Thread started 06 Mar 2016 (Sunday) 07:29
Create Custom Picture Style from Color Checker Passport Profile?
neacail
Gallery: 43 photos
Joined Dec 2013
Mar 06, 2016 07:29 |  #1
I wasn't sure where to post this . . . hopefully this is the right spot?
I would like to create a custom picture style that utilizes the adjustments from a Color Checker Passport profile.
I started to work on a custom picture style last night, but when I got to the six (and individual) colours I had troubles. It would just be so much easier to tweak colours if I could use the existing profile I've already created.
Basically, I want to create a picture style (which includes colour corrections) for each hockey rink that regularly I shoot in. I'd like to reduce post production time, and I'm hoping I can start to utilize JPEGs from the games instead of processing RAW files.
Is there an easy way to tweak the style colours? The Color Checker Profile? Something else?
Shelley
Image Editing Okay
chauncey
Mar 06, 2016 09:27 |  #2
Have you checked youtube?
neacail
Gallery: 43 photos
Joined Dec 2013
Mar 06, 2016 09:30 |  #3
chauncey wrote in post #17925405 (external link)
No. I don't like instructional videos. I prefer written instructions as I find them easier to follow.
Is there something on YouTube that I should have a look at?
Shelley
Image Editing Okay
Alveric
Gallery: 38 photos
Mar 06, 2016 10:09 |  #4
A camera Picture Style? I'm not sure that's possible. You can tweak the Picture Styles on the camera's menu, but actually feeding data to the camera... uh-uh. You can take a picture of the colour chart under the rink's light and use that for a custom WB, maybe that would help.
And I'd strongly advise against using JPEGs straight out of the camera. The camera throws out a lot of data and brands the files with the set Picture Style making post-processing more troublesome. Your exposure also needs to be spot on, as you have less latitude to correct mistakes, and every time you save a JPEG you're throwing away even more data.
I don't think RAW processing can really be avoided. Back when I used LR I used the SpyderCheckr from Datacolor. It's better than the Passport in so far as it uses the HSL/Color [Sic] mode instead of the Camera Calibration profile. Thus, you can tweak the colours easier and save all your adjustments as a preset. I created presets for daylight and for my flashes and then just applied them to imported photos, even those from other shoots where I had not used the colour chart at all. Then I just adjusted one of them photos and copied and pasted the adjustments to all others (assuming the shot and lighting conditions were the same or similar). Then the images were sent to PS as TIFFs and final retouching done; imported back into LR and I could generate the JPEGs I needed: I had presets for that too, so it was quick.
rrblint
Gallery: 84 photos
Joined May 2012
Mar 06, 2016 11:12 |  #5
You can create any picture style that you wish using Canon's "Picture Style Editor" software.
Mark
neacail
Gallery: 43 photos
Joined Dec 2013
Post edited over 7 years ago by neacail.
Mar 06, 2016 12:10 |  #6
Sorry. I always assume that everyone knows about and uses Canon's "PictureStyleEditor" software. :oops:
I'm content to do post processing work for our own association. But, at tournaments I've been approached several times by managers and coaches from other associations to shoot their games.
Shooting for our own association is huge pile of work, so I don't want to add another association's post processing work to my load.
I've always turned down the offers from any teams outside of our association. But, if I could just provide a memory stick of JPEGs at the arena right after a game for a nominal fee ($50 bucks or so), I'd be more inclined to take up offers.
I have a lot of troubles with yellows, oranges, and caucasian skin tones SOOC, in almost all of the arenas.
This is an image from last night's practice (at the brightest arena I shoot in . . . which is lit with fluorescent tube lighting) that I processed from RAW, with a profile I created from a Color Checker Passport:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/03/1/LQ_779647.jpg
Image hosted by forum (779647) © neacail [SHARE LINK]
Here is the SOOC JPEG:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/03/1/LQ_779648.jpg
Image hosted by forum (779648) © neacail [SHARE LINK]
The picture style in the above case was "portrait." I've tried all of the standard picture styles and they all do really, really bad things to the yellow strip that runs along the bottom of the boards. Varying degrees of other "bad things" happen with the other picture styles. I simply cannot give anyone photos where that yellow strip is such an off colour.
Shelley
Image Editing Okay
Alveric
Gallery: 38 photos
Mar 06, 2016 14:14 |  #7
Yup, that's one reason I don't bother with Picture Styles, the colours can be all out of whack. I have my cameras permanently set to Neutral, and I reset all the values (Saturation, Sharpness, &c) to 0. The JPEG on the LCD screen looks like poop, but I'm not using it to determine exposure anyway, so I don't care.
Yeah, I didn't know about the Picture Styles software. :( :oops:
TerminalCity
Gallery: 16 photos
Joined Apr 2013
Post edited over 7 years ago by TerminalCity with reason 'Butter fingers'. (2 edits in all)
Mar 06, 2016 18:11 |  #8
There's no automated way to do this sadly, and I'd like the same capability, but maybe enhanced to allow dual-illuminant.
You might be able to do it to some extent by creating a custom style based on Neutral, and when selecting the colours in Canon PSE try and match up the colour wheel with the known Macbeth colour swatches. This might need to be a slightly subjective visual compare on a calibrated monitor but perhaps would get you "close enough".
You'll need RAW images of the CCP of course along with some sample RAW's in the same lighting to tweak it closer.
Incidentally, a couple of in camera JPG options that might be worth testing if you haven't already:
Neutral profile with +1 Saturation
Standard with -1 or -2 Contrast, -1 Saturation
and set in-camera white balance with the CCP white balance target
Otherwise, shoot RAW / MRAW and import into LR with your custom profile, set white balance, sync all and export.
BTW, I used to use the X-rite software to create my profiles but recently switched to the Adobe profile editor. The result is a bit less saturated (reds most notably), little less contrast and I find it a bit more forgiving.
neacail
Gallery: 43 photos
Joined Dec 2013
Mar 07, 2016 06:07 |  #9
TerminalCity wrote in post #17925964 (external link)
I'll try this tonight, thank you.
I'm trying to remember what the lights are like at the arena this week's tournament is in. I think they're metal halide, which means I have to run with AWB due to phase shifting in the colour spectrum. If I remember correctly, this arena is also exceptionally dark. I've only been in this arena once before, and I didn't shoot that game.
I really need to keep better notes on the arenas.
Shelley
Image Editing Okay
chauncey
Mar 07, 2016 10:47 |  #10
What software are you using...you are shooting RAW, right??
This whole question sounds like a no-brainer...take a picture of the color checker before or after and base all your readings on that image.
nathancarter
Gallery: 32 photos
Mar 07, 2016 11:24 |  #11
neacail wrote in post #17926427 (external link)
Interested in your results. Please keep us updated.
I expect that you won't be able to accomplish it with the metal halide lights, since each shot will be not only a different color temperature, but different results across the spectrum.
chauncey wrote in post #17926724 (external link)
Respectfully, I don't think you're getting the problem.
Making a profile in the computer is relatively easy, given the X-rite software. However, that requires taking all the pictures back to the computer and editing them using that profile.
The goal is to deliver finished jpegs immediately after the event, which requires minimizing the amount of processing. To that end, using the Picture Style editor to create an IN-CAMERA picture style that agrees with the camera profile generated by the X-rite software. Ideally, with that picture style, the in-camera jpegs will be correct and no further processing will be necessary.
adam.willison
Joined Aug 2015
Mar 07, 2016 11:33 |  #12
I'm also interested in your results. I have been playing around with Picture Style Editor recently and it is quite finicky to get the colors to do what you want them to do, compared to something like LR.
neacail
Gallery: 43 photos
Joined Dec 2013
Mar 07, 2016 13:10 |  #13
Since not everyone who is reading this thread is familiar with the Canon's Picture Style Editor, I'm adding some screen shots of the program and process.
nathancarter perfectly summed up my process and my goals.
The X-rite software is only for use with the X-rite color checkers and is a part of my RAW post processing, but the other piece of software that I'm using is available to all Canon DSLR uses.
If you don't have "PictureStyleEditor" on the disk that came with your Canon DSLR, you can download it from the Canon support website. The picture styles affect the preview on the camera's screen and in camera JPEG generation (most of us already know this). It is a handy piece of software and is worth learning about. :)
Once "PictureStyleEditor" is downloaded and installed, open it.
You'll see this:
IMAGE: https://farm2.staticflickr.com/1655/24962185724_92b0497b20_b.jpg
Drag the image that you want to build the picture style off of into the program. Note that I work in sRGB for standard digital deliverables that will be viewed/utilized on consumer electronics.
IMAGE: https://farm2.staticflickr.com/1647/25296959330_4f52401a3a_b.jpg
Just click "Close" and get to work!
IMAGE: https://farm2.staticflickr.com/1697/25296972170_fae133d7f7_b.jpg
I've split the preview screen so I can see the SOOC RAW on the left and what my adjustments are doing to the image on the right.
I've selected the "Neutral" picture style to base my custom picture style on and increase the saturation +1 (following TerminalCity's suggestion).
The yellow that I'm worried about still looks like garbage. But, I can try to deal with that on the next screen:
IMAGE: https://farm2.staticflickr.com/1479/24965914163_ecdc48be10_b.jpg
I select "Yellow" and I decrease the hue -10. This give me a yellow that is closer to what I'm looking for, and though you can't see it in this screen shot, it also improves the orange along the top of the boards.
That's the only colour that I know with absolute certainty was still a mess, so I move to the next screen:
IMAGE: https://farm2.staticflickr.com/1492/25499926701_236b29dc19_b.jpg
I make no changes on this screen. I'm thinking this is where my X-Rite colour profile will come into play to adjust individual colours. I still have to play with individual RGB values.
Click the "save" icon:
IMAGE: https://farm2.staticflickr.com/1676/25225099069_b1a446c844_z.jpg
Name the file and add a caption (you need a caption to save the file).
All done in PictureStyleEditor. :)
Connect your camera to your computer, and the picture style can be loaded on the camera using EOS Utility:
IMAGE: https://farm2.staticflickr.com/1566/24962158634_5bfdfe90ed_z.jpg
Click on "Register Picture Style File"
IMAGE: https://farm2.staticflickr.com/1606/24965937863_1bc2ac7c1e_z.jpg
Select which user defined file you would like to apply your new picture style to. Navigate to the folder on your system where you stored the file. Select the file, and click "OK."
Your new, custom, picture style is now loaded on your Canon DSLR. :)
I use a Mac, and some things may look a little different but everything functions the same on Mac and PC. If I missed a step or was confusing, I'm happy to fill in any details that I may have missed. :)
Shelley
Image Editing Okay
Alveric
Gallery: 38 photos
Mar 07, 2016 13:19 as a reply to  @ neacail's post |  #14
Thanks a lot for that, Shelley.
Looks useful when you have to shoot JPEGs. The one thing I'm wondering about is how the WB will impact the custom style.
neacail
Gallery: 43 photos
Joined Dec 2013
Mar 07, 2016 13:32 |  #15
Alveric wrote in post #17926926 (external link)
I don't have the answer to that question. I guess it depends on what adjustment the camera does first? If it applies the white balance correction first, then I think the profile should be fine. But, if it just applies the profile correction and ignores the white balance there is going to be an issue.
I did find out (by checking the arena's website) that the rink I'll be shooting in this week uses incandescent lighting. That's probably why I remember the rink being so abnormally dark. I'll be able to use a custom WB.
I'm just going to try the edited neutral profile tonight. Depending on how that goes, I think I've figured out how I can build a picture style based on my X-Rite profile: by entering in each RGB adjustment individually: by taking the corrected RGB value from Photoshop, and loading the photo of my Color Checker Passport in the PictureSyleEditor. I just don't know how the individual colour adjustments will be applied: if only that specific RGB value will be adjusted, or if gradients, blends, hues, etc. will be calculated.
Shelley
Image Editing Okay
8,452 views & 1 like for this thread, 12 members have posted to it and it is followed by 7 members.
1455 guests, 127 members online
