TeamSpeed wrote in post #17932780
Would you be able to share the raw? I believe the results are from how you are processing the raw.
That would be nice. I suspect a possible defect in the camera, because the "wormy maze" look is just as strong in the white areas as in the dark areas, which would suggest a "noise" problem that is scalar, rather than additive. It may be that the two RAW green channels have different gains, and the converter used does not adapt to that. IIRC correctly, there have been converters with the option to process the two green RAW channels as separate colors, and that option gets around this issue.
I know that many 1Ds2 cameras had a green-channel unbalance, but I've never heard of it with the 1Ds3.
