Thread started 29 Feb 2016 (Monday) 13:14
need mid-stand clamp for umbrella & speedlight
ncjohn
Feb 29, 2016 13:14 |  #1
All the clamps that I've found for mounting a speedlight and umbrella on a light stand sit on top of the stand. I'm looking for one that will clamp onto the middle of the stand. Does anyone know of something like that?
flowrider
Gallery: 127 photos
Post edited over 7 years ago by flowrider.
Feb 29, 2016 13:22 |  #2
Manfrotto Super Clamp? Or use a boom to get it away from the stand.
~Steve~
~ My Website-stevelowephoto.com (external link) ~ Facebook (external link)
Feedback Feedback Feedback
Alveric
Gallery: 38 photos
Post edited over 7 years ago by Alveric.
Feb 29, 2016 13:32 |  #3
Superclamp and umbrella bracket, or, for more flexibility a grip arm with the superclamp (http://www.bhphotovide​o.com …KIT_Grip_Kit_an​d_Bag.html (external link)) and the umbrella bracket.
You could also benefit from the Manfrotto 244 flexible arm (http://www.bhphotovide​o.com …able_Friction_M​agic.html) (external link), with or without camera bracket: https://www.youtube.co​m/watch?v=DB159XXbSIs (external link)
OceanRipple*
Joined Dec 2014
Feb 29, 2016 15:18 |  #4
ncjohn wrote in post #17917882 (external link)
A Mf Superclamp - but - add the 6 in extension arm - it adds an upright spigot at the end, giving nice clearance from the mother stand.
For a really heavy light, use two, like this:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/02/5/LQ_778649.jpg
Image hosted by forum (778649) © OceanRipple* [SHARE LINK]
RicoTudor
Joined Jul 2014
Feb 29, 2016 20:56 |  #5
Grip arm for me.
Canon, Nikon, Contax, Leica, Sony, Profoto.
ncjohn
Feb 29, 2016 22:44 |  #6
So, researching all your suggestions, looks like what I need is called a grip head. Now, more research.
Thanks folks.
bpalermini
Gallery: 203 photos
Joined Mar 2011
Feb 29, 2016 23:34 |  #7
I'm not sure how much this will help you but it may give you an idea of how to do it.
I use an ancient mounting bracket from a Larson Reflectasol which was a high quality umbrella type reflector from many years ago. I use it for sports headshot to create a clamshell lighting scheme with a minimum of equipment to haul around.
IMAGE: http://www.palermini.com/Family/Tripod/i-H9F7Tq9/0/XL/Umbrella%20Bracket%201-XL.jpg
IMAGE: http://www.palermini.com/Family/Tripod/i-VfFDgbT/0/XL/Umbrella%20Bracket%202-XL.jpg
IMAGE: http://www.palermini.com/Family/Tripod/i-WKm2wzQ/0/XL/Headshot%20setup-XL.jpg
Bob
R6II, R6, EF 16-35L II 2.8, EF 24-70L II 2.8, RF 50 1.8, EF 100L Macro 2.8, RF 70-200L 2.8, EF 100-400L II, EF 200-400L 4, EF 1.4xIII, EF 2xIII, 580EXII, YN560IV, RRS TVC23 + BH55, Fuji X-E2, Fuji X30, LRCC, PSCC
My Web Site (external link) | My Sports Portfolio (external link) | Instagram @bobpal
ncjohn
Mar 01, 2016 00:09 as a reply to  @ bpalermini's post |  #8
Well, Bob, your shot #3 is exactly what I want to do. :) And the fact is, 30 or so years ago I had the same equipment! That's hilarious! Unfortunately, about 13 years ago I got the idea that I wasn't going to need them anymore (or the stands, or the Vivitar 283's, or the Quantum batteries... sigh) and sold them all. Oh well. :)
You ever heard of Finelight? The guy made all these amazing diffusers, reflectors, and stands, all from PVC. Bulky but they worked really well and cost pennies.
It's from the same era.
bpalermini
Gallery: 203 photos
Joined Mar 2011
Post edited over 7 years ago by bpalermini.
Mar 01, 2016 00:36 |  #9
Here you go (external link), $23.
Edit: Actually if you search for larson reflectasol at eBay there are quite a few options, some even less expensive.
The setup works pretty well. You do have to be aware of the light stand in front of you and keep it out of the frame.
Bob
OceanRipple*
Joined Dec 2014
Post edited over 7 years ago by OceanRipple*.
Mar 01, 2016 02:14 |  #10
ncjohn wrote in post #17918665 (external link)
Thanks folks.
Maybe. An Extension Grip Arm typically has a Grip head permanently fixed at one end. You'd probably want an extra spare Grip head to be able to grip the arm midway along its length. A Grip head on a stand is typically used at the stand's top - where the stand should have a full Baby pin top fitting - not just the more usual 5/8 X 35 mm spigot. All this can offer a rock solid solution but has costs, $ & Kg.
For a Speedlite plus shoot through umbrella, a Mf Superclamp-6 in Ext piece-spigot/stud-umbrella adapter, would be my choice. (There is a 50cm version of the extension instead of 6 in.)
ncjohn
Mar 01, 2016 11:27 |  #11
bpalermini wrote in post #17918758 (external link)
Well so there are! Thanks Bob.
RicoTudor
Joined Jul 2014
Mar 02, 2016 01:24 |  #12
Here's my solution to OP's problem. :) I do have a certain Manfrotto umbrella adapter, but its popularity and metal build cannot disguise the awkward handling, uncertain hold, and faulty geometry. Standard grip gear is far sturdier and allows on-axis positioning:
IMAGE: http://patternassociates.com/rico/fm/umbrella014.jpg
Grip arm holds the umbrella shaft and is gagged onto the stand riser. The (lower) flash is gagged onto the grip arm at an optimal position. Note the perfect light distribution from the umbrella—sorry, no shoot thru. Closeup of the business end:
IMAGE: http://patternassociates.com/rico/fm/umbrella015.jpg
This grip gear may seem expensive, but note that it can be assembled into myriad configurations (just like Tinker Toys). What gets expensive is buying the same support repeatedly because vendors impose their proprietary connectors and dimensions.
Couple of caveats to my solution: First, I would never clamp onto a alu riser since they are easily crushed. Second, the gag does not operate correctly on tubing above 5/8". For wider sections of riser, you need a clamp (pipe, Matthellini, Mafer) with baby pin or grip head.
2,460 views & 1 like for this thread, 6 members have posted to it and it is followed by 2 members.
1057 guests, 103 members online
