Thread started 01 Feb 2016 (Monday) 21:22
New Phanteks Evolv ATX case arrived, lovely quality but 2 of the Motherboard mounting posts are diff
Submariner
Joined May 2012
Feb 01, 2016 21:22 |  #1
Very pleased withthe case beautiful build quality, with solid 3mm thick side panels and top. Fabulous engineering for the price.
I think for £119 its really 12/10 value wise. The additional screws are very poor quality though, but the actual case is stunning quality, its as though someone put in the wrong acessory box, ?
I did notice that 2 of the 9 pre-installed Motherboard mounting posts looked different ?? Instead of a 6mm hexagonal post with a square end , these 2 have a sort of shoulder , admittedly they do have a spare 6mm long one, in the nice compartmentalised plasic box with all the screws.
These 2 different ones are both in the middle position, one on the top row of 3. And the other differently shaped one, again in the middle - but in the middle row. All the 3 bottom row ones are the same squared ended type and are 6mm high.
As these 2 looked longer, I measured them - and they are 7.05mm high i.e. Just over a mm longer and not squared off but seem to have a sort of sloping "shoulder"?
Is it normal on an ATX case that 2 mounting points are longer?
For a novice it seemed weird - as I have assumed the back of the mother board would be flat.?? So one would want the mouNting posts all to be the same height to make sure the MB is not bent as one screws in the secuRing 3mm screws.
I can't check the MB yet, as it is due to arrive on Wednesday with all the other stuff.
Any ideas? Should I be getting some replacement mountiing posts from Phantek?
BTW the Asus Hyper PCIe to M.2 pcie card arrived today - looks very well made, great quality.
Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
Kolor-Pikker
Post edited over 7 years ago by Kolor-Pikker.
Feb 02, 2016 02:22 |  #2
The center standoff is almost always a "guide", meaning that you don't have to screw it in, it'll just protrude through the motherboard so that when you are placing the board into the case, you don't have to fiddle with alignment.
It seems that Phanteks decided to set two guides so that both alignment and rotation are set for you while screwing it in, and the spare post is for the top row in case you want to secure the board a little better. Maybe if you're going to be using one of those big 1kg air coolers like the D15 or R1 Ultimate.
5DmkII | 24-70 f/2.8L II | Pentax 645Z | 55/2.8 SDM | 120/4 Macro | 150/2.8 IF
I acquired an expensive camera so I can hang out in forums, annoy wedding photographers during formals and look down on P&S users... all the while telling people it's the photographer, not the camera.
joeseph
"smells like turd"
Gallery: 264 photos
Joined Jan 2004
Feb 02, 2016 02:23 |  #3
can't picture the problem from the description sorry...
TF posting: here :-)
Submariner
Joined May 2012
Feb 14, 2016 09:51 |  #4
Got 2 normal ones from Overclockers, and bought 2x 30mm stainless grub screws . Used them as a guide and then removed them and replaced with normal motherboard screws.
So sorted thanks for input.
1,985 views & 1 like for this thread, 3 members have posted to it.
1277 guests, 136 members online
