Thread started 03 Mar 2016 (Thursday) 13:27
Cokin Z Pro Filter Holder
picworx
Joined Jun 2005
Post edited over 7 years ago by picworx.
Mar 03, 2016 13:27 |  #1
I have the above but am confused at how to use 3 filters in it? The first slot closet to the lens hardly holds the filter properly, the filter is so loose, the second and third slots out work fine. So perhaps this unit is assembled wrong somehow?
Can someone help here?
The Print is What Really Matters
docholliday_sc001
My hypocrisy goes only so far.
Joined Jul 2011
Post edited over 7 years ago by docholliday_sc001.
Mar 03, 2016 14:08 |  #2
The closest slot to the lens is for the round filters, such as polarizers. The other two slots (further out) are for the rectangular/square sheet filters that slide up and down.
picworx
Joined Jun 2005
Mar 03, 2016 19:20 as a reply to  @ docholliday_sc001's post |  #3
Thanks for the response, what type of round polarizer goes in the first slot there are all different sizes and my 77 mm polarizer wont work? Its too small.
Still confused here
docholliday_sc001
Joined Jul 2011
Post edited over 7 years ago by docholliday_sc001. (2 edits in all)
Mar 03, 2016 19:45 |  #4
Each Cokin system has it's own polarizer(s) that work with the respective holder. You can't use a screw-in polarizer with the holder, unless you screw it in behind the mount ring.
It's something like 103mm and doesn't have threads. It has a flat flange on the outside that slips into the closest slot. Singh-Ray and some others also make a compatible filter for the system.
The best thing that you can do is get a copy of the Cokin reference book/catalog. It shows you all the filters, their ID numbers, and what they do. There are multiple systems, A/P/Z/X, so be sure that you look at the right section for the Z system.
Here's a shot of how the filter mounts: http://www.2filter.com​/cokin/cokinzpro.html (external link)
Alveric
Gallery: 38 photos
Mar 03, 2016 20:40 |  #5
You have to use a kind of drop-in polariser like this one: http://www.bhphotovide​o.com …der_68_031144r_​4_x_4.html (external link)
B+W used to make a Kaesemann version but they seem to have discontinued it.
picworx
Joined Jun 2005
Mar 04, 2016 17:51 as a reply to  @ Alveric's post |  #6
So it appears that only 2 rectangle filters can be used with this holder and those are the outer 2 slots?
Alveric
Gallery: 38 photos
Mar 04, 2016 18:26 |  #7
I use the closest slot for my Big Stopper (it's got foam light sealing, which makes it thicker than the normal filters), but for that I had to reverse the pins that hold the adapter ring so that they can be flush with the outer face of the filter holder, otherwise they'd scracth the foam and maybe even the filter.
At length, yes, you can only use the two outermost slots; which, in a sense, it's fine, since too many filters in front of your lens would degrade the picture quality. There might be a way for you to buy the parts to add a new slot: the screws look long enough to accept just one more piece. You'd have to check Cokin's web site and documentation to see if this is a viable option.
docholliday_sc001
Joined Jul 2011
Mar 04, 2016 20:26 |  #8
picworx wrote in post #17923770 (external link)
Yes, the two outer ones are for rectangular - the inner only for circular. Be careful, the larger the stack, the more prone to flare because of the plate filters. Be sure to shade the stack with a hood, hat, or flag! Plate filters flaring isn't always noticeable until later when it seems that contrast is very low and the shadows just aren't black enough.
4,301 views & 1 like for this thread, 3 members have posted to it and it is followed by 2 members.
1510 guests, 132 members online
