Thread started 02 Feb 2016 (Tuesday) 06:49
1DX II review
DarthVader
There is no such thing as Title Fairy ever
Feb 02, 2016 06:49 |  #1
http://www.andyrouse.c​o.uk/index.php?b=1 (external link)
Nikon/Fuji.
Gear is important but skills are very important :)
Mathmans
Joined Apr 2014
Feb 02, 2016 08:02 |  #2
Outstanding. ISO 10.000 image is so clean.
Well, let's wait for some other reviews and RAW samples before we start a mass hysteria.
My photos:
https://www.flickr.com​/photos/149610703@N05/ (external link)
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Feb 02, 2016 08:08 |  #3
Typical review, just glowing this and that and some web-sized images that look great, but none of the processing revealed on how those images turned out that way.
I want to see a torture test by someone who's not sponsored to give a glowing representation of a product.
I want to see under-exposed ISO 51,200, and see the shadow lifting and how the colors and detail respond.
I want to see exposure at ISO 100, for only highlights, and then raise shadows in post.
Very best,
umphotography
grabbing their Johnson
Gallery: 21 photos
Feb 02, 2016 08:36 |  #4
Darthvadar
exactly what i needed to see. Holy smokes look at that 32000 ISO Image...look at the 10000 ISO image......AWESOME
Mike
www.umphotography.com (external link)
Facebook (external link)
umphotography
Gallery: 21 photos
Post edited over 7 years ago by umphotography.
Feb 02, 2016 08:43 |  #5
Jeff got his hands on one last weekend.....2 stops over a 5D3....take a look at some of those wedding images.....impressive for low light work......https://www.facebook.c​om (external link) ...506625567?hc_locati​on=u
Mike
sploo
premature adulation
Joined Nov 2011
Feb 02, 2016 08:46 |  #6
MalVeauX wrote in post #17882844 (external link)
Very best,
Indeed. I particularly like "One thing that is noticeable is the incredible lack of noise in the shadows, something that has always plagued DSLRs". Dude, I think you missed "made by Canon" from the end of that sentence.
Still, that article is the second reference I've seen to significant high ISO improvements, and the third to improved shadow noise. Here's hoping the raw files back that up (at least for the shadow noise) and that it's trickle down tech for Canon's future (cheaper) bodies.
It also occurs to me that (on paper at least) there isn't a massive difference between the AF on the Mk I and Mk II. Perhaps that means a 5D4 will get most of the Mk II's AF system (like the 5D3 and Mk I). That would be nice - especially combined with a sensor with improved shadow noise/DR.
Camera, some lenses, too little time, too little talent
sploo
premature adulation
Joined Nov 2011
Feb 02, 2016 08:49 |  #7
umphotography wrote in post #17882871 (external link)
Darthvadar
Surely they're way too low res to make a judgement (unless there's some hires versions I haven't spotted)?
Until we see independent reviewers compare Mk I raws against Mk II raws we don't really know just how much of a difference there is, whether the difference is mostly the jpeg engine, and whether (if it is the jpeg engine) it's just noise reduction that some may find too aggressive (i.e. too aggressive when set to a level that meets the ISO improvement claims).
DarthVader
Feb 02, 2016 09:51 |  #8
Hoping this is the cause of his statement:
http://www.digitalcame​raworld.com …-ii-hands-on-review/#null (external link)
" The EOS-1D X Mark II is designed for high-speed shooting and low-light performance, and you can only achieve this with more modest pixel counts. Many sports take place in less than perfect lighting, and Canon’s new sensor has an important innovation. The A/D converter circuitry, which translates captured light values into digital data, has now been integrated with the sensor itself. This shortens the signal path and reduces image noise – not just at higher ISOs but also further down the ISO range. This extends from ISO 100-51,200, which is the same as the previous model, but with expansion settings from ISO 50-409,600 – the highest setting is one stop higher than the old 1D X. "
Nikon/Fuji.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 7 years ago by TeamSpeed. (3 edits in all)
Feb 02, 2016 10:15 |  #9
Very best,
Why 51K underexposed? That isn't the common issue on any camera? Shadow issues usually occur at lower ISOs where DR is a factor. If you are shooting at 51K and underexposing, then you are playing football in a cave. where they don't allow flash photography and you have to run fast shutters to stop action. I do a ton of high ISO shots, and 51K with underexposure is very, very dark, and there is simply not a common condition to shoot within. Even inside some of the darker hgh school gyms won't require underexposed 51K.
All we need to see whether the shadow noise is managed better or not is to shoot a landscape at ISO 400 where there is sun/fluffy clouds, yet architecture that is buried in the shadows. Or run the raw through rawanalyze or rawdigger to compare against prior bodies. Then a few at ISO 25600 with no post processing would be good.
palad1n
Gallery: 44 photos
Joined Jun 2013
Feb 02, 2016 10:23 |  #10
I´am always suprised how people makes statements about high iso capabilities based on 800x800 image... Let´s wait for RAW images.
Website (online) : www.lukaskrasa.com (external link)
Flickr : http://www.flickr.com/​photos/105393908@N03/ (external link)
Facebook page: https://www.facebook.c​om/lukaskrasaphoto/ (external link)
Instagram: https://instagram.com/​lukaskrasacom (external link)
Amateur Photographer based in Prague, Czech Republic
JeffreyG
Gallery: 42 photos
Feb 02, 2016 10:23 |  #11
Early reports, jpeg outputs etc always make these early assessments dicey. I see some comments from Canon and Jeff that make me cautiously optimistic on the DR front.
I also think the f/8 AF and performance comments there may be bigger than folks are suspecting.
Like I've said, if Canon catches up on DR/banding they are on top in everything else.
I'm looking forward to the real assessment when production cameras are tested, and I'm hopeful for future 5D4 potential.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Feb 02, 2016 10:29 |  #12
Just playing with underexposed ISO 200 JPG results at 1/2 size (2700 on the long end), pulling up the shadows in JPG are quite clean. This is a good sign by itself. Take any shadow image from a raw converted to JPG and bring up the dark areas 2+ stops, and the noise becomes apparent pretty quickly. I can still make out blades of grass after massaging the JPG, while having the compression factor to deal with.
David83
Gallery: 10 photos
Feb 02, 2016 11:15 |  #13
another review! with samples..small ones! LOL
http://scottkelby.com/​42048-2/ (external link)
Canon EOS R3 / Canon EOS R5 / Canon EF 600mm F4 IS L II / Canon RF 400mm F2.8 IS L / Canon RF 100-300mm F2.8 L / Canon EF 300mm F2.8 IS II L / Canon RF 70-200mm F2.8L / Canon EF 85mm 1.4 L IS / Canon EF 8-15mm F 4 L / Canon RF 28-70 F2 L / Canon RF 24-70mm F2.8L / Canon RF 15-35 F2.8 L IS / Canon RF 50mm F1.2L
Charlie
Guess What! I'm Pregnant!
Feb 02, 2016 11:26 |  #14
kelby and rouse are sponsored guys from canon, kelby will tend to give a somewhat balanced review, however rouse is a self admitted non techie, I just cant take his review seriously.
I didnt read anything about how low can it shoot in low light. The nikon does -4ev, does canon have the same spec?
Sony A7siii/A7iv/ZV-1 - FE 24/1.4 - SY 24/2.8 - FE 35/2.8 - FE 50/1.8 - FE 85/1.8 - F 600/5.6 - CZ 100-300 - Tamron 17-28/2.8 - 28-75/2.8 - 28-200 RXD
Panasonic GH6 - Laowa 7.5/2 - PL 15/1.7 - P 42.5/1.8 - OM 75/1.8 - PL 10-25/1.7 - P 12-32 - P 14-140
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 7 years ago by TeamSpeed. (2 edits in all)
Feb 02, 2016 11:44 as a reply to  @ Charlie's post |  #15
Here are the official specs, everything is there:
https://www.usa.canon.​com …ras/dslr/eos-1d-x-mark-ii (external link)
Here is an interview video on the tech specs
https://photography-on-the.net …showthread.php?​p=17883019
27,325 views & 34 likes for this thread, 30 members have posted to it and it is followed by 23 members.
1DX II review
915 guests, 117 members online
