FORUMS Nikon Cameras, Lenses & Accessories Nikon Lenses
Thread started 11 Feb 2016 (Thursday) 20:32
Sigma 50-150 2.8 OS HSM EX on Full Frame
werds
"Yes, Sire. You'll shut your trap!"
Gallery: 12 photos
Joined Mar 2014
Post edited over 3 years ago by werds. (4 edits in all)
Feb 11, 2016 20:32 |  #1
When I left the Canon family and moved over to Nikon in order to go up to full frame (D750) I lamented having to leave behind my 3 favorite lenses (in order of most favored first) - Sigma 50-150 2.8 OS HSM EX, Sigma 18-35 1.8 Art, and my Canon 17-55 2.8 IS. Well since I recently picked up a D7200 as my backup camera (and as a cheap way of extending reach on my Tamron 150-600) I decided I may as well pickup a Sigma 50-150 2.8 OS whenever the opportunity arises since I knew how rare a good used copy was becoming...
So as soon as it arrived this afternoon I took a few quick snaps with the lens mounted on my D750 just to see how bad the vignetting would be and the following pictures are the result. (For those not interested in going further - I was actually shocked at how useful this lens works on a full frame sensor even though it is meant for crop!) All of the pictures below were shot originally in RAW and then minimal processing in Lightroom 5.7 to convert to Jpeg. On the lens corrected jpegs below - note that all I did was put a checkmark in the lens correction portion - I did NOT adjust the effects manually which would likely reduce the vignetting even more on some of these.
***EDIT - After posting I realized that out of sheer habit I had taken all of these photos with the lens hood on! This significantly effects the shape of the vignette!!! - Because of this error I went back and added 4 new photos in POST #8 of this thread with the lens hood removed while in Full Frame mode and in 1.2 Crop mode in camera (Pictures will be forthcoming)
50mm in Full Frame Mode - wide open at 2.8.
This first one had no lens corrections and no CA removed
IMAGE: https://farm2.staticflickr.com/1630/24336918114_64232a944c.jpg
IMAGE LINK: https://flic.kr/p/D5z4​Ss  (external link) GM1_8803 Full Frame 50mm (external link) by Gabriel Martinez (external link), on Flickr
This below had Lens Correction applied and CA removed
IMAGE: https://farm2.staticflickr.com/1595/24874400781_0a1a9b4a77.jpg
IMAGE LINK: https://flic.kr/p/DU4N​JZ  (external link) GM1_8803 Full Frame 50mm (external link) by Gabriel Martinez (external link), on Flickr
Although there is hard vignetting it doesn't look too horrible to me anyways.
150mm in Full Frame Mode - wide open at 2.8
No Lens Corrections and no CA removed
IMAGE: https://farm2.staticflickr.com/1699/24967529685_d58b7650d0.jpg
IMAGE LINK: https://flic.kr/p/E3i7​HK  (external link) GM1_8806 Full Frame 150mm (external link) by Gabriel Martinez (external link), on Flickr
The below had Lens Corrections applied and CA removed
IMAGE: https://farm2.staticflickr.com/1615/24340863483_5a6252087c.jpg
IMAGE LINK: https://flic.kr/p/D5Vh​G4  (external link) GM1_8806 Full Frame 150mm (external link) by Gabriel Martinez (external link), on Flickr
Although there is some hard vignetting there it is manageable and the lens correction did clear some of the edge vignetting.
50mm in 1.2 Crop Mode -wide open at 2.8
IMAGE: https://farm2.staticflickr.com/1496/24941211006_a5f830daa7.jpg
IMAGE LINK: https://flic.kr/p/DZYe​6q  (external link) GM1_8804 1.2 Crop 50mm (external link) by Gabriel Martinez (external link), on Flickr
WOW - this was were I was getting giddy. at 1.2 the vignetting was disappearing even before lens corrections and in the viewfinder!
This below was with Lens Corrections and CA removed
IMAGE: https://farm2.staticflickr.com/1601/24672229300_757fbde40f.jpg
IMAGE LINK: https://flic.kr/p/DAcC​cN  (external link) GM1_8804 1.2 Crop 50mm (external link) by Gabriel Martinez (external link), on Flickr
I was amazed to see there was minimal vignetting left in the extreme corners!
150mm in 1.2 Crop Mode - wide open at 2.8
This one was with no lens correction and no CA removed
IMAGE: https://farm2.staticflickr.com/1703/24336914464_7d5813f9e1.jpg
IMAGE LINK: https://flic.kr/p/D5z3​Mw  (external link) GM1_8807 1.2 Crop 150mm (external link) by Gabriel Martinez (external link), on Flickr
The vignetting barely paints the corners. looks like 1.2 crop mode is a sweet spot for this lens as long as it is being used wide open.
This one had lens correction added and CA removed
IMAGE: https://farm2.staticflickr.com/1556/24941405586_0d264479c9.jpg
IMAGE LINK: https://flic.kr/p/DZZd​Wf  (external link) GM1_8807 1.2 Crop 150mm (external link) by Gabriel Martinez (external link), on Flickr
CLEAN... that is all I have to say on that one :lol: ok maybe there is light vignette painting but it is light and manageable.
Gear: Nikon D750, Nikon D7200, Sigma 17-50 2.8 OS, Sigma 50-150 2.8 OS HSM EX , Nikon 70-200 2.8 VR1, Tamron 24-70 2.8 VC, Tamron 70-200 2.8 VC, Tamron 28-300mm Di VC PZD, Tamron 16-300mm VC PZD, Tamron 150-600 VC, Nikon AF-S 50mm 1.8, Nikon SB-900
POTN Seller Feedback (and other)
werds
Gallery: 12 photos
Joined Mar 2014
Post edited over 3 years ago by werds. (2 edits in all)
Feb 11, 2016 20:32 |  #2
Having shown the full frame and 1.2 crop mode and how it looks last but not least is 1.5 crop mode. I will post those below in similar order.
50mm 1.5 Crop Mode no lens correction no CA removal
IMAGE: https://farm2.staticflickr.com/1466/24849530092_4ebaf10ee5.jpg
IMAGE LINK: https://flic.kr/p/DRSk​y1  (external link) GM1_8805 1.5 Crop 50mm (external link) by Gabriel Martinez (external link), on Flickr
lens correction and CA removal applied
IMAGE: https://farm2.staticflickr.com/1559/24340871903_32f43a34c0.jpg
IMAGE LINK: https://flic.kr/p/D5Vk​ce  (external link) GM1_8805 1.5 Crop 50mm (external link) by Gabriel Martinez (external link), on Flickr
150mm 1.5 Crop mode no lens correction and no CA removal
IMAGE: https://farm2.staticflickr.com/1642/24874186131_3e03b817af.jpg
IMAGE LINK: https://flic.kr/p/DU3G​W8  (external link) GM1_8808 1.5 Crop 150mm (external link) by Gabriel Martinez (external link), on Flickr
150mm 1.5 Crop mode lens correction and CA removal applied
IMAGE: https://farm2.staticflickr.com/1507/24941402206_ce7bf597eb.jpg
IMAGE LINK: https://flic.kr/p/DZZc​VY  (external link) GM1_8808 1.5 Crop 150mm (external link) by Gabriel Martinez (external link), on Flickr
werds
Gallery: 12 photos
Joined Mar 2014
Feb 11, 2016 20:42 |  #3
So my closing thoughts. If you are a crop sensor shooter and it might be a few years before you move up to full frame or don't plan on moving up. This lens is a gem and especially with Nikon if you do move up to full frame it is still usable versus when I was on Canon it became a little less usable ;)
Myboostedgst
Gallery: 28 photos
Feb 11, 2016 20:48 |  #4
Without the crop factor it is bad, I useable in my opinion. I really wish they made a 50-150 2.8 for full frame. That would be a fantastic focal length.
Andrew | Flickr (external link) | Instagram (external link)
werds
Gallery: 12 photos
Joined Mar 2014
Feb 11, 2016 20:58 |  #5
Myboostedgst wrote in post #17895011 (external link)
Yes the vignetting is pretty noticeable at full frame, and when I closed down to F11 you could see the hard edged outline - it vignetted less but you could see the solid outline at that point. But this is where it becomes personal decision though! I could shoot and frame in full frame mode and crop out the vignette in post or use the lens effects to clean it up further and it would give me similar size files and quality as if I set the camera into one of it's crop modes.
That said if I was to use this lens on my full frame I would definitely put it into 1.2 crop mode and shoot from there. It would reduce the amount of post processing I would need to do. It is a unique range to work in for full frame and a great range for crop cameras when you convert the field of view (In 1.5 mode it is a fov similar to 75-225mm and in 1.2 mode it is fov similar to 60-180mm on full frame)
Just thought it would be interesting to post up these pictures of one of my favorite crop lenses (I know someone had done it in the past but the image links seem to be broken in that post). Also glad to see that nifty in camera crop mode that Nikon offers having a use that I might actually use! (Not likely but it is there if need or opportunity arise!)
Myboostedgst
Gallery: 28 photos
Feb 11, 2016 21:06 |  #6
No I am glad you did post them up. The 1.2 images are useable by far. And it doesn't extend the FOV out too much. I had never seen this lens used on crop so it was very interesting.
werds
Gallery: 12 photos
Joined Mar 2014
Feb 11, 2016 21:12 as a reply to  @ Myboostedgst's post |  #7
Sorry, tone is hard to convey in text - I took no offense and appreciate your thoughts! Stepping back and looking at them you are right the straight full frame shots are barely usable but at the same time I loved seeing the difference in framing between the different crop modes. I almost wish I had set the camera to manual and not aperture priority. Just glad I had thought enough to stay put in one spot while changing the modes lol
werds
Gallery: 12 photos
Joined Mar 2014
Feb 11, 2016 22:51 |  #8
***EDIT - After posting I realized that out of sheer habit I had taken all of these photos with the lens hood on! This significantly affects the shape of the vignette!!! - Because of this error, I went back and added 4 new photos below with the lens hood removed while in Full Frame mode and in 1.2 Crop mode in camera
50mm Full Frame mode no lens correction and no CA removed
IMAGE: https://farm2.staticflickr.com/1561/24339798564_27fb74f9d8.jpg
IMAGE LINK: https://flic.kr/p/D5PQ​8o  (external link) GM1_8821 (external link) by Gabriel Martinez (external link), on Flickr
150mm Full Frame mode no lens correction and no CA removed
IMAGE: https://farm2.staticflickr.com/1448/24944069106_d4f9bcaf1b.jpg
IMAGE LINK: https://flic.kr/p/E1dS​H1  (external link) GM1_8822 (external link) by Gabriel Martinez (external link), on Flickr
50mm 1.2 Crop Mode with no Lens corrections and no CA Removed
IMAGE: https://farm2.staticflickr.com/1520/24852386772_ff107a8e01.jpg
IMAGE LINK: https://flic.kr/p/DS7Y​K7  (external link) GM1_8823 (external link) by Gabriel Martinez (external link), on Flickr
150mm 1.2 Crop Mode with no lens corrections and no CA removed
IMAGE: https://farm2.staticflickr.com/1630/24852383962_e4a14c840c.jpg
IMAGE LINK: https://flic.kr/p/DS7X​UE  (external link) GM1_8824 (external link) by Gabriel Martinez (external link), on Flickr
50mm Full Frame mode Lens Corrected and CA removed
IMAGE: https://farm2.staticflickr.com/1643/24877184951_d90dfc1b35.jpg
IMAGE LINK: https://flic.kr/p/DUj5​nV  (external link) GM1_8821 (external link) by Gabriel Martinez (external link), on Flickr
150mm Full Frame mode Lens Corrected and CA removed
IMAGE: https://farm2.staticflickr.com/1538/24675003100_8fbd8ed7cf.jpg
IMAGE LINK: https://flic.kr/p/DArQ​KW  (external link) GM1_8822 (external link) by Gabriel Martinez (external link), on Flickr
The weird shimmer on the left side was reproduced in every shot I took, it was less visible when I took pictures against a grey wall but was more visible in the original shot here so decided to upload this one.
50mm 1.2 Crop Mode with Lens corrections and CA Removed
IMAGE: https://farm2.staticflickr.com/1689/24602880839_2dac1a9682.jpg
IMAGE LINK: https://flic.kr/p/Du5c​jF  (external link) GM1_8823 (external link) by Gabriel Martinez (external link), on Flickr
150mm 1.2 Crop Mode with Lens corrections and CA removed
IMAGE: https://farm2.staticflickr.com/1717/24970508825_852902d235.jpg
IMAGE LINK: https://flic.kr/p/E3yo​je  (external link) GM1_8824 (external link) by Gabriel Martinez (external link), on Flickr
werds
Gallery: 12 photos
Joined Mar 2014
Feb 11, 2016 22:57 |  #9
OK, so removing the lens hood does make the vignetting slightly more palatable but still meh. Wish I would have paid attention to that factor but I guess lens hood habits are second nature at this point!
smythie
I wasn't even trying
Gallery: 30 photos
Post edited over 3 years ago by smythie.
Feb 12, 2016 04:09 |  #10
Looks like another case of a great crop lens looking very useable on FX. Thanks for the comparisons
All you need now for your D7200 are the 18-35 and NIkon 17-55 :D
5,164 views & 3 likes for this thread
Latest registered member is mogeqq
976 guests, 288 members online
