What is the best, and most natural looking, way to go about brightening/whitening teeth?
I was thinking that dodging might be the best way, but I'm wondering if there is something better to try.
Thanks.
neacail Goldmember More info Post edited over 7 years ago by neacail. | Feb 07, 2016 18:21 | #1 What is the best, and most natural looking, way to go about brightening/whitening teeth? Shelley
gonzogolf dumb remark memorialized More info | Feb 07, 2016 19:07 | #2 Select the teeth, and then slowly desat desat the yellow.
Feb 07, 2016 19:55 | #3 gonzogolf wrote in post #17889669 Select the teeth, and then slowly desat desat the yellow. Clever. Shelley
rrblint Listen! .... do you smell something? More info | Feb 07, 2016 21:17 | #4 Another technique is to create a curves layer with increased brightness in the upper region of the spectrum, then slowly paint this layer in at about 7-10% opacity. Mark
DanMarchant Do people actually believe in the Title Fairy? 5,635 posts Gallery: 19 photos Likes: 2058 Joined Oct 2011 Location: Where I'm from is unimportant, it's where I'm going that counts. More info | Feb 07, 2016 23:11 | #5 I use the desaturation method too. Lightrooms adjustment brush over the teeth then raise exposure and reduce saturation. Same thing for whites of eyes. Dan Marchant
Feb 08, 2016 08:35 | #6 Thanks, everyone! This mouth I'm working on is looking better. The desaturation of the yellow and 10% brightness layer did the trick. Shelley
nathancarter Cream of the Crop More info Post edited over 7 years ago by nathancarter. | Feb 08, 2016 08:57 | #7 Lightroom's teeth whitening preset for the adjustment brush usually does a good job - depending on how the teeth are to start with. I use it on eye whites a lot, too. http://www.avidchick.com
Hen3Ry Goldmember 1,063 posts Likes: 28 Joined Nov 2009 Location: Aptos, CA, USA More info | Feb 09, 2016 19:58 | #8 gonzogolf wrote in post #17889669 Select the teeth, and then slowly desat desat the yellow. Bingo. ***************
kjonnnn Goldmember 1,216 posts Likes: 148 Joined Apr 2005 Location: Chicago, Illinois More info | Feb 10, 2016 00:01 | #9 Sponge tool set to desaturation. Hardness at 0 or close.
Damo77 Goldmember 4,699 posts Likes: 115 Joined Apr 2007 Location: Brisbane, Australia More info | Feb 10, 2016 01:05 | #10 |
kjonnnn Goldmember 1,216 posts Likes: 148 Joined Apr 2005 Location: Chicago, Illinois More info | Feb 10, 2016 03:03 | #11 Desaturation removes the yellowing of teeth which is what you want. Whitening looks unnatural and makes the too bright and white.
gonzogolf dumb remark memorialized More info | Feb 10, 2016 06:59 | #12 Damo77 wrote in post #17892611 No, not desaturation! That looks awful. Only raise the Lightness slider. Only if glowing yellow is what you are after.
Feb 10, 2016 10:00 | #13 Maybe different people have different types of discoloration on their teeth, and they all need slightly different processing treatments? http://www.avidchick.com
BlakeC "Dad was a meat cutter" More info | Feb 10, 2016 10:02 | #14 Damo77 wrote in post #17892611 No, not desaturation! That looks awful. Only raise the Lightness slider. He's only desaturating the yellow channel, not just normal desaturation. Blake C
groundloop Senior Member 995 posts Likes: 46 Joined Jun 2012 More info Post edited over 7 years ago by groundloop. | Feb 10, 2016 11:24 | #15 neacail wrote in post #17890126 ....... How are you dealing with dental fluorosis (white spots/streaks)? ....... I've never had to deal with this, but it's my guess that carefully using the spot-healing brush and/or clone tool before 'whitening' should work.
| Latest registered member is semonsters 1457 guests, 126 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
