Thread started 12 Feb 2016 (Friday) 13:33
camera lens, 2 tcs and a ex tube ?
GyRob
Feb 12, 2016 13:33 |  #1
Can someone tell me what focal length this combo makes
camera is a 5DSr and in this order 1.4tc - 12mm extension tube - 2xtc and a 600f4
is it 1680mm ?
Rob.
"The LensMaster Gimbal"
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Post edited over 7 years ago by MalVeauX.
Feb 12, 2016 13:40 |  #2
Heya,
The TC's and physical lens will multiply regardless of order.
The 12mm extension tube will then move the elements forward, reducing their minimum focus distance, and reducing infinity focus.
600mm x 1.4 TC x 2.0 TC (in any order) is 1680mm.
Why are you putting the extension tube between the TC's? That will change things and change how the focal lengths work with TC's.
Very best,
GyRob
Post edited over 7 years ago by GyRob.
Feb 12, 2016 13:45 as a reply to  @ MalVeauX's post |  #3
Its to get this my tcs wont join together hence the tube .
Rob.
Ediit its the space station .
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/02/2/LQ_775230.jpg
Image hosted by forum (775230) © GyRob [SHARE LINK]
BigAl007
Gallery: 556 photos
Feb 12, 2016 18:10 |  #4
From what I have read on here by other posters, the 12mm ext tube goes between the the two TC's, and doesn't affect infinity focus. It seems with the design of modern TC's you cannot stack them. Even so the multiplication works the same, so you would get base fl×TCa×TCb=Total fl. So in this case it would be 1.4×2×600=1680mm and it will have an f/number of f/11. I think you might need to tape the pins to stop it trying to report to the body though.
Alan
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Feb 12, 2016 18:17 |  #5
I stack my 2 Kenkos all the time, so perhaps something has happened with newer TC designs, or is this just a Canon thing?
Jon
Joined Jun 2004
Feb 12, 2016 18:32 |  #6
I suspect it's a Canon (and Sigma) thing - their TCs have protruding front elements.
OP - you'll have, as you described the arrangement, a 1200 mm lens on 12 mm extension tubes (so focusing minimally closer than infinity when at infinity; I think around 120 meters) with a 1.4x TC (which, there, won't affect focus range), so a 1680 mm total as others have said. By swapping the two TCs you could get to about 60 m, with the same final focal length.
Jon
Cocker Spaniels
Tapeman
Sliced Bread
Joined Jan 2004
Feb 12, 2016 20:10 |  #7
I haven't tried it but I have also seen a post stating that you do not lose infinity when stacking converters.
I used to stack my Canon version II extenders but (as you know) the MKIIIs cannot be stacked directly together.
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
Jon
Joined Jun 2004
Feb 12, 2016 20:59 as a reply to  @ Tapeman's post |  #8
Stacking converters, no. But add an extension tube into the mix and you WILL lose infinity. That's what extension tubes are used for. They're like a permanent extra X mm of twisting of the focus ring.
Jon
Cocker Spaniels
GyRob
Feb 13, 2016 01:23 |  #9
Thanks for reply's
I am using mkIII tcs and they wont fit together
The shots of ISS are just a bit of fun.
As for infinity loss im not sure how close the combo got to infinity focus I'm sure I was close but I could put the ISS out of focus so I went passed the focus and then back again jus as you manually work with any lens.
Rob.
Choderboy
I like a long knob
Gallery: 185 photos
Feb 13, 2016 03:39 |  #10
GyRob wrote in post #17896390 (external link)
Thanks for reply's
Rob.
I stack EF 1.4II and Sigma APO 2x with a 12mm extension tube between.
I can focus on the moon. I really don't care if infinity focus is reduced but I suspect it is not.
Dave
Image editing OK
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 7 years ago by TeamSpeed.
Feb 13, 2016 05:31 as a reply to  @ Choderboy's post |  #11
You can no longer focus on Jupiter now. :)
Choderboy
I like a long knob
Gallery: 185 photos
Feb 13, 2016 05:45 |  #12
TeamSpeed wrote in post #17896484 (external link)
Now there's a first world problem.
I was curious regards being able to focus beyond the moon and just confirmed I can.
100-400 II with EF 1.4III and Sigma 2x APO DG EX and 12mm tube:
IMAGE: https://farm2.staticflickr.com/1644/24628805279_4566c1017b_o.jpg
Dave
Image editing OK
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 7 years ago by TeamSpeed. (3 edits in all)
Feb 13, 2016 05:56 as a reply to  @ Choderboy's post |  #13
Viewing the glory of the universe is something for everyone, and always has been. However Jupiter is anywhere from around 2000 to 4000 times away than the moon. That all being said, if your farthest goal is the moon, then you are good! That means you can shoot as far as all the planets put end to end.
BigAl007
Gallery: 556 photos
Feb 14, 2016 08:37 |  #14
Since most AF lenses have a certain amount of movement past the actual infinity position, to allow both for thermal expansion etc and also to stop the AF motor driving the system into the hard stop and damaging the drive system, along with the relatively minor extension in relation to the focal length there is probably still room to get the lens and extenders/tube combination to achieve infinity focus. I don't recall how far past the infinity mark the version one 100-400's that I have rented in the past would go, but there seems to be a significant amount of movement available on my Sigma 150-600. Unfortunately, since I do not have either any teleconverters or extension tubes, it's not something that I can test, even though shooting with 1680mm of reasonable quality lens would be interesting. Back in the early 80's I did try out a 500mm mirror lens with a pair of cheap Vivitar 2× converters for 2000mm, as I recall the results on HP5 were not terrific.
Alan
4,064 views & 1 like for this thread, 7 members have posted to it.
1473 guests, 130 members online
