Heya,
I would suggest you pull back a bit, and don't spring for filters and go nuts. You need to honestly have a need for a specific filter for it to be a good idea. Cheap filters give you cheap results. Sloppy glass and resin will ruin images, heavy color cast, aberration, lack of sharpness, IQ hits all over. It takes high quality filters to not have a significant impact on your image quality. Those $20 filters are big red flags for what not to buy.
A CPL is only needed if you're having issues with reflective surfaces. If you're not, then don't put one on there. Especially on an ultrawide, you'll see all kinds of issues with an ultrawide and CPL as angle is too wide and the effect of the CPL will not cover the whole angle of view so you'll see funky skies. Keep that in mind.
UV is an absolute waste of time. You're not shooting film. The lens hood and front element are tougher than any filter you're going to have on there. Save your money.
Variable faders are interesting, but a high quality one is more than your lens, and a low quality one, well, might as well just smudge jelly on your lens and call it a day. I would pass.
ND8. Why ND8? NF filters are very useful. I would however suggest that having a goal for them is what you get them for. A 3 stop ND filter is useful. But, why only 3 stop? What about 6 stop? 10 stop? My point is, what's your goal with an ND filter? Long exposure? How long?
If you want to do this on a budget, then reduce how many filters you're buying and eliminate the things that are not going to be useful. There are cost-effective filters out there.
Look at:
Marumi
Haida
B+W
Hoya
Haida makes really great filters on the cheap, worth checking out. Same glass as B+W with less cost. You can get a 10 stop Haida PROII series for like $60, and it's well worth it. For CPL, take a look at Marumi DHG, top notch quality without all the bloated cost of some other brands.
Again, you may not actually need most of these, at all, unless you have a goal that requires them.
Very best,
