Thread started 24 Jan 2016 (Sunday) 16:33
YN600EX-RT Questions
rebop
Jan 24, 2016 16:33 |  #1
The easy one? How can you tell what version of firmware is installed? I can find no menu option or mention in the User Guide.
Second, I di a shoot with one in a softbox yesterday. I sear after 50 or 60 shots, batteries still fine, it changed exposure and dropped 2/3rd to a stop. And I was ETTL. No idea what or how this happened, but needed to readjust FEC to continue.
Any ideas?
I'm hoping maybe a firmware update fixes this. I have three YN600's but only was using on ewhen this happened.
Thanks.
~Bob
I'm Bob and I'm an L-coholic
R3 - RF 14-35
L - RF 24-70 L - RF 24-105 L - RF Thrifty-Nifty 50
RF 70-200 2.8 L - EF 70-300 L - EF 100 2.8 L Macro
msowsun
"approx 8mm"
Gallery: 18 photos
Jan 24, 2016 16:49 |  #2
You can check the firmware with custom function 27.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/01/4/LQ_771859.jpg
Image hosted by forum (771859) © msowsun [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/01/4/LQ_771860.jpg
Image hosted by forum (771860) © msowsun [SHARE LINK]
rebop
Jan 24, 2016 16:57 as a reply to  @ msowsun's post |  #3
Thanks so much. Search user Guide did not find "firmware" . I would have never found this :)
R3 - RF 14-35
PhilF
Jan 24, 2016 18:58 |  #4
I have one and I hate it when it turns off automatically.(especia​lly when its used as a hair light) Is there anyway to turn off the sleep mode or alter the time ?
http://philfernandezph​otography.com (external link)
http://www.philfashion​photography.com (external link)
https://www.instagram.​com/philfernimagery/ (external link)
https://www.facebook.c​om/philfphotography (external link)
CliveyBoy
R.I.P.      He will be missed
Joined Nov 2005
Jan 24, 2016 19:35 |  #5
C.Fn 01 Auto Power Off = Enable/Disabled, as per post #2 above  :p
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
PhilF
Jan 25, 2016 01:25 |  #6
CliveyBoy wrote in post #17871389 (external link)
thanks.
jsinon
Gallery: 6 photos
Jan 25, 2016 06:24 |  #7
rebop wrote in post #17871190 (external link)
Any ideas?
Thanks.
~Bob
Might be because you were using ETTL. ETTL can work great or it can be very erratic. Try manual next time.
Fuji X-T2, Fuji X-Pro1, XF18-55, XF10-24, XF50-140
http://www.jeffsinon.c​om/ (external link)
http://jeffsinonphotog​raphy.wordpress.com/ (external link)
rebop
Jan 25, 2016 14:53 as a reply to  @ jsinon's post |  #8
Thanks. I have used both without any issue. And this was maybe 50-60 shots before it abruptly changed so I sense something else happened.
~Bob
R3 - RF 14-35
rebop
Jan 27, 2016 22:02 as a reply to  @ rebop's post |  #9
BTW, I emailed BOTH Yong Nuo Hong Kong and EachShot (vendor) with questions on Sunday and neither have had the courtesy to reply. I will take that into consideration next time I purchase.
~Bob
R3 - RF 14-35
CliveyBoy
Joined Nov 2005
Jan 28, 2016 00:20 |  #10
It is how Canon have programmed their E-TTL cameras. NEVEC, AFR, ambient/fill/main lighting. Look at your EXIF data and check against the table. see
https://photography-on-the.net …showthread.php?​p=17710977
jsinon
Gallery: 6 photos
Post edited over 7 years ago by jsinon.
Jan 28, 2016 04:11 as a reply to  @ rebop's post |  #11
I'm not sure where you're located but Tim Payne, the U.S. distributor for Yongnuo has about the best customer service I've ever experienced. You can contact him through his website, http://yongnuousa.net (external link) or through his learning OCF Facebook group, https://www.facebook.c​om …s/speedlightfun​damentals/ (external link) I do know that there has been a new firmware released just recently too. The only downside for me is now I have to find someone with a PC so I can update mine.
rebop
Jan 28, 2016 12:08 as a reply to  @ jsinon's post |  #12
Thanks. Will investigate both links.
~Bob
R3 - RF 14-35
PhilF
Feb 02, 2016 22:22 |  #13
Big problem today at a job with a YN600EXRT .
I was using it as a kicker and the YN600EXRT kept on staying on ETTL mode and won't change to M mode even if I press the mode button. I tried turning it off and tried changing it to M model but still it goes back to ETTL mode. Is there something I am missing?
I was using YN622C mounted on the YN600EXRT and another UN622C on my camera. I was shooting at Manual model.
Is there something I missed?
Phil ­ V
Joined Jan 2005
Feb 03, 2016 00:32 |  #14
PhilF wrote in post #17883872 (external link)
The flash mode in the camera menu can override the wireless settings.
website: South Yorkshire Wedding photographer in Doncaster (external link)
Twitter (external link)Facebook (external link)
absplastic
Gallery: 40 photos
Post edited over 7 years ago by absplastic. (3 edits in all)
Feb 03, 2016 02:24 |  #15
Also, as I noted in the Rovelight thread, having E-TTL on in any way will make hypersync not work with the 622 + Rovelight 600 combo. If your camera body (or master speedlite/controller) is making the 622 go into E-TTL wireless mode, the timing is thrown off and hypersync with PC-cord-connected strobes will not work. What you've discovered with the YN600ex-rt I think is a clue to your other problem with not getting the Rovelight to work alongside the speedlites at HSS shutter speeds.
Off camera YN600ex-rt and Canon 600ex-rt both can't be changed from E-TTL to manual if they are wireless slaves. As soon as the camera body signals them again, they will flip right back to E-TTL if E-TTL flash mode is what is set on the master, either through the master flash/controller itself, or through the camera body's External Speedlite Control menu settings.
When you have an off-camera 600ex-rt set as a SLAVE, the master will override the mode (E-TTL, M, Multi) and the Power Level, and the Sync setting (HSS/1st/2nd) as soon as you take the next photo! Only things like zoom and custom functions will stick, nothing that the master sends values for.
5DSR, 6D, 16-35/4L IS, 85L II, 100L macro, Sigma 150-600C
SL1, 10-18 STM, 18-55 STM, 40 STM, 50 STM
My (mostly) Fashion and Portraiture Instagram (external link)
flickr (external link) (NSFW)
5,427 views & 1 like for this thread, 7 members have posted to it and it is followed by 6 members.
1503 guests, 130 members online
