Thread started 26 Feb 2016 (Friday) 23:08
17-55 efs focus help
jlstan
Gallery: 28 photos
Joined Feb 2012
Feb 26, 2016 23:08 |  #1
I am having trouble with my focus on my 17-55. It will not repeat focus at the same spot every time when I test it on a tripod using center point AF one shot. When I take say 8 shots maybe 1 or 2 will have correct focus. I tried doing a micro adjustment but the problem continues. I focused on the Energizer battery in the center for 8 shots. The batteries are 3 feet away from the sensor plane and are placed in a line at 45deg to the camera. Its like it floats all over. One time 6 of the 8 are ok than the next maybe 2 of the 8 are good. I set the focus ring to infinity and let it find focus for every shot. All shots were done with a 7d Mark ii which was just serviced by Canon within the last 2 months. Camera settings were F2.8 iso 800 one shot center point AF. Any thoughts as to what may be going on?
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/02/4/LQ_778147.jpg
Image hosted by forum (778147) © jlstan [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/02/4/LQ_778148.jpg
Image hosted by forum (778148) © jlstan [SHARE LINK]
Strontium
Durr?
Joined Jun 2011
Post edited over 7 years ago by Strontium.
Feb 26, 2016 23:32 |  #2
My first thought: Is IS on? My second thought: How stable is the tripod? Third: How are you actuating focus/shooting? With button on the camera or on a remote? Any sort of delay on the shot?
I am I
jlstan
Gallery: 28 photos
Joined Feb 2012
Feb 26, 2016 23:34 as a reply to  @ Strontium's post |  #3
IS is off 10 second delay using back button with mirror locked up and tripod is rock solid
jlstan
Gallery: 28 photos
Joined Feb 2012
Feb 26, 2016 23:38 |  #4
one more shot from the same series.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/02/4/LQ_778151.jpg
Image hosted by forum (778151) © jlstan [SHARE LINK]
Strontium
Durr?
Joined Jun 2011
Feb 26, 2016 23:39 |  #5
jlstan wrote in post #17914607 (external link)
Was about to ask about MLU. Might want to try the test with a remote. You haven't given any info on the tripod used. How solid the floor is, how drafty the room is, whether someone is bouncing on the couch 10 feet from the tripod, etc :D Eliminate the tripod before blaming the lens.
I am I
gjl711
Feb 26, 2016 23:41 |  #6
I'd try it with a bit more space between batteries and a better background to get a harder contrast edge.
Also, I assume that you have tried another lens and it focuses solidly thus narrowing down the problem to the lens itself and not the body.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Strontium
Durr?
Joined Jun 2011
Feb 26, 2016 23:43 |  #7
Another thought, as well: How high is the center column on the tripod extended?
I am I
jlstan
Gallery: 28 photos
Joined Feb 2012
Feb 26, 2016 23:44 as a reply to  @ gjl711's post |  #8
also shot with my 100mmL focus is spot on
Strontium
Durr?
Joined Jun 2011
Feb 26, 2016 23:46 |  #9
gjl711 wrote in post #17914613 (external link)
jlstan wrote in post #17914618 (external link)
Excellent point. Did you use the same technique with the 100mm? i.e. - 10 sec delay, back button?
I am I
gjl711
Feb 26, 2016 23:47 |  #10
Sounds like an issue with the lens then. Time to send it off to Canon.
::Gear::
jlstan
Gallery: 28 photos
Joined Feb 2012
Feb 26, 2016 23:52 as a reply to  @ Strontium's post |  #11
Shooting with a Manfrotto 055XPROB with center column all the way down. everything from the tripod to the floor is rock solid. No one else in the room. I will try a different setting next however I have been noticing this problem for quite some time now with this lens. I would try a few shots with the 17-55 doing a portrait shot and would get soft eyes every few shots. I than would switch to my 100mm L and get sharp shots every time
gjl711
Feb 26, 2016 23:53 |  #12
Mirror slap or a slight tripod wobble isn't going to cause a focus error that great. One other though, I am assuming that you are defocusing the lens the same way between shots.
::Gear::
jlstan
Gallery: 28 photos
Joined Feb 2012
Feb 26, 2016 23:53 as a reply to  @ Strontium's post |  #13
same technique with 100L
jlstan
Gallery: 28 photos
Joined Feb 2012
Feb 26, 2016 23:54 as a reply to  @ gjl711's post |  #14
setting focus to infinity between shots
jlstan
Gallery: 28 photos
Joined Feb 2012
Feb 26, 2016 23:57 |  #15
sux cause I hand hold my 150-600 sigma all the time and get better focus than this 17-55 is giving me
4,316 views & 2 likes for this thread, 7 members have posted to it and it is followed by 3 members.
1215 guests, 110 members online
