Plain & simple, is the IS worth the extra cash? I'm pretty stable and steady when I shoot...I have no problem shooting at 1/10 with no movement. Does that matter with a lens that long?
Thanks,
~Ace
AceandDeuce Cream of the Crop More info | Jan 28, 2016 20:47 | #1 Plain & simple, is the IS worth the extra cash? I'm pretty stable and steady when I shoot...I have no problem shooting at 1/10 with no movement. Does that matter with a lens that long?
05Xrunner Goldmember, Flipflopper. More info | Jan 28, 2016 20:52 | #2 i assume your contemplating between the canon 70-200 2.8 and the 2.8 IS II My gear
snegron Senior Member 503 posts Likes: 142 Joined Jul 2012 Location: Florida More info | Jan 28, 2016 20:55 | #3 I purchased a 70-200mm 28 non IS a few weeks ago. Had the same dillema between spending more for IS or not. I am halpy I got the non-IS version for less money.
Snydremark my very own Lightrules moment More info | Jan 28, 2016 20:59 | #4 The difference between the optics in the old, non-IS version and the new IS II is pretty large, regardless of the IS. I'd, personally, consider it worth it just for the optics upgrade alone. However, if you don't feel the need for IS, or if you just really don't feel like you can justify the spend for the newer lens, the latest Tamron 70-200 VC is widely regarded as "close enough" for most people's purposes to the Canon MkII but for less money and might be a good option for you to consider. - Eric S.: My Birds/Wildlife
As stated above the difference in the newer IS lens is far more than the IS - it is simply a sharper lens. Outside of that on a Canon body IS makes a considerable difference as you approach 200MM.
Jan 28, 2016 21:37 | #6 Thanks, guys! I did see that the newer IS one has 5 lens elements as opposed to 4 on the non-IS model, but I wasn't sure how much of a difference that made in image quality. I should add that I am looking to put this on a Best Buy card, so that eliminates buying a used one. I was also looking at he Tamron, but I'm trying to stick with Canon lenses...as stupid as that sounds. I'm looking to use this for a variety of situations, including a lot of indoor high school sports, like wrestling, basketball, etc...would the IS version perform better for indoor/low-light situations?
Snydremark my very own Lightrules moment More info Post edited over 7 years ago by Snydremark. | Jan 28, 2016 21:41 | #7 If you have the funds, the 70-200 MkII is just an astonishing lens. I bought it as a toy when it first came out (maybe used a dozen times, total, since I picked it up) and I still feel like I got my money's worth on the chances that I do use it. I mostly shoot much longer, even with a crop body, so it doesn't come out often; but I never stress about the results when I need to pull it out. - Eric S.: My Birds/Wildlife
Jan 28, 2016 21:53 | #8 Unless you shoot a lot of sports IMO the IS is worth the money. Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Jan 28, 2016 21:54 | #9 One last question, and this one is HUGE for me...I shoot on scene for several fire departments. I noticed that the mkII is water resistant, is the non-IS? I shot in a blizzard last week and my camera and 24-105 were completely wet and snow-covered. I've also seen a lot of water from over-spray, so water resistance is a must! IMAGE LINK: https://flic.kr/p/CRtXc6
Jan 28, 2016 22:04 | #10 I don't believe the non IS model is as water resistant. Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
05Xrunner Goldmember, Flipflopper. More info | Jan 28, 2016 22:38 | #11 the non IS is not weather sealed..the IS models are. My gear
gonzogolf dumb remark memorialized More info | Jan 28, 2016 23:03 | #12 Short answer, YES. The difference between 1/200 handheld and 1/30 is huge. It makes the lens so much more usable.
Jan 29, 2016 04:22 | #13 Thanks, guys! Looks like it will be the IS version for sure.
clipper_from_oz Goldmember More info Post edited over 7 years ago by clipper_from_oz. | Jan 29, 2016 04:47 | #14 Ace and Deuce wrote in post #17877011 Plain & simple, is the IS worth the extra cash? I'm pretty stable and steady when I shoot...I have no problem shooting at 1/10 with no movement. Does that matter with a lens that long? Thanks, ~Ace It matters heaps if you are going to use a 5DSR. Without it the camera would be almost permanantly sitting on a Tripod when using the 200mm end Clipper
MatthewK Cream of the Crop More info | Jan 29, 2016 07:11 | #15 Ace and Deuce wrote in post #17877060 Thanks, guys! I did see that the newer IS one has 5 lens elements as opposed to 4 on the non-IS model, but I wasn't sure how much of a difference that made in image quality. I should add that I am looking to put this on a Best Buy card, so that eliminates buying a used one. I was also looking at he Tamron, but I'm trying to stick with Canon lenses...as stupid as that sounds. I'm looking to use this for a variety of situations, including a lot of indoor high school sports, like wrestling, basketball, etc...would the IS version perform better for indoor/low-light situations? No, IS won't give you any advantage in these situations because IS doesn't freeze action. The f/2.8 aperture will help, but if indoor sports is your requirement, I'd look at a faster prime like the 85mm f/1.8 or the 135L f/2.0.
| Latest registered member is semonsters 901 guests, 118 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
