gonzogolf wrote in post #17922310
You can use the perspective distortion tool on photoshop to fix some of the keystoning although that might necessitate some cropping. Don't edit the lines, they are part of the image.
Thanks, I'll play with that now. That was what I was thinking of doing, but the tool is different in the current version of PS than what I am used to, and I wasn't sure if there was a better way.
(Edit: Ah, yeah, this is actually a new tool that wasn't even in my old version of PS.)
(Edit2: Ok, yeah, this tool is going to do what I want, I just need to work with it and figure out how many degrees to angle in to fix it. What you see above was already cropped slightly, so I'm not going to lose any of the mural doing this by working on the original RAW again and copying my edits after the crop to the new edit. Thanks!)
I don't want to remove the lines completely, I just want to avoid sharpening them so much when I sharpen the rest of the image.
