Thread started 15 Feb 2016 (Monday) 11:07
Laowa 12mm f2.8 zero distortion lens - a Samyang 14mm killer?
pulsar123
Gallery: 81 photos
Feb 15, 2016 11:07 |  #1
Stumbled across a mention of the newest lens from Chinese lens designer Laowa (Venus). I already own their 15mm 1:1 macro lens - a unique product of good quality, and they also have 60mm 2:1 infinity focus macro lens (another unique one).
Now it looks like they came up with a Samyang (Rokinon etc.) 14mm f2.8 killer - even wider (12mm) full frame lens, same aperture (f2.8), but addressing the most serious issue of Samyang - strong moustache type distortion. The new Laowa lens is claimed to have 0.2% distortion, which should be considered totally negligible for such an ultra-wide angle lens.
Not much information yet. There is a thread in Chinese apparently with many sample photos:
http://forum.xitek.com​/thread-1546399-1-1-1.html (external link)
And there is a Flickr group with no photos but with some technical specs:
https://www.flickr.com​/groups/2876587@N24/ (external link)
In particular,
Focal Length: 12mm
Largest Aperture: 2.8
Angle of View: 121.96°
Lens Construction: 16 Elements in 10 Groups (2 which are aspherical and 2 which are ED)
Iris: 7 blades
Shortest Focus Distance: 18 cm
Largest Reproduction Ratio: 0.2
Lens Dimensions: Approximately 74.8 diameter, 82.2mm long
Weight: 570 grams
This lens is fully manual and due to the front element, it does not allow screw-in filters. However, we specifically designed the lens hood to allow 70x200mm rectangular filter systems, a conventional lens hood is also available.
No information about pricing, though judging from their prior designs it should be competitive.
Of course, very important points - like whether it will match the legendary sharpness of Samyang 14mm, or whether the coma will be well controlled (important for astro photography) remains to be seen. But at this point it looks very promising, especially for full frame shooters.
6D, Tamron 24-70 f2.8 VC, 135L, 70-200 f4L, 50mm f1.8 STM, Samyang 8mm fisheye, home studio
MalVeauX
"Looks rough and well used"
Gallery: 2121 photos
Joined Feb 2013
Feb 15, 2016 11:19 |  #2
Lovely star spikes.
I might have to watch this one.
Very best,
msowsun
"approx 8mm"
Gallery: 18 photos
Feb 15, 2016 11:39 |  #3
Here are drawings of the lens:
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/photo16/12mm1.jpg~original
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/photo16/12mm2.jpg~original
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/photo16/12mm3.jpg~original
And some sample photos:
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/photo16/12mm4.jpg~original
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/photo16/12mm5.jpg~original
Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.8 STM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
Bassat
"I am still in my underwear."
Joined Oct 2015
Feb 15, 2016 11:48 |  #4
Looks like the same projection as my Rokinon 12mm f/2.8 FE. My initial reaction is this one is better. I'd like to compare.
pulsar123
Gallery: 81 photos
Feb 15, 2016 11:53 |  #5
Bassat wrote in post #17899171 (external link)
Not even close. Your Rokinon 12mm lens is a FF fisheye lens (= huge distortions; as a result it is a narrow purpose lens). The new Laowa 12mm is a rectilinear lens with extremely small distortion (meaning it is a general purposes UWA lens - great for architecture etc.). The proper comparison would be to Samyang/Rokinon 14mm f2.8 lens, or the new Canon 11-24 f4L lens.
Bassat
Joined Oct 2015
Feb 15, 2016 11:56 as a reply to  @ pulsar123's post |  #6
My guess is you've never used or seen the products of a Rokinon 12mm FE.
pulsar123
Gallery: 81 photos
Post edited over 6 years ago by pulsar123.
Feb 15, 2016 12:01 |  #7
Bassat wrote in post #17899184 (external link)
True. But I own the crop sensor equivalent of this fisheye lens, Rokinon 8mm, so know pretty well about the distortion these lenses produce (stereographic) - better than other fisheye lenses, but not even close to rectilinear UWA lenses.
Just try to reproduce the last sample shot posted here with your fisheye - no matter how hard you try, you won't be able to make the bottom row of chairs straight - instead it will look like a huge bow.
Bassat
Joined Oct 2015
Feb 15, 2016 12:35 as a reply to  @ pulsar123's post |  #8
Just mounted my Rok 12 and took some shots around the house. I concede. There is no comparison, if comparing the entire frame. I am going into town for a few (does that sound like Little Joe?) minutes. I'll snap a few shots of things more distant than my fireplace. I am sure I am on the losing end of this argument, by I am fielding a 180 degree lens compared to a 120 degree lens. How can they both be 12mm? Anyway, back in an hour or so.
msowsun
"approx 8mm"
Gallery: 18 photos
Feb 15, 2016 12:57 |  #9
Bassat wrote in post #17899243 (external link)
............... I am sure I am on the losing end of this argument, by I am fielding a 180 degree lens compared to a 120 degree lens. How can they both be 12mm? Anyway, back in an hour or so.
One is rectilinear and one is curvilinear. See Wiki definition: https://en.wikipedia.o​rg/wiki/Rectilinear_le​ns (external link)
pulsar123
Gallery: 81 photos
Feb 15, 2016 13:17 |  #10
Also check the plot on this web page:
http://www.lenstip.com …ish-eye_Introduction.html (external link)
It is for a crop sensor, so e.g. 8mm lens on a crop can have between 120 degrees (rectilinear) to 250 degrees (extreme fisheye projection) angle of view.
Jarvis ­ Creative ­ Studios
Gallery: 28 photos
Joined Aug 2013
Feb 15, 2016 13:30 |  #11
msowsun wrote in post #17899167 (external link)
These are sooc? No distortion correction? I might have to check this lens out further.
WEBSITE (external link)
Sony ZV-1 || Sony a7RIV || Sony a9 || Sony a1 || Sony FE 20mm f1.8 G || Sony FE 24-70 f2.8 GM || Sony FE 50mm f1.2 GM || Sony FE 90mm f2.8 Macro G OSS || Sony FE 135mm f1.8 GM || Sony FE 200-600 f5.6-6.3 G OSS || Godox speedlights and strobes
pulsar123
Gallery: 81 photos
Feb 15, 2016 13:39 |  #12
Jarvis Creative Studios wrote in post #17899313 (external link)
They claim the lens has 0.2% distortion, meaning no distortion correction is needed.
Bassat
Joined Oct 2015
Feb 15, 2016 14:08 |  #13
pulsar123 wrote in post #17899179 (external link)
Again, I concede. I shot several frames in which is it hard to tell I am shooting with a 12mm FE. If I intentionally exaggerate the effect, it is most certainly HUGE. I'm OK with posting a few comparison shots on request, but they are not really germane to this thread.
idkdc
Joined Oct 2014
Feb 15, 2016 18:24 |  #14
Wowza, color me interested in this. How is the venus macro? Should be a good indicator of bang-for-buck, no? Where do they sell these?
I like big cinema cameras and I can not lie
You other brothers can't deny
pulsar123
Gallery: 81 photos
Feb 15, 2016 19:24 |  #15
idkdc wrote in post #17899741 (external link)
It is not officially released yet. The info is from a Chinese rumor site. Given that they already posted a bunch of sample photos, the production should start pretty soon - probably in a few months.
42,087 views & 20 likes for this thread
Latest registered member is GBahry
778 guests, 255 members online
