FORUMS General Gear Talk Tripods, Monopods & Other Camera Support
Thread started 27 Feb 2016 (Saturday) 19:08
Tripod for 500mm
Headshotzx
Feb 27, 2016 19:08 |  #1
So I'm sure this has been covered before, and yes I've read quite a bit of previous threads on the forum, but I've perhaps got a more specific set of conditions.
I just bought a pristine condition 500mm f/4L IS USM mk1, and will be using it on a 5D3 gripped, perhaps a 1DX somewhere down the line.
My head of choice will be the Sachtler FSB-8T head, which sports a 75mm bowl or removable stud (flat mount 3/8").
I tried shooting around the neighbourhood with my set of speedlock 75mm legs and it worked more than fine yesterday. However, I envision a situation where I would want to go really low, and that set of video legs will not do the trick.
I also have an RRS TVC-23 but a mate of mine said that it's not recommended, especially since I lose the ability to level the head (I have the RRS leveler but I need a shorter countersunk screw for the quick release arca swiss plate at the bottom).
He recommended that I get a 5 series Gitzo, which of course means that he thinks money drops from the sky, but more importantly I feel that a 5 series would put me in a situation where the photo sticks would be no different in weight / price / size as my video sticks, and I've all along relied on the portability difference.
So I have a few questions:
- Is the RRS TVC-23 actually good enough for consistent 500mm use with a 2kg video head? (I'm gonna test it out in an hours' time at a nature reserve)
- If no, would a Gitzo 4 series GT4552TS (traveler series) work better? There's a possibility that I can trade my RRS setup with a local copy of it.
- If no, what other set of sticks would be ideal, if money were no object but portability and the ability to do 75mm video bowl mod be of highest importance?
- And lastly, what if money was a thing? What other more cost-effective options would I have?
Hope you good folks can help me, and I'm definitely psyched to join the 500mm club :)
Zexun | Flickr (external link) | YouTube (external link) |
idkdc
Joined Oct 2014
Post edited over 7 years ago by idkdc.
Feb 27, 2016 19:12 |  #2
RRS TVC 34L should have a 75mm bowl, no? I imagine the fluid gimbal video head from RRS would be right up your alley, wouldn't it?
I like big cinema cameras and I can not lie
You other brothers can't deny
ShadowHillsPhoto
Gallery: 174 photos
Joined Aug 2015
Feb 28, 2016 08:57 |  #3
Headshotzx wrote in post #17915555 (external link)
On the RRS site under Q&A for the TVC-24L:
SimonM: Hi, I have just ordered the TVC24-L and already own the BH-55. I intend using a Nikon D810 + 400mm F2.8 as the heaviest combination. Will the tripod be man enough or do I need to reconsider.... before despatctch!
CSR ScottN: All of our Series 2 tripods are rated to carry 40 lbs and solidly hold a 400mm lens with no camera shake. Your combination will work perfectly.
If RRS is confident it can take a 400mm f2.8 with a 2lb ballhead it should be fine with a 500mm f4 with a 4lb video head.
SailingAway
Joined Sep 2013
Post edited over 7 years ago by SailingAway.
Feb 28, 2016 11:29 |  #4
If you want to go low-low, traditionally, in video bowl-style tripods of 100 and 150mm you'd have sticks, sawed-off sticks, and a high hat. Sawed off referring to about half-height, because these sticks were actually sticks made of wood, and the typical design was one stage (two sections).
Now, 2-stage (3 section) is standard, you don't see sawed-off any more with alu and CF.
But, you can still buy a high hat! The selection in 75mm is quite meager, but they *are* out there. This could be great if you want to retain ball leveling.
Typically, a high hat is just high enough to clear the screw handle. A lens height of about 10" is typical. Moving the head between tripod and hat is a matter of 3 or 4 minutes.
This one is shown bolted to a piece of plywood, a very traditional approach:
http://www.indurogear.​com/dr-hi-hat-tripod-set.html (external link)
Also, for a wider range of choices, there are 100mm bowl to 75mm ball adapters, so you could use a 100mm high hat.
Here's one in the old style:
http://www.filmtools.c​om …-75-75mm-ball-hi-hat.html (external link)
A modern approach, which must be bolted to a base:
http://www.aviatorcame​ragear.com/product/mic​ro-hi-hat-75mm/ (external link)
Or, you could get one of these:
http://www.bhphotovide​o.com …529B_529_Hi_Hat​_with.html (external link)
*and* a 100-75mm adapter
http://www.bhphotovide​o.com …19_319_75mm_to_​100mm.html (external link)
From the upper left corner of the U.S.
Photos, Video & Pano r us.
College and workshop instructor in video and audio.
70D, Sigma 8mm, Tokina f2.8 11-16, Canon EF-S f2.8 17-55, Sigma f2.8 50-150 EX OS, Tamron 150-600VC. Gigapan Epic Pro, Nodal Ninja 5 & R10.
johnf3f
Feb 28, 2016 15:26 |  #5
Intrigued at your choice of head - are you shooting primarily video with the 500? If stills are your game then I would favor a Wimberley 2 - probably why I have one!
Your RRS tripod will certainly do the job and do it pretty well too! I would prefer the next series up (3 series) from either Gitzo or RRS.
I use the Canon 800mm F5.6 L IS on a 3 series Gitzo (3530LS) with a Wimberley 2 head. I have tried the larger 5 series but could find no practical advantage for shooting stills - video is a different game and I have absolutely no idea about it!
Were I in your shoes (shooting stills) I would simply put a Wimberley 2 on your RRS and go out and shoot! Then ONLY if you find a problem with the setup (I don't think you will) would I change the legs. I don't get the thing about leveling bases, whilst the do slightly speed setting up, to me they are dead weight most of the time and can reduce rigidity if you don't buy a top quality one.
Still intrigued by your choice of head.
Life is for living, cameras are to capture it (one day I will learn how!).
Headshotzx
Feb 29, 2016 04:23 |  #6
Thanks for the comments, guys, I'll go one by one.
idkdc wrote in post #17915561 (external link)
Yeap, and also really much more expensive than the 23 that I own. Would there be an alternative from gitzo worth looking into?
ShadowHillsPhoto wrote in post #17916233 (external link)
That's interesting. Problem is that they're talking about 400mm, and we're speaking of 500mm and sometimes 1000mm.
SailingAway wrote in post #17916426 (external link)
That's a very detailed response, I really appreciate it :) I was asking a few FB groups about the induro, and I mentioned that they weren't on sale anywhere now. Wonder what happened to them.
The Manfrotto high hat would be the next best alternative, but it's another 2kg just to go low. Rock solid though, I've used it before on video gigs.
johnf3f wrote in post #17916744 (external link)
I do photography with my 5D3 and video with the Sony FS7... so if say I travel for a safari gig, or feel like I'm ready to do some more wildlife video, it would make sense to bring the FSB8. The FSB8 also packs down smaller than the full sized wimberley. With the wimberley being 1.4kg and the fsb8 being 2.1kg, that little 600g difference won't matter to me. That, and it's 600 usd (or whatever used prices go at these days) that I don't have to spend.
I underlined the part where you mentioned your gear and experience. I was contemplating moving to a 3 series but that friend of mine said that the size of the stage really matters a lot, especially with the 75mm fluid head, and told me it'd be a bad idea if I got a 3 series. He told me look at 4 series or 5 series... which would be beastly to carry around, no?
Headshotzx
Feb 29, 2016 08:37 |  #7
What do you guys think about this?
http://www.bhphotovide​o.com …x_6_SECTION_TRA​VELER.html (external link)
I'm 165cm (5' 4"), and the sachtler head + lens foot to VF is about an additional 20cm + 18cm, meaning to say that if I'm to photograph something level, the tripod need only be 125cm. Which would probably mean that I can choose not to open the last leg unless needed. This would be helpful for me when I travel by car or by plane (check-in inside suitcase).
Thoughts on stability? I just reserved the sale of my RRS TVC-23 + leveler, so I'm good to go for a new purchase.
idkdc
Joined Oct 2014
Feb 29, 2016 09:09 as a reply to  @ Headshotzx's post |  #8
You need the bowl adapter as a separate purchase? Fyi.
idkdc
Joined Oct 2014
Feb 29, 2016 09:11 |  #9
Headshotzx wrote in post #17917388 (external link)
No alternative from Gitzo on the fluid video head gimbal. Plus side is that it's one head to rule them all and specifically for supertele use, and also breaks down for storage.
Headshotzx
Post edited over 7 years ago by Headshotzx.
Feb 29, 2016 09:31 |  #10
idkdc wrote in post #17917577 (external link)
Yes I'm aware of that, thanks for bringing it up though.
Am thinking of going for it after watching this video. Seems like the 2nd (from bottom) leg section is about the same as a 4 series' last one.
https://www.youtube.co​m/watch?v=IkM6YZe-O24 (external link)
Based on the attached image, if I compare the 2 tripods that I'm looking at, it would seem that as a system, the price and extended length really doesn't differ too much. I would have to decide whether I prefer a more compact and heavier setup, or a lighter longer setup with possibly greater stability (due to leg sections and leg diameter).
Tough call, though.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/02/5/LQ_778609.jpg
Image hosted by forum (778609) © Headshotzx [SHARE LINK]
idkdc
Joined Oct 2014
Feb 29, 2016 11:51 |  #11
Headshotzx wrote in post #17917612 (external link)
Tough call, though.
Hosted photo: posted by Headshotzx in
./showthread.php?p=179​17612&i=i172030204
forum: Tripods, Monopods & Other Camera Support
Probably depends on if you intend to fit the tripod in carry on or not (risky to stuff a 1k tripod in checked luggage, I would think?). I think the TVC34L is marketed as the right size for this without sacrificing height (4-section), but it does cost a bit more. The TVC33s is also smaller, at the cost of max height, but maintains 3 sections at the smaller min length at a lower price: http://dancarrphotogra​phy.com …ally-right-stuff-tvc-33s/ (external link). I found this guide useful a while back http://www.reallyright​stuff.com/Guides-Support-for-Tripods (external link)
idkdc
Joined Oct 2014
Feb 29, 2016 11:57 as a reply to  @ Headshotzx's post |  #12
And here's a comparison that you might find useful between Gitzo and RRS: http://scottgrobarek.b​logspot.com …stuff-tvc-34l-review.html (external link)
Headshotzx
Feb 29, 2016 12:51 |  #13
Interesting comparison between Gitzo and RRS. The top stage difference looks huge here - something that I might appreciate at 1000mm. Considering that it's also able to accept a 100mm bowl, this might come in handy as a hi-hat for video production use if I'm thinking of doing 100mm heads.
I tried stuffing the TVC-23 with leveler that I'm holding into my luggage and it's just right, diagonally. If it's a 3 series the top stage might be too large for it.
I would think that the gitzo at 50cm would be able to be placed in without having to resort to diagonals, which is one consideration because I might want to travel for birding or wildlife.
Yet the thought of lugging 2.9kg (almost twice that of my current TVC23 legs now) phases me a bit. Or maybe I'm just a wuss and haven't gotten used to trekking with much gear yet.
idkdc
Joined Oct 2014
Feb 29, 2016 13:34 |  #14
Headshotzx wrote in post #17917860 (external link)
I think the top stage of the 2 and 3 series are fundamentally different, no? I would imagine that the 2 series top stage is taller because of the lack of bowl. Which one does 100mm bowl? The RRS or the Gitzo? I didn't catch that detail before.
Headshotzx
Mar 01, 2016 22:09 |  #15
idkdc wrote in post #17917907 (external link)
The Gitzo does a 100mm bowl.
Anyways, by a stroke of luck, there was somebody selling a GT4542LS at an extremely attractive price. Dude was previously a birder as well, and who also used the FSB8 for birding.
It's perfect for me now, and the increase in diameter of the stage is astounding.
Thanks for all your help and the links to other reviews!
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/03/1/LQ_778881.jpg
Image hosted by forum (778881) © Headshotzx [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/03/1/LQ_778882.jpg
Image hosted by forum (778882) © Headshotzx [SHARE LINK]
5,336 views & 2 likes for this thread, 5 members have posted to it and it is followed by 2 members.
Tripod for 500mm
1025 guests, 107 members online
