adammazza wrote in post #17883616
I own a combination of AD360s, and V850s. In order to have a more streamlined setup (and HSS without using a YN622) I decided to give the X1 a try. So I picked up an X1 and XTR16 and started testing it on the AD360. A few questions.
1) Is it correct that at most I'll only be able to manually control power of 5 lights with this setup (A-E)? Don't think I'd need more, just wanting to make sure I'm understanding the setup correctly.
2) On the X1, what is the difference between the A/B/C mode which is default and enabling "Gr" when holding down <mode>? Is that just to enable the 5 groups?
3) When using the XTR16 it seems to disable the sound on the AD360? Basically I can no longer hear when the flash is cycled. Anyone else have this problem?
1) With a XTR16 receiver you have ability to adjust manual flash power in the older manual only flashes with one of the TTL 2.4G transmitters (X1, AD360II or TT685). You still have to enable the H mode in the flash it self as this feature is not automatically enabled. I am not sure if modeling light or focus lamp features will be allowed if Godox ever puts modeling light control in one of their 2.4G transmitters. It sounds like Godox is looking at adding this feature to the X1 for the AD600 but whether it will be useable for older manual only flashes remains to be seen. It looks like the new XT16 transmitter has the lamp feature same as the FT16 so I guess for what ever features are lacking in the 2.4G TTL transmitters can be controlled from the XT16 2.4G transmitter. Kind of unhandy but at least you have direct control of Manual flash power which is good enough for me.
2) The difference between the A,B,C mode compared to the "Gr" mode is the same as with the Canon Wireless RT system. The older Canon DSLR's are not capable of using the "Gr" mode. The A,B,C mode allows all Canon DSLRs to use the X1 wireless system with 3 Groups in either TTL only, Manual only or Multi only modes. If you have a newer 2012 or newer DSLR then you can activate and use the "Gr" mode which gives you 5 Groups and the ability to set each Group independently to either TTL or Manual modes or you have the ability to turn a Group "Off". The AD360II and TT685 still use the older Canon Optical Wireless Modes in a Radio Master configuration. I have been begging Godox to at least upgrade the AD360II and TT685 to the same features as the X1 and to also allow for individual mode control in the 3 Group configuration as it is with the "Gr" mode.
3) My problem is that I cannot hear any beeps that these strobes make in the first place so, I am not sure of an answer to your question.
I just checked and the "beep" feature, when enabled in the flash, is disabled as soon as the flash goes off when triggered by the X1. A way around this, I realize it kind of defeats the purpose of the XTR16 receivers giving direct flash power control from the X1, is to use an FT16 or XT16 in the X1 hot shoe to trigger and control the flash power of Legacy flashes, this will allow enabling the "Beep" and the focus lamp. HSS works in this setup when H mode is selected in the Legacy flash and you can hyper sync at 1/1 power as well. Using the flash sync timing adjustment (15-20) of the X1 I can pickup an extra stop of flash exposure with an AD360.
