Feb 05, 2016 20:33 | #1 Image hosted by forum (773985) © grizzerbear [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Barry
Feb 06, 2016 01:13 | #2 Nice composition and well seen. Could be a better final image if the editing halos weren't as visible around the edges of the leaves and hill outlines.
OhLook insufferably pedantic. I can live with that. 24,813 posts Gallery: 105 photos Best ofs: 2 Likes: 16149 Joined Dec 2012 Location: California: SF Bay Area More info | Feb 06, 2016 10:59 | #3 DavidWatts wrote in post #17887741 Could be a better final image if the editing halos weren't as visible around the edges of the leaves and hill outlines. I don't see them. Are you sure the lighter areas aren't effects of the contours of the land under irregular clouds? PRONOUN ADVISORY: OhLook is a she. | A FEW CORRECT SPELLINGS: lens, aperture, amateur, hobbyist, per se, raccoon, whoa | Comments welcome
Feb 06, 2016 11:31 | #4 OhLook wrote in post #17888063 I don't see them. Are you sure the lighter areas aren't effects of the contours of the land under irregular clouds?
Feb 06, 2016 13:53 | #5 DavidWatts wrote in post #17887741 Nice composition and well seen. Could be a better final image if the editing halos weren't as visible around the edges of the leaves and hill outlines. OhLook wrote in post #17888063 I don't see them. Are you sure the lighter areas aren't effects of the contours of the land under irregular clouds? Antihero47 wrote in post #17888106 Negative. There are definite Halo's in/around the brush. Calibrated Monitor here.
Barry
frozenframe Goldmember More info | Feb 07, 2016 13:10 | #6 What software do you have? On1Photo does a real good job, and is relatively easy to do. Ron
Feb 07, 2016 16:17 | #7 frozenframe wrote in post #17889312 What software do you have? On1Photo does a real good job, and is relatively easy to do. Thanks for the input Ron. Barry
Feb 10, 2016 07:26 | #8 What make me wonder about the bushes is some of the branches don't have the brightness around them. Halos are usually around everything contrasty. Would need to see the original file I guess. Comments, Questions, Observations Welcome
OhLook insufferably pedantic. I can live with that. 24,813 posts Gallery: 105 photos Best ofs: 2 Likes: 16149 Joined Dec 2012 Location: California: SF Bay Area More info | Feb 10, 2016 11:19 | #9 tmcman wrote in post #17892839 What make me wonder about the bushes is some of the branches don't have the brightness around them. Right. Some of those light areas correspond to shafts of sunlight visible at the top. PRONOUN ADVISORY: OhLook is a she. | A FEW CORRECT SPELLINGS: lens, aperture, amateur, hobbyist, per se, raccoon, whoa | Comments welcome
Feb 10, 2016 21:07 | #10 tmcman wrote in post #17892839 What make me wonder about the bushes is some of the branches don't have the brightness around them. Halos are usually around everything contrasty. Would need to see the original file I guess. OhLook wrote in post #17893142 Right. Some of those light areas correspond to shafts of sunlight visible at the top. I don't see the narrow white lines that result from oversharpening, although someone with a better monitor might. Thank you so much. I appreciate your kind critiques and comments. To say that I delve into them is an understatement Barry
| Latest registered member is griggt 1439 guests, 105 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
