OK I installed my Xeon E5 1650 V3 using a Noctua NH-D15 with two 150mm onboard PWM fans. The PC case deliberately is clear for airflow from the right intake to the MB, except a Samsung evo 850 bolted to the side wall. In addition there are 5 more 140mm Noctua PWM fans and 1 more 120mm fan. ( 3 intake and 3 exhaust ).
In Summary I imagined this would be massive overkill. See end - for airflow concept.
But when I turn on the PC the CPU hits 40C in a few minutes, and the PCH is at say 36C. Hmmm not so happy, I am just in the Bios looking around so no heavy workload at all.
I was surprised that with such good airflow, and a processor only cranking at 3.5ghz it was so hot, Honestly I was pretty disappointed the CPU temp was not nearer room temp!
Over the next 20 minutes the CPU temp will gradually rise to 52C and the PCH to 40C, and then all fans hit 1,500 rpm until the temps come back down to CPU 44C and PCH 37C.
If I tweak the PMW settings to Full Power all the time i.e. 8x fans at full tilt eg 1,500 rpm then it will maintain CPU at 42C and the PCH at 37C but TBH its unpleasantly noisy for the money.
Intel Ark says max temp at the IHS is 66.7 C
And the CPUs TDP is 140 Watts
Q1 is this too hot for a Xeon, basically doing nothing at 3.5 ghz i.e. Just looking at the bios settings!
Q2. Am I right that when the Std. turbo mode kicks in taking the CPU to 3.8 Ghz it will get hotter and the voltage supplied will be bigger.
The most worrying part for me is the CPU Voltage shows between 1.42V and 1.473V - note these are all at 3.5Ghz!
When the standard Turbo mode ( 3.8Ghz ) is required will the Voltage supply also go up?
Intel Ark says the correct voltage can be between 0.65V and 1.3V. So Even at a basic clock speed its way overvoltage, I would have hoped to see 0.66V or 0.7V considering the low workload and, that its running at its base specification not turbo mode.
I spoke to Intel support - just got the wrong person. Less knowledge than me!!
What I wanted confirmation of was :-
1. As the CPU speed remains / is rock solid at 3.5GHz, and one sees the temp and voltage vary a lot, is the Bios doing its job properly? Namely sending enough power to keep the CPU at 3.5ghz ?
2. Say the Bios was faulty and I updated it, and then The voltage regulator then only sent say 0.7 Volts to the CPU as not much is being done. Would that mean my CPU would slow down?
3. When it goes into Turbo mode , I assume the rise in speed will be matched by a corresponding Voltage increase?
4. If Intel say the max. voltage the CPU can operate at is 1.3V , is 1.472V harmfull long term?
Any prompt advice very much appreciate - should this be swapped.
In summary can I argue ( in Computer speak ) that under no load the CPU is out of spec, and its highly likely that when it goes into the standard torbo mode it will only get worse? Add some heavy video rendering and this will be come a real problem?
Planed Air Cooling Concept - backgrounf info:-
Was to let lots of fans run slowly ( Noctuas go down to 320 rpm ) where they are at there quietest; but have the capacity to create a hurricane if required. Also By using PWM one could let fan management target specific areas, say boost the CPU cooler fans speed and still run the case fans slowly.
And it works just as I hoped bar the 2 problems above . By that, the fans can all start at 300 to 350 rpm = beautifully quiet
As the CPU temp rises, then the CPU fans may speed up to say 900 rpm and the other 6 case fans stay at circa 300 rpm. Still a very pleasant noise level.
When the CPU gets very hot, all fans hit 1,500 rpm until the temp drops, and the cycle continues. Quite loud all at 1,500 rpm but that does not last for long, and anyway extreme cooling is reuired ... so the noise level is justified.
Perfect I am a happy bunny withthe way airflow works.
