Thread started 07 Mar 2016 (Monday) 19:26
Lightroom question
mike_311
Checking squirrels nuts
Gallery: 18 photos
Joined Mar 2011
Mar 07, 2016 19:26 |  #1
I just installed LR CC on a new pc. On the old pc when I would "edit in Photoshop, edit original" and go into PS. When i hit save, LR would update with the changes made in PS keeping any previous LR adjustments I made. Now if I make any LR adjustments, open it in PS, hit save. LR resets any adjustments back to default.
I cant figure out how to get it to keep my LR adjustments.
Canon 5d mkii | Canon 17-40/4L | Tamron 24-70/2.8 | Canon 85/1.8 | Canon 135/2L
www.michaelalestraphot​ography.com (external link)
Flickr (external link) | 500px (external link) | About me
pknight
Gallery: 39 photos
Joined Feb 2006
Mar 07, 2016 21:25 |  #2
I tried to reproduce what you describe, and could not. I edited a virtual copy of an image in LR CC (converted it to B&W), and then opened it for editing in PS CC. There I used a curves adjustment to increase the contrast to a ridiculous level, and hit Save. Back in LR I had the original B&W version, and the high-contrast B&W version created by PS. The LR editing (B&W conversion) was evident in both images.
What sort of adjustments are you making in LR?
Digital EOS 90D Canon: EF 50mm f/1.8 II, EF 50mm f/2.5 Compact Macro, Life-Size Converter EF Tamron: SP 17-50mm f/2.8 DiII, 18-400mm f/3.5-6.3 DiII VC HLD, SP 150-600 f/5-6.3 Di VC USD G2, SP 70-200 f/2.8 Di VC USD, 10-24mm f/3.5-4.5 DiII VC HLD Sigma: 30mm f/1.4 DC Art Rokinon: 8mm f/3.5 AS IF UMC
pknight
Gallery: 39 photos
Joined Feb 2006
Mar 07, 2016 21:27 as a reply to  @ pknight's post |  #3
Now I see your problem. You chose "Edit Original," when you should be selecting "Edit Copy with Lightroom Adjustments." "Edit Original" ignores your LR adjustments.
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Mar 08, 2016 03:04 |  #4
+1 to above "edit copy with Lightroom Adjustments".
Dan Marchant
mike_311
Gallery: 18 photos
Joined Mar 2011
Mar 08, 2016 06:06 |  #5
not quite.
On my old PC, let say i made some adjustments, say convert to B/W in LR. I decide I need to clone something out, so i right click, edit in PS, edit original. do my cloning , hit save and when i got back into LR, my black/white conversion and any adjustments are still applied, only now to the new tiff or psd.
whats happening now is when i return to LR the image defaults back to the original SOOC settings.
If I choose edit with lightroom settings i wont be able to get back to my original sooc shot if i wanted to.
DagoImaging
Gallery: 20 photos
Joined Nov 2012
Mar 08, 2016 06:49 |  #6
When you hit save in PS it should be saving it as a .tiff or .psd file based on your settings. It does not apply your PS edits to the RAW file you opened from LR. Whatever edits you had on your LR raw file should still be there. Most likely you are seeing the images stacked in LR. If there is a number on the thumbnail in LR, RMB and select unstack. This will then show you both the raw and the tiff/psd file side by side (if you sort by date created).
When you open the image from LR w/ edit original should open the image in LR w/o any LR adjustments.
Sony a7R3a/a6300/ 16-70/4 / 70-200/4 G / 12-24/4 G/ 24-105/4 G /Sony HVL-60M
NullMember
Mar 08, 2016 07:08 |  #7
bannedPermanently
What file type are you editing in Lightroom. Is it a RAW file or a TIFF/PSD/JPEG
pknight
Gallery: 39 photos
Joined Feb 2006
Post edited over 7 years ago by pknight.
Mar 08, 2016 07:53 |  #8
mike_311 wrote in post #17927822 (external link)
not quite.
Not so. The original SOOC shot is always available. If you want the SOOC image of any LR-edited image, just create a virtual copy (to save your edits), select the original image, and click the Reset button in Develop. Your original will revert to its SOOC state, and the virtual copy will contain your LR edits. This is because, unlike PS, LR never changes a single pixel of the original image.
mike_311
Gallery: 18 photos
Joined Mar 2011
Mar 08, 2016 08:56 |  #9
pknight wrote in post #17927897 (external link)
clarification. I want my PS edits not to have any LR adjustments, when i edit them. The only edits i apply in PS are using cloning, healing, etc. all color, exposure adjustments are done in lightroom.
mike_311
Gallery: 18 photos
Joined Mar 2011
Post edited over 7 years ago by mike_311.
Mar 08, 2016 09:01 as a reply to  @ NullMember's post |  #10
i edit RAW and PS creates .tiff. and LR creates a stack.
It seems that when LR creates imports the .tiff it doesn't apply the LR adjustments that were made to the image before I went into PS. Likewise if i make adjustments to the .tiff in photoshop after I made adjustments in PS, the tiff will revert back to its original unadjusted form. The save process in PS seems to make LR ignore or overwrite the sidecar file that it was associated with.
NullMember
Mar 08, 2016 09:24 |  #11
bannedPermanently
mike_311 wrote in post #17927981 (external link)
mike_311 wrote in post #17927984 (external link)
You seem to be contradicting yourself
DagoImaging
Gallery: 20 photos
Joined Nov 2012
Mar 08, 2016 09:28 |  #12
I think you're overly confused.
DagoImaging
Gallery: 20 photos
Joined Nov 2012
Mar 08, 2016 09:37 |  #13
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/03/2/LQ_779982.jpg
Image hosted by forum (779982) © DagoImaging [SHARE LINK]
Any edit to the Raw in LR will not effect the .tiff image. If you want the raw in LR to be SOOC then reset your develop settings.
travisvwright
Gallery: 21 photos
Joined Feb 2013
Mar 08, 2016 10:00 |  #14
DagoImaging wrote in post #17928020 (external link)
I know I am.
I come here for your expert opinion. Please do not hesitate to critique or edit.
70D, 6D, Canon 135, Tamron 28-75 2.8, Tamron 70-200 2.8 VC, Canon 50 1.4, Canon 100 2.8 Macro, Canon 85 1.8, Canon 10-18 4.5 STM
Franklin NC Photographer Travis Wright (external link)
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Mar 08, 2016 10:09 |  #15
I have never heard of any version of LR/Photoshop being able to do what you describe....
- edit RAW in LR - Open that image in PS without edits - edit the image (creates a new TIFF) - return back to LR where the edits from the RAW file get applied to the new file.
That's not to say it can't be done, just that I don't know of any way it could happen automatically. You can do it by selecting the edited RAW, then the new TIFF and then select Sync Setting, which will copy all the edits across to the TIFF.
There may possibly be a way to get what you describe if you use Smart Objects but I have never heard of it.
Dan Marchant
3,835 views & 5 likes for this thread, 6 members have posted to it and it is followed by 4 members.
Lightroom question
1323 guests, 124 members online
