Thread started 12 Mar 2016 (Saturday) 07:46
How to configure EOS 7 D Mark II for telephoto lens
J ­ R ­ Mohan
Gallery: 218 photos
Mar 12, 2016 07:46 |  #1
The 7 D Mark II doesn't recognize telephoto lens. Please guide how to configure telephoto lens on it.
Jai.
sapearl
Gallery: 243 photos
Mar 12, 2016 07:57 |  #2
J R Mohan wrote in post #17932686 (external link)
Jai.
Is this a Canon lens or another brand? Normally this should not be an issue - just pop the lens on and go. What exactly is the camera not doing? Are you getting error codes, is it not auto-focusing, is it metering improperly or not at all? Please give us some more info so we can do a better job of helping :-)
MY WEBSITE (external link)- MY GALLERIES (external link)- MY BLOG (external link)
Artists Archives of the Western Reserve (external link) - Board
J ­ R ­ Mohan
Gallery: 218 photos
Mar 12, 2016 09:59 as a reply to  @ sapearl's post |  #3
It is Canon EF 300 mm F/2.8 L II lens. Attach it with camera and click but no image is taken nor any error message is flashed .
Archibald
You must be quackers!
Gallery: 789 photos
Mar 12, 2016 11:06 |  #4
It is not necessary to "configure" a lens for the 7D2.
It would be helpful if you could provide more information.
For instance, does the 7D2 work with other lenses? What is the history of the telephoto lens? And so on...
I'm Ed. Migrating to Focus on Photography (https://focusonphotogr​aphy.community.forum/ (external link)) where I'm Archibald.
GyRob
Mar 12, 2016 11:23 |  #5
Very odd , you might want to clean the contacts on the camera and lens ,a gentle wipe over with a clean cloth should be all in needs.
Rob.
"The LensMaster Gimbal"
sapearl
Gallery: 243 photos
Mar 12, 2016 11:58 as a reply to  @ GyRob's post |  #6
What was the last lens you used on your 7D and did it function fine?
FEChariot
Gallery: 13 photos
Joined Sep 2011
Mar 12, 2016 13:45 |  #7
I have had a similar issue when using off brand Fotodiox tubes on occasion. I usually just remount and it takes off. I would check to make sure you are getting a good mount with solid click and clean the contacts.
Canon 7D/350D, Σ17-50/2.8 OS, 18-55IS, 24-105/4 L IS, Σ30/1.4 EX, 50/1.8, C50/1.4, 55-250IS, 60/2.8, 70-200/4 L IS, 85/1.8, 100/2.8 IS L, 135/2 L 580EX II, 430EX II * 2, 270EX II.
J ­ R ­ Mohan
Gallery: 218 photos
Mar 12, 2016 21:31 as a reply to  @ Archibald's post |  #8
Yes it worked normally with other lens, the 70-300 L . The EF 300mm F/2.8 L is a new lens which I use on my 6D . I wanted to test it on 7d MkII but it didn't work.
J ­ R ­ Mohan
Gallery: 218 photos
Mar 12, 2016 21:32 as a reply to  @ sapearl's post |  #9
EF 70-300 L and EF 50mm F/1.4. They all worked well.
Archibald
Gallery: 789 photos
Mar 12, 2016 21:44 as a reply to  @ J R Mohan's post |  #10
You are in the best position to solve the puzzle, because only you know the details of the situation.
rrblint
Gallery: 84 photos
Joined May 2012
Mar 12, 2016 22:03 |  #11
Do you have mirror lock up activated?
Mark
sapearl
Gallery: 243 photos
Mar 12, 2016 22:14 as a reply to  @ rrblint's post |  #12
With the new lens attached, can you see through the viewfinder at all?
J ­ R ­ Mohan
Gallery: 218 photos
Mar 13, 2016 08:30 as a reply to  @ sapearl's post |  #13
At last returned the 7D mkii to the dealer and took a 5 D mkiii instead. The new 7D was becming a puzzle.
Thank you all for your time and suggestions.
Jai.
drifter106
Joined Feb 2006
Mar 13, 2016 08:57 |  #14
wondered was the issue was...have one and wandering what to watch out for....
Gear
Remember, what is common knowledge to some is a revelation to others.
For the sake of his sorrowful passion, have mercy on us and the whole world.
sapearl
Gallery: 243 photos
Mar 13, 2016 12:33 |  #15
J R Mohan wrote in post #17933661 (external link)
Jai.
Sorry you never worked it out - you would have enjoyed the camera plus we were all quite curious. The 5d3 is a marvelous camera.
3,768 views & 0 likes for this thread, 7 members have posted to it and it is followed by 3 members.
1689 guests, 115 members online
