My brand new 15 year old Canon 1D uses FAT. That means it can only format and recognize a 2GB partition. Is there any way to get the camera to recognize my entire 4GB or 8GB CF card?
Bassat "I am still in my underwear." 8,075 posts Likes: 2742 Joined Oct 2015 More info | Feb 10, 2016 18:55 | #1 Permanent banMy brand new 15 year old Canon 1D uses FAT. That means it can only format and recognize a 2GB partition. Is there any way to get the camera to recognize my entire 4GB or 8GB CF card?
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Feb 10, 2016 20:03 | #2 4 GB maybe, if you open a command line window (worked with XP; may not with later versions of MS operating systems) and use the FORMAT command with switches /FS:FAT and /A:64K. So at a command prompt enter FORMAT X: /FS:FAT /A:64K Jon
Feb 10, 2016 21:03 | #3 Permanent banThanks. The command you provided runs. It just limits partition size to 2GB. 64K cluster size works, but yields a 2gb partition. If I try to go bigger on the cluster size, it throws an error. "Cluster size too big for FAT file system." Using Win7.
Feb 10, 2016 21:52 | #4 Jon wrote in post #17893731 4 GB maybe, if you open a command line window (worked with XP; may not with later versions of MS operating systems) and use the FORMAT command with switches /FS:FAT and /A:64K. So at a command prompt enter FORMAT X: /FS:FAT /A:64K Don't use windows but can you specify fat32 or is that implicit these days >>> Pictures? What pictures? <<<<
CyberDyneSystems Admin (type T-2000) More info Post edited over 7 years ago by CyberDyneSystems. (3 edits in all) | Feb 10, 2016 22:07 | #5 I thought for sure my 1D would use 4GB with a FAT32 format. GEAR LIST
Bassat THREAD STARTER "I am still in my underwear." 8,075 posts Likes: 2742 Joined Oct 2015 More info Post edited over 7 years ago by Bassat. | Feb 11, 2016 00:41 | #6 Permanent banOk, guys. Thanks. I got it. The 'problem' was trying to run that command on a card already formatted by the 1D. My computer then thought it was only a 2GB card. When I formatted the card in the 1DII first, the computer could see it was a 4GB card. I probably could have just as easily formatted it fat32 in the computer and THEN moved to the above command. Anyway, my brand new 15 year old camera can now use all 4GB of my 4GB cards. Now I can get twice as many photos on card. That may come in handy at 8 fps! Thanks, a heap, everyone!
Feb 11, 2016 01:08 | #7 Permanent banRodS57 wrote in post #17893848 Don't use windows but can you specify fat32 or is that implicit these days Rod Thanks for the input, Rod. I believe default for the last 10 years or so is NTFS.
Feb 11, 2016 16:19 | #8 Bassat wrote in post #17893980 Thanks for the input, Rod. I believe default for the last 10 years or so is NTFS. With this issue, on this camera (1D classic), fat32 is the problem. The camera does not recognize a fat32 card as being formatted, so it overwrites it with FAT, and the default 16k cluster size, which only allows for a 2GB max. Reformatting, using FAT and a 64K cluster size allows for a 4GB card to be used at full capacity. Just about every card or jump drive that you buy that is already formatted (I haven't seen any that were not) has the fat32 file system because support is pretty much universal. If you are really curious about the file system type then copy a file that has a longer name than 8 characters (ie: thisisafile.txt ). If, aftercopying, the visible name of the file on the card hasn't changed then you have fat32. >>> Pictures? What pictures? <<<<
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Feb 11, 2016 17:28 | #9 NTFS is a characteristic of the Windows NT family. I believe it was introduced with Windows NT 3.1, but certainly was the Windows 3.5 standard and has been so ever since. Windows ME was (an unlamented) part of the 16-bit Windows family along with Win 3.1, Win 95, and Win98. It met its end when Microsoft released Windows 2000, which unified the Win9x GUI and the WinNT kernel. But there's always been the option of formatting media using any of the earlier/other MS file systems. Glad that blasting away the artificial partitioning took care of it for you. Jon
Feb 11, 2016 21:51 | #10 Jon wrote in post #17894792 NTFS is a characteristic of the Windows NT family. I believe it was introduced with Windows NT 3.1, but certainly was the Windows 3.5 standard and has been so ever since. Windows ME was (an unlamented) part of the 16-bit Windows family along with Win 3.1, Win 95, and Win98. It met its end when Microsoft released Windows 2000, which unified the Win9x GUI and the WinNT kernel. But there's always been the option of formatting media using any of the earlier/other MS file systems. Glad that blasting away the artificial partitioning took care of it for you. Oops! I forgot about the win NT versions. I can remember the interview where Bill Gates said a computer would never need more than 640k of ram. Definitely getting old I am. >>> Pictures? What pictures? <<<<
joeseph "smells like turd" More info | Feb 12, 2016 02:28 | #11 Jon wrote in post #17894792 It met its end when Microsoft released Windows 2000 oddly I came across a Win2k server today - lord know what it does, I'm hoping to quietly ignore it while migrating the rest of the network to a decent structure... some fairly old canon camera stuff, canon lenses, Manfrotto "thingy", and an M5, also an M6 that has had a 720nm filter bolted onto the sensor:
| Latest registered member is Thunderstream 1900 guests, 106 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
