Thread started 01 Feb 2016 (Monday) 13:38
Which 1.4x TC to pair with the 100-400 MkII
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Feb 01, 2016 13:38 |  #1
I'm looking into, hopefully, upgrading to the 100-400 MkII sometime this year and am expecting to add a 1.4 to it since the 7DII now supports F/8 AF. I know that the long-standing advice for 1.4x was to go with the Kenko over the Canon part, but I'm curious if that wisdom still holds true with the introduction of the MkIII versions of Canon's TCs.
What say you all?
Thanks,
-E
LV ­ Moose
Moose gets blamed for everything.
Gallery: 223 photos
Post edited over 7 years ago by LV Moose. (2 edits in all)
Feb 01, 2016 13:43 |  #2
I'd go with the Canon 1.4X III.
The Kenko has served me well with other lenses, but I hear the Canon 1.4X III and the 100-400mkII are a match made in heaven.
Moose
Gear... Flickr (external link)...Flickr 2 (external link)...
Macro (external link)...Hummingbirds (external link)
Aircraft (external link)
Trvlr323
Feb 01, 2016 13:49 |  #3
I had the 1.4x II before I bought the 100-400 II. I bought the 100-400 II and the 1.4x III at the same time but for the life of me I couldn't tell the difference between the 1.4x II and the 1.4x III. I ended up exchanging the 1.4x III for some other gear I wanted.
Sometimes not taking a photograph can be as problematic as taking one. - Alex Webb
2loose
Gallery: 227 photos
Joined Apr 2011
Feb 01, 2016 14:04 |  #4
Hey Eric,
It's so obvious, get Canon 1.4 TC III. Don't slap your 1800 bucks lens with cheapo TC and not getting the maximum result. I've been using this combo for BIF and very happy with the results.
Like I said in the other thread, when you buy $$$ Armani suit, you don't buy the shoes from Payless store. Yes it will work, but c'mon hehehe.
Besides, you can get the used or refurb one for 300 or less.
Body:Canon EOS-5D Mark IV, Fuji X-T3, Samsung Galaxy S21 Ultra.
Lenses: Canon 24mm TS-E f3.5L II, Canon EF 400mm f/4 DO IS II USM, Canon TC 1.4X III, FUJINON XF50-140mmF2.8.
alliben
Gallery: 42 photos
Joined Apr 2011
Feb 01, 2016 14:24 |  #5
Feel free to correct me, but I thought I read somewhere that optically, the II and III were identical. The difference was something, perhaps in the electronics, that was useful only for the Canon super-teles.
j-p
LV ­ Moose
Gallery: 223 photos
Feb 01, 2016 14:33 |  #6
From the-Digital-Picture.com review: Link (external link)
"The image quality differences most easily noticed between the 1.4x II and the 1.4x III are:
The 1.4x III has less barrel distortion than the 1.4x II. This makes the center-of-the-frame details slightly smaller in a comparison. This difference will be most noticeable in the top crop shown in the ISO 12233 chart tool.
Anomalous dispersion glass elements are used in the Series III extenders to reduce chromatic aberration and increase resolution and contrast. The CA difference between the II and III is quite noticeable – pay close attention to this difference in the bottom ISO 12233 crops.
Less noticeable are the resolution and contrast differences, but some comparison examples do show improvements.
The Series III extender includes some durability improvements.
The lens mount pin and lens mount stopper pin are improved for higher endurance and there are now 7 (instead of 4) screws holding the rear lens mount to the body. "
Supposedly better AF on Super-Telephotos as well.
Moose
Tapeman
Sliced Bread
Joined Jan 2004
Feb 01, 2016 15:17 |  #7
I own both and the differences are minimal.
Performance on the MKII lenses is touted to be better.
The advantages of the MKIII may become more noticeable on newer (future) lenses as well.
I would bite the bullet and spring for Canon's latest version.
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
Snydremark
Gallery: 66 photos
Feb 01, 2016 18:23 |  #8
Thank you, All! That is basically what I was suspecting, but wanted to confirm; it'll be a little bit before the trigger gets pulled and hopefully I can catch a refurb deal when the time comes.
alliben
Gallery: 42 photos
Joined Apr 2011
Feb 01, 2016 18:41 |  #9
alliben wrote in post #17881841 (external link)
j-p
I had to see where that thought came from. Here's something from another forum,
"I emailed Chuck Westfall with this very question last January. Here is his reply:
As of now, I have not had the time to compare the image quality of the new 100-400 version II with 1.4X III vs. 1.4X II. However, our information from Canon Inc. in Japan does not indicate any special optical advantage for either version of the EF Extenders when used with EF zoom lenses. In fact, the only instance in which the Type III Extenders are stated to be a better optical match than earlier models occurs when the Type III Extenders are used with the IS II prime lenses from 300mm to 600mm. Based on that, plus my personal experience with the EF 1.4X II and III on other EF zoom lenses such as the 70-200/2.8L IS II, I wouldn't expect any significant difference in image quality for either of those extenders when used with the new EF 100-400mm IS II lens.
If you hear anything different, please let me know.
Best Regards,
Chuck Westfall
Advisor, Technical Information
ITCG Prof Bus Strategy Plan Division
I ended up trading my 1.4x2 for the 1.4x3 using the proceeds from used lens sales. Can't say I see any real difference on the 100-400II, just taking Brian's TDP 70-200 II comparison as gospel. He also compared the two extenders on the 100-400 v1 without any discernible difference. I think the lens, sensor density, and shooting circumstances have to be perfect to detect a difference. Tough call as to whether its worth it.
I think it would be wonderful if someone did a side by side with the two extenders and posted the results."
Archibald
You must be quackers!
Gallery: 789 photos
Feb 01, 2016 18:43 |  #10
I have the Canon 1.4x III and think it gets great IQ. However, the TC slows down the AF, so that doing BIF with the TC on the 100-400 II is difficult. In fact I have given up trying. The 7D2 has great cropability, so as an alternative to the TC, consider cropping.
I tried to do some tests some time back to compare the TC with cropping, but the results were indeterminate. What they seemed to show was that if you are hand-holding your rig, then there is no significant difference. I thought about repeating the tests on a tripod. But I hardly ever use a tripod - so the results would not be that useful to me in practice.
I'm Ed. Migrating to Focus on Photography (https://focusonphotogr​aphy.community.forum/ (external link)) where I'm Archibald.
Snydremark
Gallery: 66 photos
Feb 01, 2016 19:04 |  #11
Archibald wrote in post #17882189 (external link)
Yeah, I don't shoot from tripod either, so that's not a real solution for me, either (but I don't do a ton of BIF anyway). My presumption is that given the AF speed of the newer model, the hit from using the TC will be minimal enough to keep it on par with the current lens.
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
Feb 06, 2016 09:24 |  #12
LV Moose wrote in post #17881853 (external link)
I noticed CA on my 1.4 II and I then I found that article that confirmed it wen I was researching the 1.4 III. I bought it and sold my 1.4 II and 2X II.
Image Editing OK
digital ­ paradise
Gallery: 157 photos
Feb 06, 2016 09:27 |  #13
Same lens and I have tried it successfully for BIF but never use it for that. I lose too many fun focusing options. Here it is on my 1.4 III which I had to MFA to +14 for whatever reason. It is +3 at 400 without the TC.
IMAGE: http://i33.photobucket.com/albums/d74/Zenon1/Costa%20Rica/this-one_zps8fhfrivc.jpg~original
Image Editing OK
digital ­ paradise
Gallery: 157 photos
Feb 06, 2016 09:29 |  #14
Snydremark wrote in post #17882233 (external link)
I would use it more on tripod if I had a gamble head and the conditions were right. One day I'll invest in the head but not until I go 500mm or more with a prime.
Image Editing OK
Leigh
Joined Apr 2003
Feb 06, 2016 12:50 |  #15
I tried a Used Canon 1.4ll from Adorama, & though it worked quite well, I returned it due to cosmetic 'mars", & bought a 1.4lll.
I think they both work equally well, though the lll has a better build quality, and I can certainly attest to it's Image quality with this lens.
The only other consideration with the Canon's, is if in the future you get one of the primes that communicate with the TC, you'll need the 1.4lll
Leigh
6,629 views & 2 likes for this thread, 13 members have posted to it and it is followed by 7 members.
1202 guests, 120 members online
