MikiG Goldmember 1,179 posts Likes: 401 Joined Feb 2011 Location: Ireland More info | Mar 05, 2016 16:14 | #1
Davenn Senior Member More info Post edited over 7 years ago by Davenn. | Mar 06, 2016 02:53 | #2
A picture is worth 1000 words
Mar 06, 2016 09:26 | #3 What camera body are you using for this and is it modified for astrophotography? Pay no attention to the fact that the blue line is labeled "Canon" -- every camera intended for normal photographic use has such a filter and has a ramp-down blocking curve very similar to the one you see in this graph. To get around this problem, astro-imagers interested in photographing subjects with a lot of Hα will use cameras outfitted with a filter designed for astro-imaging or "full spectrum" cameras that have the filter removed entirely. The Canon 60Da and the Nikon D810a are both astro-imaging cameras that allow nearly all light in the visible spectrum to pass through... and then do a hard-cut at the 700nm point (to keep out IR). Some people will buy a camera and send them out to be modified (there are people on the web who do it) or do the modification themselves (for the technically adept and brave ... this does require significant disassembly of the camera and risks damaging it. And of course if the camera had a warranty... it doesn't anymore. If you break it... you get to keep both halves.) The "full spectrum" cameras don't have a filter ... and that means they have to use a "Luminance" filter when sooting. A luminance filter simply allows the full visual spectrum (everything from 400-700nm) to pass, but blocks everything else. Light of different wavelengths bends by different amounts as it passes through the lens elements, which means that when the camera is focused to the middle of the visible spectrum (stars are sharp) then by the time the light reaches the sensor, it doesn't all focus at the same point (some light wants to come to sharp focus just slightly in front of the sensor ... or just slightly behind the sensor. This means UV and IR light won't focus the same as visible light and that will leave your images looking a bit soft. To correct for it... the luminance filter just blocks those wavelengths (as an added bonus to having a full-spectrum camera, you can easily use it to do IR photography by using a filter to allow the appropriate IR wavelength you want to pass through, while blocking all others.) I suspect you're using a standard camera and it's unable to collect much of the Hα light. BTW, this is really only a problem for "emission nebulae" (such as the Rosette here) that glow richly in Hα. Stars, star clusters (open clusters or globular clusters), and galaxies all glow mostly as "black body radiation" sources (full spectrum) so no special modifications are needed to get rich images of them. Reflection nebulae (such as the blue-glowing halo glow around the stars of the Pleiades cluster) are also no problem. Reflection nebulae usually glow (reflect) blue light wavelengths and these aren't a problem for most normal cameras.
Mar 06, 2016 14:44 | #4 Much improved image Miki. You're definitely headed in the right direction. Processing data has a pretty steep learning curve and will come with practice. I would suggest you stay focused on collecting quality data and plenty of it. I've been shooting for a lot of years with both a Canon 20D and 5D (classic) right out of the box, absolutely no modification, and have had no problem resolving H-alpha nebula. The key is acquiring individual exposures that are long enough to be data rich. Once I was able to extend exposures to 3 or 4 minutes each and collect between 2 and 5 hours of total time my results improved significantly. It's common for beginners to think that stacking short exposures in the same total times as fewer longer exposures will yield the same results. Your final image is only as good as your individual frames, if the data isn't in each of them it won't be there in the final image. Stacking can't magically create or increase data. Astro specific cameras make the process easier and I'm sure are very rewarding, but at a cost. Early on it's far more important to concentrate on the fundamentals of this challenging endeavor. I find that half the fun is learning how to overcome the difficulties and see my photos improving as a result, just as you've done with your image. Steve
Mar 08, 2016 15:42 | #5 Hi Guys.
ToxicCoolaid Goldmember 1,115 posts Likes: 328 Joined Feb 2011 Location: NorthEast Tennessee More info | Mar 12, 2016 15:36 | #6 I have been trying to find some old images I have of the Rosette. These images show what filters can do and what can actually be hiding in an image that you think is no good. I can't find the data for these images but I think they were 45 or 60 seconds long, shooting with white zone light pollution terrible). I was using a SkyWatcher ED80 telescope, and my 1st Canon (a 1000D), and a Astronimik CLS clip in light pollution filter in the camera. I was amazed after I stacked 30 or so images in Deep Sky Stacker and processed it's ouput in PS. It just looked like a bluish-green sky with some stars. I have done better with my newer cameras, different scopes and a darker imaging site, but this shows what you can get from a bad location and images that don't look promising. The CLS filter made all the difference in the world for me. IMAGE LINK: http://i347.photobucket.com …t/12-6-12Rosejpeg2cna.jpg
Mar 12, 2016 18:09 | #7 That second image is a killer ! However the stars center the Rose are slightly leaning towards CYAN .
ToxicCoolaid Goldmember 1,115 posts Likes: 328 Joined Feb 2011 Location: NorthEast Tennessee More info | Mar 13, 2016 00:45 | #8 Oh yeah, it has some problems. Like I said, I've done better since, and I could probably improve it with processing. I just wanted to let Miki know that good data can be in images that don't look like much.
NovaTJ Senior Member 552 posts Likes: 1 Joined Jan 2009 Location: Stafford, Virginia More info | Mar 13, 2016 01:27 | #9 I had the same problem shooting from my light polluted backyard till I tried the CLS filter from Astronomik. Quite a difference. Toxic Coolaid, aka Mo, you do some fine work. Don't listen to Celestron...every star in my images lean toward cyan too! Just joking there Ron.... Astro-Tech 8" f/4 imaging Newtonian,Baader MPCC,Orion ED 80 APO F7.5,Skywatcher EQ-6 Pro,ASGT, Modified Canon 50D, Meade DSI Guide Camera, 8" SCT dovetail mounted relic, Criterion Dynascope RV-6, modified 300D, custom astro shed,and still just getting started!
ToxicCoolaid Goldmember 1,115 posts Likes: 328 Joined Feb 2011 Location: NorthEast Tennessee More info | Mar 13, 2016 15:28 | #10 I guess I forgot to mention that the 1st pic there is how all of Lights looked in the stack. The 2nd pic is what I got after stacking and processing. The CLS was a game changer for me when shooting from home. I would often shoot new targets from home to get an idea of what to expect and make sure I would use up that rare time shooting from my dark location. Greg, I know we have similar LP and some of the same equipment. It help me appreciate your work even more. We all know Ron will tell you like it is. He even keeps the Hubble guys in line
Mar 13, 2016 20:04 | #11 I see Celestron's point. It's a gorgeous image ... but the stars do have a slight blue color cast to them.
Mar 16, 2016 12:56 | #12 Thanks Toxic Coolaid.
ToxicCoolaid Goldmember 1,115 posts Likes: 328 Joined Feb 2011 Location: NorthEast Tennessee More info | That's what I was trying to do, just show you what can be in there. I wasn't worried about the little finial details. As for length of images, See what you can get with your equipment without star tracking. See what length your light pollution will allow. Your histogram should have its biggest hump about 1/3 over from the left. When starting out you'll usually come out better with 30x 30sec images than 15x 60sec. You be much better off with DSS. Make sure 2x or 3x drizzel are NOT checked. Here are a few links that may help.
| Latest registered member is semonsters 1610 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
