Who does it?
Is it better that using Bridge, then selecting the photos you want?
I have been using bridge and found that I am not editing a lot of the photos that I am taking.
ThomasDidymus Member More info | Jan 30, 2016 21:41 | #1 Who does it? God created the beauty. My camera and I are a witness..
Jan 30, 2016 22:21 | #2 I use lightroom almost exclusively for my photos. I Import, cull, organize, and edit, all in lightroom.
Archibald You must be quackers! More info | Jan 30, 2016 22:36 | #3 I don't import directly into LR. I used to, from time to time, but quite often found it to be harder than it should be. The reason is that sometimes I have cards from two or three cameras that need to go into one folder (and sometimes more than one folder). I use LR's default folder naming, but append a description that describes the event or place. All this is hard to accomplish in LR. Canon R5 and R7, assorted Canon lenses, Sony RX100, Pentax Spotmatic F
Reiep Senior Member More info | Feb 01, 2016 05:46 | #4 I directly import in Lr. This way I can select the photos I want, tag them, rename them (usually with the date I took the photo), and apply a default preset of mine at once. It goes very smoothly this way, and by applying a preset of mine during import I sometimes just have to check exposure and that all, my photos are done. Website
bpalermini Goldmember More info | Feb 03, 2016 22:17 | #5 I import via Lightroom now. It took me a year or two to figure it out, I had been copying the files via the OS and synchronizing my Lightroom view of my photos folder. That worked but I found that I had been missing a number of features available via Lightroom import like keyboarding, preset application, and others. Bob
DanMarchant Do people actually believe in the Title Fairy? 5,635 posts Gallery: 19 photos Likes: 2058 Joined Oct 2011 Location: Where I'm from is unimportant, it's where I'm going that counts. More info | Feb 04, 2016 01:19 | #6 I import directly into LR from a card reader. I have set up the Import dialogue to apply different presets (I have one for Rugby, one for Street, one for Black and white) and also apply different default Keywords. It is also set to apply a colour label (Green) to all the RAW files as they are imported. Then if I later create a virtual copy I change the label on that to Yellow. If I create a TIFF and bring that back into LR it gets a blue label. I don't generally bother to bring JPEGs back into the catalog (I treat them as disposable files and just delete after posting to the web) but if I do they are red. Dan Marchant
TheLimey Senior Member More info | Feb 04, 2016 04:21 | #7 i use Scott Kelbys way exturnal hardrive then lightroom 7D,20D,1V.
Feb 04, 2016 10:21 | #8 Dan Marchant wrote in post #17885269 I import directly into LR from a card reader. I have set up the Import dialogue to apply different presets (I have one for Rugby, one for Street, one for Black and white) and also apply different default Keywords.
http://www.avidchick.com
| Latest registered member is semonsters 1467 guests, 130 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
