Thread started 07 Mar 2006 (Tuesday) 13:04
Choosing AF points? (Rebel XT)
krista
Mar 07, 2006 13:04 |  #1
Can I ask a really dumb Q?
How do I choose which of teh 7 points I want to have as my focus point on the Rebel XT? I've heard and read about the "*" button on the back - can someone explain that to me?
Thanks for humouring my humble Q.....
http://www.kristajeffe​rson.com (external link)
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Mar 07, 2006 13:11 |  #2
Krista,. I have edited the title of your thread to refelct the actual nature of the question. You'll find this helps get the responses your looking for better than a generic "I have a question" title.
As for the question.. I'd love to help but I'm not familiar with the Rebel XT controls :)
CDS' HOT LINKS
sapearl
Gallery: 243 photos
Mar 07, 2006 13:12 |  #3
The only dumb question is the one that is never asked. You are in friendly company. I will have a similar question for my new 5D - I've just cracked the 179 page manual and there are only so many hours in the day ;) .
MY WEBSITE (external link)- MY GALLERIES (external link)- MY BLOG (external link)
Artists Archives of the Western Reserve (external link) - Board
Livinthalife
Mar 07, 2006 13:22 |  #4
pg 73 of the manual
thats got the real detail of doing it. hope that helps!
-Andy-
Jon
Joined Jun 2004
Mar 07, 2006 13:46 |  #5
Do you mean "Which focussing point should I use?" or "how do I select a focussing point?" The latter is explained in your manual; the former depends on what you're shooting. Most folks here usually use the center focussing point. If you're shooting something that you know will have the main area of interest off-center, choose the focussing point closest to the main point of interest.
Jon
Cocker Spaniels
krista
Mar 07, 2006 13:50 |  #6
I guess I'm wondering if I can choose one specific point of the seven point focus. i.e. say, I want to use the left focus point - is there a way to select it?
Jon
Joined Jun 2004
Mar 07, 2006 13:54 |  #7
IIRC (not having a 350D, but having gone over the manual),there's a button marked sorta like this [---]. Push it and use the arrows on the camera back to select the point you want (either while looking through the finder or via the LCD data display. But this will be in the manual, try p. 73 as Andy suggests.
Jon
Cocker Spaniels
formula4speed
Mar 07, 2006 14:00 |  #8
I haven't used my Xt in a while but I believe you want to hold down the button next to the * button on the back of the camera. If you are looking at the back, the button is on the top right hand side I believe. While holding this down rotate the black wheel that is directly behind the shutter button to change your focus point. Again, this is going from memory so consulting your manual can confirm or prove I'm getting old.
I'm taking pictures of everything, so go ahead and take this place away from me.
5DII, 16-35mm f/2.8L II, ZE 28mm f/2, 35mm f/1.4L, ZE 50mm f/1.4, 100mm f/2.8L IS, 580 EX
Pyrex
Mar 07, 2006 14:01 |  #9
Assuming you understood how to actually physically select which one of those points you want to use, it is down to the photo you wish to take. If you select a narrow depth of field, and you chose a specific point in your subject, then it is possible to use that location in the frame to be your chosen sharp point whilst allowing other areas to be less sharp according to their distance in front or behind the depth of field chosen.
So instead of taking a general hit or miss aproach with focal points flashing and bleeping like a disco show, you can rely on just the one. Which does not have to be the centre one. So if you are taking repeat shots at the same location you do not have to select the one in the centre, half hold down the shutter and then pan to your chosen framing of the image.
Just like computers, there are usually several ways to achieve the same objective. Which ever one feels most comfortable to use to you is the way to go.
(I think I got that right).....criticisms humbly accepted.
EOS Digital Rebel XT (Black):lol:
EFS 18-55 USM kit lens / EFS 10-22 USM
EF 70-200 USM f2.8L / EF 50 USM f1.4
EF 2X Mk11 Extender
Speedlight580EX /Jessops Ext Tubes
stupot
Mar 07, 2006 14:03 |  #10
you wont be able to change the focus point if you are not in a creative shooting mode. use all the modes to the left of the green square on the dial (P,Tv,Av,M...) and you will be able to change the focus point by pressing the button thats top right on the back of your camera (cross shaped symbol) and twiddling the scroll wheel by the shutter button. if you look through the camera viewfinder you will see the focus point change, same goes for looking at the screen on the back.
stu
Canon EOS 350D, Sigma 10-20 f4-5.6, 24-105 f4L IS, 70-200 f4L, 300 f4L IS, Kenko 1.4x pro300, 430EX, Apple Powerbook G4
Free filters for your flashgun!
krista
Mar 07, 2006 14:19 |  #11
I think I've figured it out! I keep hearing press the "*" and select your focal point- but couldn't figure out HOW! And one book I have is for the rebel (not XT) and so it says to press that then turn the dial - but I don't have a dial on teh back. ANyhow here's what I learned in case anyone else is interested...
-press * button
-press button beside it (this is the step I was missing!) - above the button there is a diagram of all seven focus points
-then they'll all go red in the viewfinder, and then I can scroll through with the dial on the front I use to change shutter speeds.
Wait - I just reread stupot's post and he never mentioned the "*" button so I tried doing it without that button and it works. What is the point of the * button?
Also... How long does this stay as my focal point - just for the one pic or is there a way to lock it?
Thanks everyone - you are sooo helpful!
Jon
Joined Jun 2004
Mar 07, 2006 14:22 |  #12
The posts you're reading about the '*' button are referring to setting Custom Function 4 to 1, which puts focus lock (not focus point selection) on the '*' button. Basically it swaps the focus lock and exposure lock functions.
Once you've selected any focus point via the [---] button, it'll stay there until you select another one (deliberately or accidentally).
Jon
Cocker Spaniels
ChopstickHero
Mar 07, 2006 14:29 |  #13
you have to be in P, Tv, Av or M mode to use the selective focussing points. You press [---] and then you can either spin the dial or use the 4 up/down/left/right keys to change it. after about a second, it will lock in that position. it won't change. you have to change it again if you want to pick another focussing point.
it's very useful and one of the things i love about DSLRs that have this feature. you can selective focus on something in the foreground and cause the background to blur if you have the right settings.
if you have your popup flash open, the * can be used to pre-flash a scene so that it can help with AF or metering. try it.
Canon 40D and 350D :: Canon 70-200mm f/2.8L IS :: Canon 17-55mm f/2.8 IS :: Canon 10-22mm f/3.5-4.5 :: Canon BG-E2 & BG-E3 :: Canon 430EX Speedlite :: Crumpler 6MDH & The Whickey and Cox
rdsmith3
Joined Feb 2006
Mar 07, 2006 15:16 as a reply to  @ ChopstickHero's post |  #14
OK, Krista, now you have me (a beginner) confused. I have the Rebel (300) not the XT (350) but I think they are similar.
I thought the ----- button is for changing the Focus point, and the * button, right next to it on the back of the 300D, is for locking the exposure.
I guess you need some extra thumbs and index fingers if you want to do both.
Bob Gear List
The eye is the lamp of the body; so then if your eye is clear, your whole body will be full of light. But if your eye is bad, your whole body will be full of darkness. If then the light that is in you is darkness, how great is the darkness! (Matt. 6:22-23)
2,860 views & 0 likes for this thread, 10 members have posted to it.
1764 guests, 131 members online
