Thread started 16 Feb 2016 (Tuesday) 20:33
Choice of connecting SSD interim backup drives to 6 GB/s ISATA or sSATA ?
Submariner
Joined May 2012
Feb 16, 2016 20:33 |  #1
Q1. Is there any difference? In speed or say overloading the CPU . instead of letting the PHC chipset do its work, or any bus constraints etc??
On the motherboard block diagram it only shows 5x SATA going to the C612 chipset, weirdly doesnt show the other 5x sSATA connectors? So no idea where they go to.
Q2. I have an old 500 GB ex laptop Tosh 7,200 rpm hdd. Thought I Would pop it in the rear quick release drive bays ( as there are 2 and I only have a budget for one 2TB HHd , so may as well use it.
But do I set this to AHCI or IDE ... Apparently I have to select something for every drive connected??
I assume AHIC... As thats what I set up for the Samsung.... But then thats an ssd?
Any help appreciated...
Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Post edited over 7 years ago by CyberDyneSystems. (4 edits in all)
Feb 16, 2016 21:03 |  #2
Not sure what Motherboard you are using but the C612 chipset is specced to handle 10 SATA ports.
AHIC, IDE is for optical drives and legacy drives at this point.
"iSATA" "sSATA"
sSATA likely just means "secondary" for the 2nd set of five ports.
The two sets means option of two RAID controllers,. two RAID 5 arrays etc.
I do not think there could be any speed advantage choosing one over the other.
CDS' HOT LINKS
Submariner
Joined May 2012
Feb 17, 2016 04:07 as a reply to  @ CyberDyneSystems's post |  #3
Really appreciate the explanation. Especially as the motherboard manual doesn't give one any explanation.
It a Supermicro X10SRA ( a workstation variant of a server board ) I guess being a server company they assume proper IT guys will be buying it and dont explain the basics. And boy do I need that!
Before deciding to do this I didnt even know what a PCIe slot was lol :)
Contrasting Asus and MSI manuals really convey the basics as well as all the Overclocking stuff.
The strange thing is the systems block diagram ( the one that shows how the PCIe slots are connected, and whick ones can swith the lanes to other ones, and what hangs off the chipset and which go directly into the CPU etc. It only shows 5 Sata connectors yet as you rightly said states the C612 chipset supports 10x 6GBs Sata ( 5x I's and 5x s's )
I am sure you are right as on the HP Z series they have Sata and sSata - where sSATA are secondary ones.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Feb 17, 2016 18:29 |  #4
Ah, Supermicro, they make some very mean Workstation and Server boards.
My last mega build "Skynet" graphics workstation was a SuperMicro, and I loved it!
Dual Opterons built back when AMD was faster (MUCH FASTER) than Intel's sad Pentium 4 offerings.
CDS' HOT LINKS
Submariner
Joined May 2012
Post edited over 7 years ago by Submariner.
Feb 18, 2016 05:11 as a reply to  @ CyberDyneSystems's post |  #5
Thanks thats very reassuring - looks like a good quality build, but as a novice the instructions are how can I say written for a professional who knows what he is doing.
Whereas looking at Asus and MSI they tend to explain the detail more. Plus there are loads of things like Trusted Server Management, and DOM that I hopefully I dont need.
I just hope the extra ( 40 ) PCIe lanes will deliver a benefit.
Honestly I initially only got into Supermicro, as there was a great deal for £187 whereas the normal price was £255 to £275, and they should understand working with Xeon processors. So for me 3 x16 slots with 16 electrical lanes, and another x8 in a physical x16 slot was attractive - just hope it makes a difference.
My difficulty is with things like the Intel AC wi fi card, it comes with a tiny Bluetooth power lead and I have no idea where that goes to on this board?
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/02/3/LQ_776397.jpg
Image hosted by forum (776397) © Submariner [SHARE LINK]
Sure the tiny tiny connector goes on the card, but the other end they say to put on some of the pins on a USB front header.
It has four holes, two are empty and the other two have + and -
I assume as its going on USB, that means its 5 Volts?
But the SM X10SRA only has one front panel usb connector, and that has been used with a plug thingy with 2 thick wires disappearing into the front-header ( I assume connecting the two 3.0 USB sockets there ).
Again I assume this wire is just to get 5V - I do hope it only needs that to power the bluetooth not the wifi.
I am puzzled why this little aic didnt get the power off the PCIe slot?
My alternative is to work out how to get this power from the EVGA Supernova 1200w P2 ( rebranded Superflower ) as I know it says it has a 5v rail - but stumped as to how to get to that, as there is a periferal lead going to a 4 pin Molex connector but I think that is 12v?? ..... :-/ or cannibalise one of the Sata power connectors .... Or just abort on the Bluetooth and hope this lead doesnt power the card for wi fi.
Guess I will know today as its power up time :-0
SM assume one will be using the two! Gigabit Lan connectors, whereas say MSI comes with Wifi built in.
110yd
Joined Jan 2005
Feb 18, 2016 19:14 |  #6
I would select AHCI to get the maximum performance out of an SSD.
IDE is somewhat old school. AHCI also gets you the ability to Hot-Swap a drive.
Hope this helps,
110yd
Submariner
Joined May 2012
Feb 19, 2016 07:21 as a reply to  @ 110yd's post |  #7
2,356 views & 1 like for this thread, 3 members have posted to it and it is followed by 2 members.
1277 guests, 136 members online
