as I didn't think there was anyway 35mm could ever work well.
Shelley
Image Editing Okay
mike_d
Post edited over 7 years ago by mike_d.
Jan 24, 2016 16:40 |  #6
neacail wrote in post #17871191 (external link)
I'm not sure, exactly. What you're trying to avoid is filling the frame which will do two things: Exaggerate facial proportions (ie big nose) and stretch things toward the corners. Standing back and deliberately NOT trying to fill the frame will reduce these effects. The final output resolution needed will also be a factor. The lower the final resolution needed, the more you can crop. You're not going to replace an 85mm with this technique, just reduce the downsides of shooting people with a wide angle lens.
neacail
Gallery: 43 photos
Joined Dec 2013
Jan 24, 2016 17:00 as a reply to  @ mike_d's post |  #7
Hmmm. Check this out:
https://cdn.photograph​ylife.com …ength-Face-Distortion.jpg (external link)
I would like to see a sample where the subject was looking directly at the camera . . . but in the photo taken three metres away the subject's proportions are much, much better than the one metre shot.
I tried to convince my standard "experiment" model to let me take some shots of him to test this out, but he's more interested in his computer game at this moment.
My revised advice to the trailguy . . . following mike_d's advice might get you some good headshots.
If I were you, I'd take a lot of test shots before head shot day: to establish the best distance to use your 35mm lens at and to see how well your flash bounces at the different distances.
Shelley
Image Editing Okay
gonzogolf
dumb remark memorialized
Gallery: 559 photos
Jan 24, 2016 17:16 |  #8
Perspective distortion is based on distance, not the lens. Not that the lens doesn't have a practical effect for cropping a 35 to match an 85 would mean standing back amd wating pixels.
trailguy
Jan 24, 2016 18:26 as a reply to  @ gonzogolf's post |  #9
OK, the words and link pictures have scared me. Which should I borrow? Sounds like an 85mm would work ok.?
I've taken many various shots of people, using numerous lenses and never noticed noticeable distortion, but when asked to take a bunch of portrait types for a business use, it makes me a bit concerned about making them look well.
I love using a FF, but I do have a Canon 40D and an L series 70 - 200 F4, so perhaps I should simply charge it up and use it.
Ernst Hass 1952
LV ­ Moose
Gallery: 223 photos
Post edited over 7 years ago by LV Moose.
Jan 24, 2016 18:33 as a reply to  @ trailguy's post |  #10
I just dusted off my 40D a few days ago, after using my 5DIII exclusively for over a year. Still a very capable camera, especially with something like a 70-200L attached.
Might be better than going the 16-35 route. Experiment first, just to see what works better for you.
But, if you have the option of borrowing an 85 or a 100 and using your FF, that would be my personal preference if I was in your shoes.
Moose
gonzogolf
Gallery: 559 photos
Jan 24, 2016 18:36 |  #11
trailguy wrote in post #17871317 (external link)
The 70-200 f4 makes a fine portrait lens, might be a little long on the 40D if you are working indoors. You might consider renting a portrait lens for your nikon, 85 is a great focal length no significant distortion although my preference is 135 on full frame as I like the longer lens but again inside it can be a bit long.
windpig
Chopped liver
Jan 24, 2016 18:36 |  #12
85 on a crop would be a great head shot FL.
Go ahead, spin the wheel.
neacail
Gallery: 43 photos
Joined Dec 2013
Jan 24, 2016 18:37 as a reply to  @ LV Moose's post |  #13
I regularly use a 70D and a 70-200 2.8 II . . . I'm thinking that your 40D and 70-200 might be a nice option.
But, I'd still test everything first. If you can't find a model to work with, you could try doing self-portraits to see what gives you the results you're looking for.
Shelley
Image Editing Okay
gonzogolf
Gallery: 559 photos
Jan 24, 2016 18:39 |  #14
This migjt be a good occasion to treat yourself to a 50 1.8 stm for the 40D.
windpig
Chopped liver
Post edited over 7 years ago by windpig.
Jan 24, 2016 18:59 |  #15
gonzogolf wrote in post #17871334 (external link)
Yup
Here's the perspective from 8 feet away. (this is an 85 on a 5dIII)
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/01/4/LQ_771876.jpg
Image hosted by forum (771876) © windpig [SHARE LINK]
7,759 views & 5 likes for this thread, 11 members have posted to it and it is followed by 7 members.
1228 guests, 149 members online
