Tommydigi wrote in post #17904594
Is the Sony A7RII really that much smaller? I think if your using a zoom or even an L prime I feel the size/weight difference is really not that much. At least that is what's keeping me away. I've considered switching for a while now but I just don't see much of a difference unless your talking the A6300 or Fuji.
Am I missing something?
it's not much smaller, *IF* you're using big lenses.
If you're mounting larger lenses frequently, then it's not that much smaller, however the body profile will allow you to fit the body into much smaller bags. To get an idea of how small it can be, I typically use the A7rii with 55mm f1.8 or A7r with 40mm f1.4. Like a restaurant outing or to the mall, I'll just carry the A7r/rii and 40mm f1.4. I have a tiny belt clip bag that fits the whole combo, or bigger shoulder bag that can fit 2 or 3 small lenses.
the bulk difference in body alone is pretty massive
the bulk and size savings is two fold.
1. Body size, significantly smaller
2. *Some* lenses. Forget about the GM lenses if you want small. This is where things arent straight forward, and a case by case basis.
- Voigtlander lenses soon to be native 10mm, 12mm, 15mm. The 15mm will carry the same design from the leica mount. It's a tiny lens. The 10 and 12, new designs, so who knows. I have the older M mount 12mm, works great on the A7rii, wont work well on any other model. Legit small lens.
- Loxia 21mm f2.8, much smaller than ZE 21mm f2.8
- Batis 25mm f2, moderate size, much smaller than ZE 25mm f2 equivalent, much smaller than EF 1.4 glass, however cant be compared directly
- Sony 28mm f2, small
- Sony zeiss 35mm f2.8, small
- Loxia 35mm f2, small
- Loxia 50mm f2, small
- Sony zeiss 55mm f1.8, small
- Batis 85mm f1.8, moderate size, a little smaller than an adapted 85mm f1.8
- Sony 28-70, moderate size, no weight to the lens, feels hollow
- Sony zeiss 24-70mm f4, moderate size
- M-Mount lenses. These require research, some may not work well, others will. Many options.
- All the rest of the MF lenses. You can find many unique glass that wont work so well on typical EF system, but very well on sony. Some notable lenses: OM 200mm f5, nikon 105 AIS, FD collection
aside from the size, you're also buying into the tech tools not offered by DSLR's, like face detection, AF coverage, realtime exposure, peaking in viewfinder, adaptability, eye focus (native lenses), IBIS for all lenses
Sony A7siii/A7iv/ZV-1 - FE 24/1.4 - SY 24/2.8 - FE 35/2.8 - FE 50/1.8 - FE 85/1.8 - F 600/5.6 - CZ 100-300 - Tamron 17-28/2.8 - 28-75/2.8 - 28-200 RXD
Panasonic GH6 - Laowa 7.5/2 - PL 15/1.7 - P 42.5/1.8 - OM 75/1.8 - PL 10-25/1.7 - P 12-32 - P 14-140
