gonzogolf wrote in post #17920333
Sodium amd mercury lights are not full spectrum light sources so its impossible to get an accurate white balance. You cant balance colors that arent there in the light. You can shift the colors around to make the colors seem somewhat natural but if the light source doesnt hace enough red you cant get a true balance. Try using your card on full spectrum light sources (not vapor or fluorescent).
To reinforce the point: "Sodium amd mercury lights are not full spectrum light sources so its impossible to get an accurate white balance. "
Many modern fluorescent CFL bulbs (but not all) can be quite good for overall balance when corrected with WB shift and Tint shift. I routinely shoot things after darl for posting on POTN or other forums under home CFL illumination, and it corrects quite nicely...NOT true of sodium vapor or mercury lights however!
Shot under CFL and corrected
Shot under daylight (note the Colorchecker card is on grass, as evidence)
Also, due to the small size of your calibration cards, it may be difficult getting the card to fill the frame of your camera, which provides opportunity for in-camera custom WB to be thrown off a bit. Rather than do Custom WB in camera, it is better to use these particular cards by including them in the scene and take one reference photo which can be used with the WB eyedropper on the card, then replicate that WB and Tint setting is to other photos (with Sync in LR, for example).
