FORUMS General Gear Talk Tripods, Monopods & Other Camera Support
Thread started 18 Feb 2016 (Thursday) 12:00
Varavon Multi-finder - early report
GJim
Post edited over 7 years ago by GJim. (15 edits in all)
Feb 18, 2016 12:00 |  #1
I received my order today. Ordered direct from the varavon.com web-site. $140 plus $30 shipping*. The price used to be near $250.
*I thought the shipping charge was a bit excessive, but turns out the unit ships from Korea. I ordered on Feb. 12th, received today (18th) - seems fair enough.
Photo links below.
Although not mentioned in any of the literature, the finder can be mounted on a gripped 7D. I was prepared to make modifications to the mount in order to have it work with the grip, but not necessary.
I haven't done any shooting with it yet, just getting everything mounted. The most likely use of this will be for shooting video from tripod and ground/low level, or still photography at ground/low level. The finder does have an Arca-Swiss mounting plate, so it can easily be used with my tripods, monopods, window/ground mount. The main portion of the finder can be easily removed, leaving only the bottom mounting plate. Since this will fit my tripods, etc., I will probably leave the mount on except when I know that I'll be shooting verticals using a tripod - then, I will switch to the Really Right Stuff 90-degree mount.
The loupe can be removed easily, a good idea if shooting low-level.
Unit comes with a nice carrying case and the necessary hex-tools for installation/adjustmen​t.
My photos of the multi-finder mounted on my 7D:
www.wyomerc.com/photog​raphy/equipment/varavo​n/DSCF1661A.JPG (external link)
www.wyomerc.com/photog​raphy/equipment/varavo​n/DSCF1662A.JPG (external link)
www.wyomerc.com/photog​raphy/equipment/varavo​n/DSCF1663A.JPG (external link)
www.wyomerc.com/photog​raphy/equipment/varavo​n/DSCF1664A.JPG (external link)
www.wyomerc.com/photog​raphy/equipment/varavo​n/DSCF1665A.JPG (external link)
www.wyomerc.com/photog​raphy/equipment/varavo​n/DSCF1666A.JPG (external link)
I don't know why the images won't embed - but, the links above will take you to the images on my web-site.
G'Jim c):{- ... 2x 50D (Both Gripped), 2x 7D (Both Gripped), 2x 5D Mk II (One gripped), 1x 60D, assorted glass (10-800mm), sundry accoutrements.
The beginner clicks the shutter and says "Let's see what I got." ... The experienced photographer thinks "How can I capture what I see?"
My Photography: http://www.gjimphotogr​aphy.com (external link)
Chet
Gallery: 132 photos
Feb 18, 2016 12:04 |  #2
GJim wrote in post #17903354 (external link)
Photo links below.
http://www./wyomerc.co​m/photography/equipmen​t/varavon/DSCF1661_201​6-02-18.JPG
www./wyomerc.com/photo​graphy/equipment/varav​on/DSCF1662_2016-02-18.JPG
www./wyomerc.com/photo​graphy/equipment/varav​on/DSCF1663_2016-02-18.JPG
www./wyomerc.com/photo​graphy/equipment/varav​on/DSCF1664_2016-02-18.JPG
www./wyomerc.com/photo​graphy/equipment/varav​on/DSCF1665_2016-02-18.JPG
www./wyomerc.com/photo​graphy/equipment/varav​on/DSCF1666_2016-02-18.JPG
I had to take the / out of your links after the www. to make anything work.
GJim
Feb 18, 2016 12:36 |  #3
Can't seem to get the images to link - will continue editing.
Fixed now - links should work properly.
GJim
Feb 18, 2016 13:05 as a reply to  @ Chet's post |  #4
Thanks, the links should work properly now.
1,950 views & 0 likes for this thread, 2 members have posted to it.
1549 guests, 135 members online
