Thread started 29 Feb 2016 (Monday) 06:38
Weighting or Counter-balancing a Boom on Matthews C-Stand
frozenframe
Gallery: 189 photos
Joined Jun 2013
Feb 29, 2016 06:38 |  #1
I have the Mattews 40" C-Stand with boom This One (external link). Until yesterday I really hadn't much opportunity to use it boomed out holding my 48" Octobox with FP Rovelight. It was a little un-nerving. I had sandbagged all the legs, but it still seemed a little tippy.
The opposite end of the boom there's no hook or anyway to place a sandbag to counter-balance. I've tried finding an attachment accessory so that I can, but haven't. Is there such a thing, or how would someone go about counter-balancing it?
Ron
My Gear List
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Feb 29, 2016 07:42 |  #2
the grip arm is not a "real" boom, but it will work.
i use one of these on the opposite end of the grip arm http://www.bhphotovide​o.com …REG&ap=y&m=Y&Q=​&A=details (external link)
you can get cheaper ones (store brand) that do the same thing. I put a 3/8 eye hook into one of the threaded holes with a nut to keep it tight. I can then hang anything from the end of the grip arm.
the other trick for stability is to make sure the longest leg is under the light. If I had people walking around my light set up, i would probably get a stand with a wider base and true boom.
OceanRipple*
Joined Dec 2014
Post edited over 7 years ago by OceanRipple*. (2 edits in all)
Feb 29, 2016 07:45 |  #3
frozenframe wrote in post #17917462 (external link)
Hi, That's an Extension arm and for lightweight lights you may not need to counterbalance them. But for the Rovelight, I agree, a counter-weight gives peace of mind. For a fitting, anything that grips the 5/8 in (16 mm) rod can be used - I use an Ebay Mini Jaws clamp and hang a shot-bag with its strap on the arm, just above the clamp.
http://www.ebay.co.uk …47d7eb:g:obgAAM​XQydtTKrib (external link)
Edit, Oops: as per LHBs ideas.
frozenframe
Gallery: 189 photos
Joined Jun 2013
Post edited over 7 years ago by frozenframe.
Feb 29, 2016 08:27 |  #4
Left Handed Brisket wrote in post #17917497 (external link)
Looks like that or Impact's model would be the way to go. When purchasing the Matthews C stand I thought the arm was a boom arm. I mean the whole thing is solid as heck, and heavy.
I looked at the possibility of just getting another actual boom-stand setup, however not in my current budget. I was also thinking about just getting another grip head to put on the end, but the cost would be more than what you suggested.
I think I'll get THIS (external link)
Thanks.
Ron
My Gear List
Wilt
Post edited over 7 years ago by Wilt. (2 edits in all)
Feb 29, 2016 08:38 |  #5
Why can't you use a counterbalance weight like this one, clamped on at the opposite end of the boom from the light?
http://www.bhphotovide​o.com …unter_Balance_W​eight.html (external link)
If 10 lbs is too much (which is not likely since you use a 5.5 lbs. monolight), they have a 3 lb. version which is similar, but suited for a lighter head-only powerpack+heads setup.
FarmerTed1971
fondling the 5D4
Gallery: 66 photos
Joined Sep 2013
Post edited over 7 years ago by FarmerTed1971.
Feb 29, 2016 08:41 as a reply to  @ Wilt's post |  #6
The nano clamp, eyelet and a cheap sandbag would be the way I'd go. In fact I think I'll try this, thanks!
Getting better at this - Fuji X-t5 & X-t3 - 16 1.4 - 35/50/90 f2 - 50-140 - flickr (external link) - www.scottaticephoto.co​m (external link)
OceanRipple*
Joined Dec 2014
Feb 29, 2016 11:38 |  #7
Hi, Genuine Nano clamps are fine for gripping 16 mm arms - as are some of the Ebay equivalents.
But the Impact item that frozenframe linked to is not quite the same. Some varieties have two angles in each jaw piece - IMO you're much better off with the variety whose jaws closely resemble those of a Nano clamp ie single angle per jaw piece. The grip is much more reliable.
i.e not this type:
http://www.ebay.co.uk …4d207b:g:~9QAAO​SwPe1UI-FF (external link)
for instance.
Gallery: 15 photos
Joined Jun 2011
Feb 29, 2016 13:25 |  #8
99.9% sure i bought the Impact model and it works fine.
frozenframe
Gallery: 189 photos
Joined Jun 2013
Feb 29, 2016 19:50 as a reply to  @ Left Handed Brisket's post |  #9
I looked at the Impact model, it appeared identical to the Manfrotto, so I ordered it.
Thanks everyone for your kind assistance. :-)
Ron
My Gear List
RicoTudor
Joined Jul 2014
Feb 29, 2016 20:42 |  #10
The general-purpose item for gripping an arm is a gag, seen at left in Matthews form:
IMAGE: http://patternassociates.com/rico/fm/mattgag.jpg
Whether considered a grip arm without the arm, or two adjoined knuckles, you can run the handle of a weight bag through the 2nd hole and it's going nowhere. The Manfrotto c/w mentioned by Wilt is another solid product, but designed for the larger dia of a real boom (I use two of the 15-lb version on my D650). Personally, I recommend using a larger stand—secure as-is with a 40" grip arm, and always a good investment. :)
Canon, Nikon, Contax, Leica, Sony, Profoto.
frozenframe
Gallery: 189 photos
Joined Jun 2013
Feb 29, 2016 21:06 as a reply to  @ RicoTudor's post |  #11
So how is the Matthews C stand not considered a large stand? This thing is built like a tank, and heavy. I can see that it could use a wider base. Plus when the arm is setup correctly in the knuckles, or gags, it will not loosen. I think the arm would bend before they'd loosen.
The T-handles are made so it's near impossible to strip them. I've put some serious torque to them.
When I was shopping for another light stand, I was looking for something heavy duty to support my octobox and monolight, that was also had a boom arm. I do have a couple of other light stands that are what I call medium duty. I have placed my monolight and softbox on one without too much concern. However I don't think I would want to use them for booming.
Ron
My Gear List
RicoTudor
Joined Jul 2014
Feb 29, 2016 22:00 |  #12
frozenframe wrote in post #17918525 (external link)
I don't have any large stands but C-stands, being designed for modifiers, are far from large. Between the baby pin, limited loading and footprint, I would classify C-stands as small (even if well built). At the very least, I expect a medium stand to offer a junior fitting. Here is the Matthews Medium Overhead supporting a few 2x3 panels:
IMAGE: http://patternassociates.com/rico/fm/juniorroller.jpg
My fully-loaded junior boom adds 60 lbs, which is just 2/3 the limit for this stand. I don't even own sandbags. :)
Gallery: 15 photos
Joined Jun 2011
Post edited over 7 years ago by Left Handed Brisket.
Feb 29, 2016 22:06 |  #13
well, i've seen some folks who don't really even consider c-stands real light stands. Which makes sense considering older large monolights and hot lights for video etc. With today's light weight, high power lights, it's a little different story.
For me, it was an inexpensive option that was of course very sturdy, but had a small footprint for my small home studio. I don't take many portraits so having people bouncing around an potentially knocking over a stand is not really an issue.
a true boom stand has a much larger foot print, this one is about 44 inches.
http://www.bhphotovide​o.com …_Heavy_Duty_Boo​m_and.html (external link)
edit: rico right on time :D
PhilF
Feb 29, 2016 22:25 |  #14
RicoTudor wrote in post #17918599 (external link)
looks like a "christmas tree of flags"
http://philfernandezph​otography.com (external link)
http://www.philfashion​photography.com (external link)
https://www.instagram.​com/philfernimagery/ (external link)
https://www.facebook.c​om/philfphotography (external link)
PhilF
Feb 29, 2016 22:31 |  #15
your link doesn't say boom...it says c stand with grip and arm.
Get a real boom arm...not a regular arm. Use the right tool to avoid equipment damages.
3,095 views & 7 likes for this thread, 7 members have posted to it and it is followed by 2 members.
926 guests, 118 members online
