Thread started 08 Feb 2016 (Monday) 05:51
i need a new 85mm
mike_311
Checking squirrels nuts
Gallery: 18 photos
Joined Mar 2011
Feb 08, 2016 05:51 |  #1
I've come to the conclusion that I cant use my 135. I love the look, but its too long and handshake is a real issue for me. I'm much better with my 85. the focal length is perfect for me. but the 135 produces the look i want so i struggle with it.
I'm thinking about getting an 85/1.2 but im not sure I want to pay the premium for it. I could sell both my 85/1.8 and the 135L but i'd rather keep the 135.
The 85/1.8 is solid but i'm looking for something give a bit dreamier look when shooting wide open. is the 85/1.2 my only worthwhile option or does someone other than canon make a solid alternative. I'm also not opposed to say a 70-200/2.8 IS either...
thoughts?
Canon 5d mkii | Canon 17-40/4L | Tamron 24-70/2.8 | Canon 85/1.8 | Canon 135/2L
www.michaelalestraphot​ography.com (external link)
Flickr (external link) | 500px (external link) | About me
philodelphi
Gallery: 50 photos
Feb 08, 2016 06:07 |  #2
Take a look at the Sigma 85 1.4
Sony DSC-RX100M2 α7R III / ILCE-7RM3 Cyber-shot DSC-RX10 IV | Voigtlander 65mm F2 Macro APO-Lanthar | Venus Optics Laowa 15mm f/4 Macro | Sony FE 24-240mm F3.5-6.3 OSS Sonnar T* FE 55mm F1.8 ZA FE 24mm f/1.4 GM | Samyang 35mm f/1.4 ED AS UMC | Canon MP-E 65mm f/2.8 1-5x Macro Photo EF 100mm f/2.8 Macro USM | Sigma 100-400mm f/5-6.3 DG OS HSM | Tokina Firin 20mm f/2 FE MF | Tamron 28-75mm F2.8 Di III RXD
mike_311
Gallery: 18 photos
Joined Mar 2011
Feb 08, 2016 11:15 as a reply to  @ philodelphi's post |  #3
with the 85 ART rumored to be coming out i'm a bit leery of getting one just yet.
CanonYouCan
Post edited over 7 years ago by CanonYouCan. (5 edits in all)
Feb 08, 2016 11:53 |  #4
Time that the rumors are over and that Sigma announces the 85 Art officially.
As Sigma never makes f1.2 lenses it will be a Sigma 85 1.4 Art, probably without OS.
Don't know if I would sell my 85 1.2L (MKI) for that.
E.g. I bought a 50 1.4 Art because it's way sharper than the 50 1.2L wide open.
I think I would't buy a Sigma 85 1.4 Art only for the sharpness as the 85 1.2L MKI is allready a sharp lens (+ unique f1.2)
Maybe a 85 1.4 Art with OS, but not without.
Yes the 135L is sometimes a difficult lens to work with.
This weekend I took about 300 pics during carnaval, moving my lens fast at ISO 500 & fast shutterspeeds of 1/2000 at f2.
I think I have only +-120 sharp ones in the centre, the rest are blurry.
Despite of the superfast AF, this lens is ideal for modelshoots outdoor, where you don't move so much...
mike_311 wrote in post #17890311 (external link)
Sony A7 III | Metabones V | Sigma 35 1.4 Art | Sigma 85 1.4 Art | 70-200 2.8L II
Lighting : Godox AD600B TTL + Godox V860II-S + X1T-S
Modifiers: 60cm Collapsible Silver Beautydish + grid | Godox 120cm Octagon softbox + grid + Speedlite Flash bender
Tripod: Vanguard Alta 253CT carbon
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Post edited over 7 years ago by MalVeauX.
Feb 08, 2016 13:26 |  #5
mike_311 wrote in post #17890032 (external link)
thoughts?
Well, 135 is so niche, you can only go wider or longer. You just said "it's too long" and then you're saying a 200mm might work. So, is it too long in the sense of shutter speed needs, or is it too long for working distnace needs? Makes a big difference. While you can get away with slower shutter on the 70-200 F2.8L II, it weighs a lot more, so you have to consider that. If you already have issues with shaking hands, do you think it will be difficult to hold a bigger, heavier lens, despite having IS that helps with the shutter speed need?
135L (subject at 20 feet, F2, DOF is barely 1 foot (0.79)
85 F1.4 (subject at 15 feet, F1.4, DOF is barely 1 foot (0.79ft)
So between working distance and faster aperture, you can get the same DOF.
As for amount of blur, the 85 F1.4 at F1.4 will produce more blur at the same distance as the 135L at F2, from 1 meter out to 30 meters, after 30 meters, the 135L will finally produce more blur, however, 30 meters is probably not your working distance.
The longer focal length will suck the background forward just a little bit more.
Other than that, you can recreate the "look" very closely.
I would look at the Sigma 85mm F1.4 at half the cost of the 85L. Also, compare the 85L and Sigma 85 F1.4 at F1.4 together, there are tons of threads about it, they're so similar it's almost a wash really, assuming both are good copies and both in proper focus, etc.
Very best,
DoughnutPhoto
Joined Aug 2014
Feb 08, 2016 15:03 |  #6
You might consider another body with higher ISO capability to reduce your shutter speed. Did you consider a monopod to steady the camera?
Canon 5d, 60d, 17-40mm L, 30mm Art, 50mm, 85mm
philodelphi
Gallery: 50 photos
Feb 08, 2016 15:10 as a reply to  @ DoughnutPhoto's post |  #7
Maybe I'm in the minority here, but I have the Sigma 50mm 1.4, not Art. I love it. I just can't justify going to the Art. So just because Sigma may come out with a 85 1.4 art, that doesn't mean that the current one isn't awesome.
mike_311
Gallery: 18 photos
Joined Mar 2011
Feb 08, 2016 18:52 |  #8
philodelphi wrote in post #17890583 (external link)
the sigma retails for ~$1000, when the ART comes out that price will likely drop so i'll probably wait regardless.
to answer a few other questions, i have a monopod which i do use, it helps a little. I also have a 5d2, I usually bump the ISO to 400 or 800 with no issues to get it sharp.
i just find the 85mm focal length to be what i prefer for shooting with, i only use the 135 because i love the images it makes but i need quite a bit of room to use it and forget using it outdoors. i was thinking about a 70-200/2.8 to cover both the 85 and the 135 plus some.
i started using more artificial light and the 85 is just easier to use all around without having to use HSS.
Myboostedgst
Gallery: 26 photos
Post edited over 7 years ago by Myboostedgst.
Feb 08, 2016 19:29 |  #9
The 70-200 won't give you the look that the 135L does, altough it is close. You will need to be at 200mm to get a close look to the 135, and while the extra focal length does suck, the IS really does help. You clearly said you like the 85mm focal length, so that is what you need. You just need to decide on if you want the 85L or the current Sigma 85 1.4, or wait for the rumored 85 1.4 ART (most likely without OS). The 70-200 is a great lens, but anything other than a 85mm is a stop gap and you will eventually end up at the 85mm focal length.
BTW - I tested the 70-200 IS II side by side on an outdoor model shoot with my 135L and a rented 70-200 F4. Anything less than 200mm @ 2.8, the 135L blows it out of the water in that special "look" feeling.
Andrew | Midwest Automotive (external link) | Flickr (external link) | Instagram (external link)
MalVeauX
Joined Feb 2013
Feb 08, 2016 19:33 |  #10
mike_311 wrote in post #17890858 (external link)
Heya,
For reasons similar to this, I use a Tamron 90mm F2.8 VC. It's basically an 85mm (90mm), and has modern 4 stop image stabilization. Razor sharp, compared to 100L. The trade off is that it's F2.8, but it's very good wide open. So it's a lighter weight lens than using a big heavy 70-200 F2.8 lens just to gain stabilization. I use it for portrait, with lighting, etc, too. I don't use my 85mm F1.4 with lighting outside, because I prefer to not have to use 8~10 stops or HSS just to make up for it. So the F2.8 doesn't bother me.
I would love if Canon would release an 85 F1.8 IS :)
Very best,
gonzogolf
dumb remark memorialized
Gallery: 559 photos
Feb 08, 2016 19:55 |  #11
The bokeh on the 70-200 II is closer to the 135L than the 85 1.8. I enjoy the 85 1.8 but whe I shoot with it there is a richness thats missing from the 135L. Whether its bokeh, micro contrast, or whatever it just doesnt come close. The shots I've seen from the 70-200II are closer.
mike_311
Gallery: 18 photos
Joined Mar 2011
Feb 08, 2016 20:59 as a reply to  @ gonzogolf's post |  #12
i hear you. i really enjoy my 85/1.8 too but its not the 135L. i see shots from the 85/1.2 and its there.
i'd like to try out a sigma 1.4, ive never own a sigma. is the sigma lottery a real concern with the older pre-art lenses? i'm kind of leery about buying one after reading so many posts over the years.
OoDee
Gallery: 58 photos
Joined Oct 2012
Post edited over 7 years ago by OoDee. (2 edits in all)
Feb 09, 2016 00:50 |  #13
I was never able to justify paying the ridiculous top dollars for the 1.2L. So I bought the Sigma 1.4, and even found it it used for a nice 500 euros. After some 6 months the lens has received a lot of attention from, to the point that I barely use the 135mm anymore - which, in itself , is a great shame.
I just don't see the one extra stop being worth it. So far the F1.4 has been fast enough without a problem.
mike_311
Gallery: 18 photos
Joined Mar 2011
Feb 09, 2016 06:16 as a reply to  @ OoDee's post |  #14
i dont "need" 1.2, i'm content with what 1.8 provides. The 85/1.8 just doesn't give that dreamy look and i'm looking for an 85 that will, if it exists. from what ive seen of the 85/1.2 it appears to. I'll be looking into the sigmas.
DesolateMirror
Gallery: 251 photos
Joined Oct 2015
Post edited over 7 years ago by DesolateMirror.
Feb 09, 2016 09:15 |  #15
If you wanted to go super-crazy-dreamy you could try to get your hands on a Helios 40-2 85mm 1.5 (yeah, it's manual)
flickr search: https://www.flickr.com​/search/?q=helios+40-2&s=int (external link)
I think this photographer took nearly all these shots with one (portraits): http://direct3dvisual.​deviantart.com/gallery​/ (external link)
9,967 views & 12 likes for this thread, 21 members have posted to it and it is followed by 13 members.
i need a new 85mm
1320 guests, 125 members online
